How Does the Principle of Equivalence Lead to Gravity Curving Space?
The discussion centers on the principle of equivalence and its connection to gravity curving space, particularly in the context of General Relativity (GR). It highlights that while the equivalence principle suggests that gravity and acceleration are indistinguishable locally, it does not fully determine GR, as other theories also comply with this principle. The rotating disc thought experiment is used to illustrate how acceleration alters the geometry of space-time, leading to non-Euclidean results. Participants debate the implications of measurements taken by different observers, emphasizing the effects of length contraction and the relativity of measurements in different frames. Overall, the conversation underscores the complexity of linking the equivalence principle to the geometric nature of gravity in GR.
Goldbeetle
I understand the principle of equivalence (e.g. thought-experiments with lifts etc), but how come that from it one can arrive at the result that gravity acts curving the space? Where can I find a step-by-step reasoning illustrating this link?
I'm not sure if the equivalence principle can be used alone to develop GR, or similar geometrical space-time theories of gravity. But it does mean that such a theory is required if the EP is to be automatically incorporated. Free-fall is unique to the gravitational field so an energy based (dynamic) theory would not do it.
After Einstein had his crucial insight that a freely-falling body experiences no force, it still took nearly ten years to find the formulation that gave GR.
This link might help
http://www.lightandmatter.com/html_books/genrel/ch01/ch01.html#Section1.5
If you want to know how Equivalence Principle(EP) leads to General Relativity(GR) you must first consider two important points related to Special Relativity(SP).
The first is that SR made an end to absolute character of time which used to keep it apart from the continuum composed of the three space dimensions and made it possible to establish the new concept of space-time in which the laws of S R are not more than the geometrical properties of flat four-dimensional continuum.
The second point is that SR is not complete ,it can not be applied in gravitational field and accelerated frames.
Now if we understand EPwell ,we will be able to know that the fact that gravitation is equivalent to acceleration implies that all small regions of space-time are similar because by using suitable frame SR is applicable, the only characteristic property of space-time in a point is the difference between the suitable frame in the point and the suitable frame in neighboring points. This properties of space-time is similar to the properties of Curved Four-dimensional Space which was studied many years before by mathematicians maybe without thinking that it could be applied in reality one day.
This similarity between Curved 4-d space and Space-time led Einstien to the idea that gravitation is the geometrical properties of space-time.
His second step would be to relate the geometrical properties of space-time to the material properties ,in this step he used other facts and assumptions for which this is not the appropriate
place.
I think a crucial part of his intuitive reasoning is illustrated in the his analysis of the rotating disc. He noticed that an observer riding on the edge of the disc would measure the circumference to be greater than 2*pi*r because the observer's rulers would be length contracted. He concludes than in the pseudo-gravitational field of the the rotating disc the geometry of space and time can no longer be described by Euclidean principles that assume flat space. Since his equivalence principle assumes that a real gravitational field and a pseudo gravitational field due to artificial acceleration are indistinguishable locally, it seems reasonable to make the connection that a real gravitational field will distort space and time into a non-Euclidean (i.e. non-flat) form. There is of course a lot more to GR than that, but I think that was one step in the reasoning process on the way.
Would he measure the radius using radar distance or ruler distance?
What you are arguing here cannot be explained even by GR.Actually, there is a different theory called the Einstein-Cartan theory which explains this by extending GR to include spin angular momentum.
http://www.einstein-online.info/spotlights/geometry_force
The equivalence principle does not determine GR completely. Other theories such as Newtonian gravity and Nordstrom's second theory also obey an equivalence principle, and can be recast as geometry. The recasting of Newton was done by Cartan, while the recasting of Nordstrom was done by Einstein and Fokker. Nordstrom's theory was actually the first relativistic theory of gravitation, and closely studied by Einstein, who had himself critiqued Nordstrom's first, unsuccessful theory in a way useful to Nordstrom.
Einstein originally described this thought experiment in terms of the radius being measured by ruler distance which gives the result of the circumference (C) to radius (R) ratio as C/R = 2*pi/sqrt(1-v^2/c^2).
If the the thought experiment is done using ruler distance for the circumference and radar distance for the radius then the ratio would be C/R = 2*pi/(1-v^2/c^2) which contrasts even more with the Euclidean flat space expectation.
The circumference can also be measured using radar distance (and a series of mirrors around the circumference) and this would give the same result as the ruler measurement of the circumference.
Very Few people know that the thought experiment of the rotating disc although used by Einstien himself to show the idea that acceleration changes the geometry of space is obviously incorrect .
The experiment compares the observation of two observers one of them see that the disc is static and the geometry of the disc is Euclidean,to the other observer the disc is rotating, but I can prove that the geometry of the disc will be Euclidean also.
