Decoherence for dummies and experts
  • Thread starter kurious
  • Tags
    Decoherence
In summary, according to this website, decoherence is what happens when you try to measure something in a superposition state. You can't keep a superposition state alive forever, and it eventually collapses into a mixed state.
kurious
641
This is a link that shows a visual depiction of decoherence:
http://www.geocities.com/scjphysicist/decoh.html
and this is a link with the technical details of decoherence:
http://www.ece.rochester.edu/~habif/Web/Research/decoherence.htm
Is the second link saying that measuring one electron repeatedly in a Josephson junction, at different times, is the same as measuring lots of electrons simultaneously?
From your first link:
"The decoherence effect explains how a superposition of states becomes a mixed state"
Is this true? It's not possible taht decoherence acts in a superposition to produce a pure state?
From the first link:
a superposition = sum of two wavefunctions which is then squared to give
probability amplitude function
mixed state = square wavefunctions first then add them
decoherence is superposition becoming mixed state
no pure state because we are talking about more than one particle
in this system
also I think generally, mixed state includes observer and observed
trying to learn about this
Interesting!
I´m learning about femtochemistry, excuse my inexperience in quantum physics.
Imagine a real sample of diatomic ideal gas (suppose harmonic oscillator for simplicity). You want to prepare a superposition state between two or more eigenstates of the system and probe it at various time delays.
You use an ultrashort femtosecond laser pulse to prepare the state.
Why is that superposition induced, instead of a simple spectroscopic transition between two stationary states?
What energy does this state have? Are population of the sample "oscillating" between the two eigenstates?
Thanks for your interest
The superposition is induced because the femtosecond wavepacket from the laser is classically considered to be a mixture of frequencies and each frequency can cause a different spectroscopic transition,so the wavefunction of the molecules has to reflect this.The population does not oscillate between eigenstates it exists in
the superposition - that is wavefunctions for each spectroscopic state are added together and then squared to give the probability amplitude function.Superpositions are very strange indeed! One day,hopefully, superpositions will be given a more intuitive explanation rather than just a mathematical one.
We employ superpositions of sound waves all the time. They're called chords.
One has to be careful. When looking at the combination (system+macroscopic measurement apparatus), a superposition remains a superposition of course, because the hamiltonian is a linear evolution operator. But what decoherence shows you is that *when you restrict your attention to the system*, then what formerly was a superposition, is now best described (best described because you are neglecting part of it, namely the measurement system) by a statistical mixture of eigenstates of the operator that is measured by the measurement apparatus.
cheers,
Patrick.
kurious said:
The superposition is induced because the femtosecond wavepacket from the laser is classically considered to be a mixture of frequencies...
Ok! The reason is the energy uncertainity of the pulse, right?
I undrestand. Controlling the shape of that pulse you can adjust the eigenstates that you want to take part in the superposition (or, what is the same, the initial coefficients of the terms of the superposition).
Decoherence can be also controlled whith sequences of pulses, but that´s still too difficult for me. I´m working on it. It´s the optical analogous of the NMR multipulse thechniques.
As a chemist (well, still student) i have to say that experimental detection, and control of this states is the future of chemistry or at least important part of it (in my opinion). Frontiers between physics and chemistry are now nonsense.
I hate to advertize my own site, but Scott (the author of the website in question) and I had a discussion along this line almost a year ago. You can read a part of it here:
http://groups.yahoo.com/group/undernetphysics/message/465
Zz.
FAQ: Decoherence for dummies and experts
What is decoherence and why is it important in science?
Decoherence refers to the interaction between a quantum system and its surrounding environment, which causes the system to lose its quantum properties and behave more classically. It is important in science because it helps explain the transition from the microscopic world of quantum mechanics to the macroscopic world we observe in everyday life.
How does decoherence occur?
Decoherence occurs when a quantum system interacts with its surrounding environment, such as through collisions with particles or absorption of photons. This interaction causes the system to become entangled with the environment, making it difficult to isolate and observe the system's quantum properties.
What are the effects of decoherence?
The effects of decoherence include the loss of coherence and superposition, which are fundamental properties of quantum systems. It also leads to the emergence of classical behavior, making it difficult to observe and manipulate quantum systems.
How is decoherence different from measurement in quantum mechanics?
Decoherence is a natural process that occurs due to the interaction between a quantum system and its environment, while measurement in quantum mechanics is a deliberate act of observation by an external observer. Decoherence can lead to the collapse of a quantum state, but measurement is required to determine the specific outcome of that collapse.
How is decoherence being studied and applied in current research?
Decoherence is being studied through experiments in various fields such as quantum computing, quantum information processing, and quantum mechanics. It is also being applied in the development of technologies such as quantum sensors and quantum cryptography. Additionally, decoherence is being used to better understand the role of the environment in the behavior of quantum systems.
