Transistor in saturation region problem
In summary, when a transistor is in saturation mode, the collector-base junction is forward biased, causing the emitter-injected minority carriers to flow from the n-type material to the p-type material. This results in a net current flow from the collector to the base, contrary to the direction of the electric field. This is due to the large number of minority carriers present in the base region, similar to the behavior of a photovoltaic diode. The physics of this behavior is described by the Ebers-Moll model and the emitter reverse saturation current is also known as IEO.
Danish_Khatri
I am having great trouble in understanding the operation of transistor in saturation region.
This is how I understand the working of a transistor:
In a bipolar junction transistor the width of base is very small therefore very small number of carrier undergo recombination inside base, whereas, the rest of carriers get conducted through collector because of the polarity of voltage applied across collector-base junction. In this case, electrons flow towards collector because collector is at higher potential than the base.
However, when the transistor is being operated in saturation region collector-base junction is forward biased i.e. collector is at lower potential than the base and if this is the case how do the electron flow towards the collector??
Please help me understand this concept as I am experiencing great frustration not being able to understand it.
Are you seeking an explanation in terms of the physics of the transistor or in terms of the electronics functionality?
I m doing electrical engineering so I would prefer to understand it in terms of electronic functionality. Yet, I would be glad to know its physical functionality too.
From a circuit point of view saturation is rather like a water tap (faucet). There comes a point where you cannot turn in on any further.
Look at the CE connection in the attachment.
The transistor is biased just 'on'. That is its base is about 0.7 volts above the emitter.
This causes a collector current Ic= beta times the base current to flow in the collector resistor RL.
By ohms law there is a voltage across RL = IcRL.
This sets the collector voltage at a point equal to the supply voltage minus the voltage across RL.
If we now increase the base bias so that more base current flows this cause an increase in collector current. This increases the voltage across RL. Since the votlage across RL is now greater the collector voltage falls. The collector voltage always 'takes up the difference'.
Obviously the collector cannot fall below zero volts as we crank up the base drive. In fact it falls to about 0.2 - 0.4 volts above the emitter. At this point the transistor is said to be bottomed or in saturation or saturated. Further increase in base drive beyond this poion t will not result in increased collector current.
That concludes the case for the electronic engineer.
Also worth mentioning is that a bjt is really 2 bjt devices in 1. The 1st device is the normal "right side up" device, the 2nd is upside down. Transistor action works both ways. When saturated, the b-c junction is forward biased. So holes from the base region enter the collector, and electrons from the collector enter the base. In addition e- from the emitter transit through the base, some recombine there, most go on into the collector.
There is more than 1 thing happening here. The b-e & the b-c junctions are both forward biased for the saturated state. In cutoff or active state, the b-c junction is reverse biased. So analyzing the device in terms of charge transit must be done with this in mind. In the saturated state, an additional component of charge motion is present. Did this help?
Claude
Both are wonderful explanations for the operation of transistor in saturation mode but since, I am still a beginner I am going to take time to grasp it.
What I am still confused about is the direction of current flow when the transistor is in saturation mode. in active mode, when the collector base junction is reverse biased the direction of conventional current is from collector to base in an npn transistor. However, recalling the operation of diode, the direction of conventional current during forward bias should be from p type to n type side. Does the same thing happen in transistor when it is in saturation mode? if not, how is it possible that current is flowing from n type to p type material and the junction is still forward biased?
The same way that it does in a photo-diode (in photovoltaic mode), by having non thermal-equilibrium minority carrier concentrations. In a photovoltaic cell the diode is forward biased (anode +, cathode -) yet the current flows from cathode to anode!
In BJT saturation mode there are very high excess minority carrier levels in the base resulting in a lot of diffusion current across the CB junction. Yes it’s true that the drift current is in the opposite direction, but the diffusion component is larger and so the net current is actually opposite to the electric field direction. Remember that diffusion current is driven by concentration gradient (and thermal motion) so yes it is possible for diffusion current to flow counter to the electric field!
In summary. In the case of the photovoltaic diode it is because of the large number of optically generated minority carriers. In the case of the CB junction of a saturated BJT it is because of the large number of emitter-injected minority carriers.
I hope that helps.
This is a simple explanation of the physics of the subject.
http://www.ecse.rpi.edu/~schubert/Course-ECSE-6290%20SDM-2/1%20BJT-3%20Advanced%20topics.pdf
If you want more. google 'Ebers-Moll'
You should note that the 'emitter reverse saturation current' is also called IEO and is taken with the collector open circuit.
To explain how current flows in a reverse biased c-b junction, consider the following. The device is npn. The b-e junction is not biased, and the c-b jcn is reverse biased. Only a small reverse leakage current is present, Ics, aka Ico or Iceo. Ib = 0.
