Experimental interference of independent photons
In summary, the Zeilinger group has published a paper in Physical Review Letters discussing the possibility of observing fully destructive interference of photons originating from separate, independent sources. According to quantum theory, this is possible due to the interference of probability amplitudes of multiparticle detection events. However, a reader questions this claim and suggests a classical analog of two independent sources creating waves in a pool of water, which would also result in constructive and destructive interference. The authors of the paper invite the reader to show a mathematical explanation for this classical analog. The paper can be accessed at the given link and it also discusses the Hong-Ou-Mandel-type interference, which only occurs when two equal photons with the same polarization enter a beamsplitter at the same
ZapperZ
Staff Emeritus
Education Advisor
Insights Author
32,820
4,720
Don't miss this paper from the Zeilinger group:
R. Kaltenbaek et al, PRL 96, 240502 (2006).
In particular, read the first paragraph:
Is it possible to observe fully destructive interference of photons if they all originate from separate, independent sources? Yes, according to quantum theory. The perfect interference of photons emerging from independent sources cannot be understood by the classical concept of the superposition of electromagnetic fields but only by the interference of probability amplitudes of multiparticle detection events. As stressed by Mandel ‘‘this prediction has no classical analogue, and its confirmation would represent an interesting test of the quantum theory of the electromagnetic field’’
Zz.
‘‘this prediction has no classical analogue, ..."
Don’t see how this can be claimed.
A simple classical pool of water with two points independently generating waves of exactly the same frequency will generate waves that overlap each other and can be observed alone a line some distance from both sources. Even if the sources are out of phase that phase difference between the independent sources would remain fixed as the frequencies are the same. You would still find points along the observation line of complete constructive interference with the waves doubling in size. And points in-between those constructive points where there is destructive interference and no wave or change in water height at all. How much more of a matching classical analog could they expect? I see no interesting test here that would indicate anything.
Read the paper. If you can show mathematically how classical wave superposition can produce the same results shown in Fig. 3, then write to PRL.
Zz.
You can read the paper here:
http://arxiv.org/abs/quant-ph/0603048For those who want to find interpretations of Quantum Mechanics in
combination with Classical EM:
If one photon enters the beamsplitter it will be detected only at one
of the two outputs, either one but not at both outputs at the same time.
In this experiment:
If two equal photons enter the beamsplitter at the same time, at
different inputs, (there are two inputs), there will only be something
detected at one of the two outputs, either one, but there won't be
detected anything at both outputs at the same time.
This is the so-called Hong-Ou-Mandel-type (HOM) interference.
The effect disappears if the two photons have different polarization.Regards, Hans
FAQ: Experimental interference of independent photons
What is experimental interference of independent photons?
Experimental interference of independent photons refers to the phenomenon in which two or more photons that are not connected or correlated in any way interfere with each other. This effect is typically observed in experiments that involve the manipulation and measurement of individual photons.
How is experimental interference of independent photons achieved?
Experimental interference of independent photons is achieved through the use of special experimental setups, such as the Mach-Zehnder interferometer or the double-slit experiment. These setups involve splitting a beam of light into two paths and then recombining them, allowing for the interference of the individual photons.
What is the significance of experimental interference of independent photons?
Experimental interference of independent photons has significant implications for our understanding of the nature of light and the behavior of photons. It provides evidence for the wave-particle duality of light, as well as the role of probability in quantum mechanics.
What are some real-world applications of experimental interference of independent photons?
Experimental interference of independent photons has potential applications in fields such as quantum computing, telecommunications, and cryptography. It also plays a crucial role in experiments and studies related to quantum entanglement and quantum information.
Are there any challenges or limitations associated with experimental interference of independent photons?
Yes, there are several challenges and limitations associated with experimental interference of independent photons. These include technical difficulties in achieving and maintaining a stable interference pattern, as well as the limitations of our current technology in manipulating and measuring individual photons accurately.
