arildno said:If an exact value can be found for that definite integral, I suspect you should make a contour integral in the complex plane in order to crack it.
snipez90 said:Hint: try to decompose the integral into two integrals. one should have limits of integration from 0 to pi/2
exploit symmetry and manipulate the limits of integration to solve the problem. these identities might also help: sin(x) = sin(pi - x), 2sin(x)cos(x) = sin(2x).
Defennder said:Yes, I agree it's a series of tricks. I just solved it yesterday and was amazed at the elegance of the solution. Dick's hint in the other thread proves to be very helpful.
An integral problem is a mathematical problem that involves finding the area under a curve. It is often used to solve problems related to motion, such as finding the distance traveled by an object or the amount of water in a tank at a given time.
Solving integral problems is important in various fields of science and engineering. It helps us understand the relationship between quantities and their rates of change, and allows us to make predictions and solve real-world problems.
There are several methods for solving integral problems, including using basic integration rules, substitution, integration by parts, and numerical integration. The choice of method depends on the complexity of the problem and the available tools.
No, integral problems cannot be solved without using calculus. Integration is a fundamental concept in calculus, and it is necessary to solve integral problems involving rates of change and accumulation of quantities.
To improve your skills in solving integral problems, it is important to have a strong foundation in calculus and practice regularly. You can also seek help from tutors or online resources, and work on a variety of problems to gain a better understanding of the concepts.