But when the b-e jcn is forward biased, Ib > 0, and holes, h+, move from base to emitter, and electrons, e-, move from emitter towards the base region. Simple enough. But the base region is intentionally made to be very very thin. Also, the base region has light doping density, with the emitter having heavy doping density.
The h+ from the base recombine in the emitter region or in the depletion zone at the edge. The e- from the emitter incur very little recombination in the base, because nearly all pass right through the base region and continue into the collector where they are "collected". The emitter "emits" electrons towards the base which is forward biased wrt the emitter. But the electric field in the reverse biased c-b jcn points in the same direction as that in the forward biased b-e jcn. An e- entering the base from the emitter encounters a strong attractive force yanking it into the collector before it has a chance to recombine with a hole in the base.
Although the c-b jcn is reverse biased it conducts a lot of current. This is because the carriers, e- here, are not provided by the collector region, but by the emitter region. The collector collects the e- that the emitter emitted a moment ago. Outside charge carriers are being injected into the collector. Thus the equation of transistor action is:
Ic = alpha*Ie.
Transistor action occurs because the base is so thin and lightly doped, that charges get swept into the collector before they have a chance to recombine in the base. A good signal level bjt has an alpha value of around 0.98 to 0.998, and a power bjt around 0.95 to 0.98, sometimes as low as 0.90.
In a diode, the n & p regions provide all the charge carriers. So a reverse biased jcn has low current since carriers are in short supply. But in a reversed c-b jcn in a bjt, the b-e jcn is forward biased. Charges carriers are abundent in the base & emitter. But the e- emitted from the emitter pass through the base being so thin, and get collected by the collector due to the electric field. In a nutshell that is transistor action. One more point is worth mentioning. "Current" is merely charge motion. In a bjt, charges move through 1 region, cross a junction, and then move through another region. Thus "collector current" is charge motion, most of which consists of charge carriers injected into the collector from a different location. So e- moving through the emitter region, constitute emitter current Ie. A moment later, nearly all of those e- are moving through the collector region. They now constitute collector current Ic. In other words, what we call "Ic", was only a moment ago called "Ie". Ic=alpha*Ie. Pretty straight forward. Have I helped or made things worse?
Claude
One thing to observe is that saturation occurs at different collector currents for different supply voltages.
Taking my example from before if we suddenly doubled the supply voltage we would still maintain the same collector current and hence the same voltage drop across RL.
Hence the voltage at the collector would now be 2Vsupply - VRL. We would have to nearly double the current in RL to drive the transistor into saturation, assuming we did not exceed the current capacity of the transistor.
These explanations were really helpful. Thanks a lot for giving me so much time writing the answers. God Bless you all.
Keep at it, you'll get there.
And don't hesitate to ask lots of questions.
Dear Studiot,
let me repeat the question here
I have been given a basic electronics project for design of a single stage common emitter amplifier. The problem is that this the first time I am going to carry out such an assignment and have no idea how to start. I do not know how to make choice for the resistors and I need help in this regards.
Very much thank you for this explanation ...
Glad it helped someone else and welcome to Physics Forums.
I hope that helps.
Thank you uart for your explanation.
FAQ: Transistor in saturation region problem
1) What is the saturation region in a transistor?
The saturation region in a transistor is a state where the transistor is fully turned on and the current flowing through it is at its maximum. In this region, the voltage between the base and the emitter is less than the voltage between the collector and the emitter, allowing for a large amount of current to flow.
2) How does a transistor enter the saturation region?
A transistor enters the saturation region when the voltage between the base and the emitter is greater than the threshold voltage, which is typically around 0.7V for a silicon transistor. This allows for a large amount of current to flow from the collector to the emitter, making the transistor fully turned on.
3) What is the significance of the saturation region in a transistor circuit?
The saturation region is important in a transistor circuit because it allows for the transistor to act as an amplifier or switch. In the saturation region, the transistor can provide a large current gain, which is necessary for amplification. It also allows for the transistor to be fully turned on, making it useful as a switch in digital circuits.
4) How can you calculate the collector current in the saturation region?
The collector current in the saturation region can be calculated using the equation: IC = βIB, where β is the current gain of the transistor and IB is the base current. This equation assumes that the base current is large enough to fully turn on the transistor.
5) What are some potential problems that can occur in the saturation region of a transistor?
Some potential problems that can occur in the saturation region of a transistor include overheating and breakdown. When a transistor is in saturation, it can dissipate a large amount of power, which can cause it to overheat. Additionally, if the base current is too high, it can cause the transistor to enter the breakdown region, where it can be permanently damaged.
