Dmitry67
- 2,567
- 1
I read many threads in this forum (in QM section), and in many cases I witnessed the same logical flaw over and over again. People conclude that, for example, if world is deterministic, than there is no free will, because our consciousness is deterministic too. Why? Because our brain is nothing more than a huge collection of atoms and molecules. Hence all properties of the brain can be reduced to the properties/configuration of the parts it consists of.
This is not true for purely mathematical reasons. Let be begin from some hand-waving. Remember HUP? When we measure position we affect the impulse. So we can’t make 2 accurate position measurements of the same particle. This limitation is not instrumental. What if our consciousness has the same property? If you try to explain the consciousness based on how the molecules function in a brain, you destroy the brain in a process no matter how small is your scalpel. If you start measuring the positions of the particles in the brain you add random momentum to them, heating the brain and destroy it as it does not support even slight overheating.
Now, if that limitation is not instrumental than our consciousness is a very interesting object. Let say we have a predicate [itex]IsCons(x)[/itex] which is true when system [itex]x[/itex] is conscious. What we know is that for any system we know all the details about, isCons is false: [itex]isCons(\overline{x})=0[/itex] Note that [itex]\overline{x}[/itex] is constant, not a variable. In another words:
[itex]\forall X \vdash IsCons(X) = 0[/itex]
(for every constant X we can prove that isCons(x) is false). At the same time, conscious objects do exist:
[itex]\vdash \exists Y : IsCons(Y)=1[/itex]
Is it a contradiction? NO, even it is conter-intuitive. In mathematics many object possesses the same weird property. Look for example at famous http://en.wikipedia.org/wiki/Banach–Tarski_paradox
There exists a decomposition of a solid ball in 3-dimensional space can be split into a finite number of non-overlapping pieces, which can then be put back together in a different way to yield two identical copies of the original ball. That sounds really impossible because we can’t imagine such decomposition. But can we provide any examples of Banach-Tarsky decomposition?
No, this is absolutely impossible! Banach-Tarsky theorem is a consequence of AC (Axiom Of Choice). If it would be possible to provide an example of such decomposition, then the example itself would be a proof, so no AC would be needed. Hence providing an example is not possible.
The weird property I described is called [itex]\omega[/itex]-inconsistency, which is weaker then inconsistency. Formal arithmetic is [itex]\omega[/itex]-consistent. There is undecidable Goedel statement G, however. You can add G or [itex]\neg G[/itex] as a new axiom, but only one choice will be [itex]\omega[/itex]-consistent
Unfortunately, more complicated theories (Set Theory) are [itex]\omega[/itex]-inconsistent from the very beginning (for other examples check Continuum Hypothesis for example). We see how these weird properties emerge on some level of complexity. Of course, it is not a proof that human consciousness actually has weird property I explained above. However, it shows that the knowledge about the structure of a system and about how that system works might ‘non commute’ with some properties of that system. You can know all the details about the dead brain, not about the alive one.
Hence many ‘proofs’ in the QM section fundamentally flawed.
