How Is Relativistic Mass Measured Indirectly in Physics?
In summary, measuring relativistic mass and energy is not a direct process, but rather relies on calculating them from measured kinematic quantities. One method involves measuring the strength of a uniform magnetic field and the velocity of a charged particle moving through it, and then using the cyclotron relation to calculate momentum and eventually the relativistic energy of the particle. This highlights the fact that all measurements in physics are ultimately based on kinematic principles.
bernhard.rothenstein
991
Measuring the relativistic mass and energy
When we speak about a physical quantity we should define it and it is compulsory to propose a procedure of measuring it.
But how does one measure relativistic mass? The answer lies in the fact that relativistic mass (as well as proper mass) is never really measured directly, nor is energy measured directly. As Jammer1 wrote, “As in the last analysis all measurements in physics are kinematic in nature.” So, one does not measure mass nor energy. One calculates them from measured kinematic quantities. Suppose you know the strength of a uniform magnetic field B. Launch a charged particle, of magnitude charge q, into the field such that the velocity is perpendicular to the field lines. The charge will move in a circle of radius r. B is known while r and v are measurable. Then use the cyclotron relation p=qBr to find p. Then m=p/v. Multiply by c2 to get the relativistic energy of the particle E=mc2. We have indicated a measurement procedure for a physical quantity on which physicists wish to ban.2
References
1 Max Jammer, Concept of Mass in Classical and Modern Physics, (Harper and Row, 1964, Dover 1997)
2 Lev Okun, “The concept of mass,” Phys.Today, 42, 31-36 (1989)
Do you aggree with the lines above?
I don't think I could have stated it better myself. :biggrin:
One question remains though - How does one measure the relativistic mass of a particle with no charge?
Pete
Pete
Ummm, measure its momentum in a known momentum conservation situation? Like a calorimeter; see how far it penetrates some material of known density, such as water or armor-plate steel.
And how do you propose to measure the momentum? Also, a calorimeter does not measure the energy, E, of a particle. It measures, K, the kinetic energy. If the proper mass of the particle is a known quantity then what you say is a sufficient method of measuring the mass of a particle.
Pete
I have a few comments on this multi-faceted post.
This is usually called the "Operational Method".
I'll have to consult the reference for more elaboration of this point. I recall a profound statement I heard in graduate school: measurements are the results of inner products with one's measuring devices.
It may be enlightening to express a measurement such as this in the way described above.
While your procedure may be one measurement method, I think it's fair to say that it may be unnecessarily complicated [for a theoretical discussion on foundations]. (To play the critic, I'll ask how all of these other quantities are defined.) I suspect there should be a simpler measurement that can be carried out in theory.
I don't see the point of this statement. It seems to me, the issue of relativistic mass "which physicists wish to ban" arises not out of a failure to measure it or to define it... it is an issue of pedagogy.
References
please explain me in detail what do you mean by the statemnt. it sounds attractive
thanks
References
No, energy can be measured. Basically, let electron pass through two wire loop to measure its speed, then hit a target, measure the temperature change to get energy, it agree with the relativistic equation of energy
Proper mass can be measured using the same techniques as measuring "the mass" in Newtonian mechanics. The most fundamental way of measuring the mass of an object is to put it on a balance in a uniform gravitational field, or in an accelerating reference frame if you prefer not to deal with gravity, and thereby compare its mass with a standard mass.
FAQ: How Is Relativistic Mass Measured Indirectly in Physics?
What is relativistic mass?
Relativistic mass is a concept in physics that describes the increase in mass of an object as it approaches the speed of light. This increase in mass is due to the object's energy increasing as it gains speed.
How is relativistic mass measured?
Relativistic mass can be measured using the formula m = m0 / √(1- v^2/c^2), where m0 is the rest mass of the object, v is its velocity, and c is the speed of light. This formula is known as the mass-energy equivalence equation and is derived from Albert Einstein's theory of special relativity.
Can an object's relativistic mass ever exceed its rest mass?
Yes, as an object approaches the speed of light, its relativistic mass will continue to increase without limit. This means that theoretically, an object's relativistic mass can exceed its rest mass, although it would require an infinite amount of energy to accelerate an object to the speed of light.
How does relativistic mass affect an object's momentum?
Relativistic mass is related to an object's momentum through the equation p = mv, where p is momentum, m is relativistic mass, and v is velocity. As an object's velocity increases, its relativistic mass increases, resulting in a greater momentum.
Why is the concept of relativistic mass important?
The concept of relativistic mass is important because it helps us understand the behavior of particles at high speeds, such as those in particle accelerators. It also plays a crucial role in theories of special relativity and is essential for accurate calculations in fields such as astrophysics and cosmology.
