Problem involving polynomial equations
  • Thread starter Thread starter Byrgg
    Polynomial
To form an open box from an 8cm x 6cm rectangular sheet by cutting identical squares from each corner, the volume must equal 16cm^3. The initial equations proposed include xyz = 16cm^3, 2x + y = 8, and 2x + z = 6, where x is the side length of the squares cut out. Participants suggest eliminating either y or z from the equations to simplify solving for x. A diagram may aid in visualizing the problem and finding the solution more effectively.
Byrgg
335
Identical squares are cut out from each corner of a rectangular sheet of tin 8cm x 6cm. The sides are bent upward to form an open box. If the volume of the box is 16cm^3, what is the length of each side of the squares cut out from the original sheet?
I came up with the following equations to start, I don't know if they're right though:
xyz = 16cm^3
2x + y = 8
2x + z = 6
I'll try to make a diagram and put it up later, if anyone thinks it would help.
The equations look good. If you can eliminate either the y or the z from one of the second two equations you can solve it easily.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is , being the parameter. From my side, the only thing I could...
