Anamitra
- 621
Is it meaningful to talk of relative velocity between two moving points at a distance in curved space-time? This interesting issue came up in the course of discussion of the thread "Curved Space-time and the Speed of Light".I remember Dalespam giving some formidable logic with a very good example[Thread :#25]The content of the thread #19 was also very interesting (and similar in some sense). I would like the to repeat the basic idea that could prevent relative velocity from becoming a valid concept in the framework of general relativity :
To calculate relative velocity we need to subtract one velocity vector from another at a distance.For this we have to bring the vectors to a common point by parallel transport. We could keep one vector fixed[let us call this the first vector]and parallel transport the other [the second vector]to the position of the first vector. Now parallel transport may be performed along several routes. If different routes lead to different directions of the second vector in the final position, relative velocity does not have a unique meaning and becomes mathematically unacceptable.Again I refer to the illustration in thread #25.
My queries: 1)If two points(or observers) are moving relative to each other in curved space-time how should the motion of one point appear to the other physically? Is such observation meaningless from the physical point of view if we are unable to interpret it in the existing framework of mathematics?
2)On Parallel transport: We start with a familiar example on parallel transport:
A vector e on a globe at point A on the equator is directed to the north along a line of longitude.We parallel transport the vector first along the line of longitude until we reach the north pole N and then (keeping it parallel to itself) drag it along another meridian to the equator.Then (keeping the direction there) subsequently transport it along the equator(moving the vector paralley) until we return to point A. Then we notice that the parallel-transported vector along a closed circuit does not return as the same vector; instead, it has another orientation. "
It is interesting to observe that the route followed in parallel transport [in the above example and the example cited by Dalespam in thread #25]involves sharp bends or joints where derivatives cannot be defined. Incidentally from the mathematical point of view the definition of parallel transport[Wald:page 34] involves derivatives[covariant derivatives to state accurately] and we know very well that derivatives do not exist at sharp junction.Can we entertain the above examples to refute the concept of relative velocity in curved space time, considering the fact that such examples use paths containing sharp junctions?
Interestingly one may perform the above examples by " rounding off" the north pole edge and the ambiguity will be removed.One may draw "smooth(closed) curves" on "curved surfaces" and carry out examples of parallel transport. The vectors will coincide in their initial and final positions![If one is to perform an experiment by drawing smooth curves on a basket ball he should take care to move the vector parallely without bothering about what angle it is making with the curve after the motion has been started.Angles should be noted only at the initial and the final points/stages.]
If the arguments in point (2) are correct I may conclude that
1)The concept of relative velocity is mathematically consistent in relation to the notion of curved space time.
2)The ideas portrayed in the thread "Curved Space-time and the Speed of Light" are correct.