Let us suppose that the observer to whom the disc is rotating draw a shape in his static ground in such a way that it coincides with the circumference of the rotating disc
it is obvious that the length of the two circles is the same and the length of the radios is
not affected as all of us agree so the geometry is the same.
The effect of acceleration on the geometry of space-time is true but can not be proved in this case of rotating disc.The principle of Equivalence is helpful in this purpose.
The experiment compares the observation of two observers one of them see that the disc is static and the geometry of the disc is Euclidean,...
This is not correct. The observer that sees the disc as static is obviously riding on the disc and whether they use radar or ruler measurements they will not obtain a Euclidean result of 2*pi for the ratio circumference length to the radius length.
I also want someone who believe in the rotating disc experiment to tell me which of the two observers will notice non-Eculidean geometry if the experiment is done in a region of zero gravitational field (the question is also valid in gravitational field but I want to simplify the problem )
please read what I said again an tell me what is incorrect . I did not speak about radar and ruler at all and when I say the observer to whom the disc is static is the same as saying riding ion the disc but that is not the point of discussion we are discussing the case of the other observer
Mueiz said:
Let us suppose that the observer to whom the disc is rotating draw a shape in his static ground in such a way that it coincides with the circumference of the rotating disc it is obvious that the length of the two circles is the same and the length of the radios is not affected as all of us agree so the geometry is the same.
It is certainly not obvious. Why would you think that the length would be the same?
Clearly something either has to be squeezed or stretched for a rotating disk wrt a stationary disk.
Say we have a unit circle with radius r=1 when at rest. Now we rotate it with an angular velocity w, what do you say the radar distance of r is?
Dalespam ...they are the same because the two circle coincide. we suppose that the observer outside the disc should draw the static circle to coincide with the rotating one ,is it not obvious that if two objects coincide they must have the same length and all other quantities .
I know that we must be careful when using the word (obvious) in relativity and modern physics . but you cannot by any relativistic or non- relativistic analysis say that if two object have the same shape being in the same place in the same order can give different measurement to any quantity for the same observer.
Mueiz said:
Dalespam ...they are the same because the two circle coincide. ... is it not obvious that if two objects coincide they must have the same length and all other quantities .
Not only is it not obvious, it is wrong. Have you never heard of length contraction? Even for a single object (which coincides with itself) different frames will give different lengths.
I know that we must be careful when using the word (obvious) in relativity and modern physics . but you cannot by any relativistic or non- relativistic analysis to say that if two object have the same shape being in the same place in the same order can give different measurement to any quantity for the same observer.
length contraction is two observers to the same rod ...our discussion is one observer to two coinciding objects one static the other rotating. even in length contraction zero length is absolute
you can also see a good book by Ohanian called ''Einstein's Mistakes'' for more details
Here you wish to discuss the point of view of both observers. You are stating that the observer rotating with the disc and the non rotating observer off the disc, both see the geometry as Euclidean.
Now you only want to discuss the point of view of the non rotating observer. For what it is worth I agree that the inertial observer that is not on the disc, will measure the circumference of the rotating disc to be the same as the circumference of a non rotating circle drawn on the floor with the same radius. To the inertial non rotating observer the geometry is Euclidean everywhere, however, to the rotating observer on the disc the geometry is non Euclidean as I stated in a previous post.
As stated above, it is the rotating observer riding on the disc that sees the geometry as non Euclidean and this applies in a zero gravitational field far from any significant gravitational sources.
Here is a numerical example that might help. Assume we have a drawn on the floor in a non rotating frame with a radius of 10 metres. Inside this circle is a disk rotating with a tangential rim velocity of 0.866c (gamma factor =2), with the same radius. If lit from above, by a even light source, the disc casts a shadow that superimposes neatly on the circle.
Measurements in the rotating frame:
The circumference of the circle according to a non rotating observer is 2*pi*10 = 62.8318 meters.
The circumference of the rotating disc can be measured by placing a mark on the rim. The velocity of the mark can be measured (0.866c) and then the non rotating observer can time how long it takes for the mark to complete one full circle and return to the starting point. It takes 72.552 seconds for the mark to travel on full circle. The observer then calculates the distance traveled by the mark to be 72.552*0.866 = 62.8318 meters which is the same as the circumference of the non rotating circle.
So nothing unusual or non Euclidean as far as the non rotating observer is concerned.
Measurements in the non-rotating frame:
The circumference of the disc rim according to the rotating observer is 2*2*pi*10 = 125.6637 meters whether he uses rulers or radar measurements. The circumference of the disc Cd has the relationship Cd = 4*pi*r and so is non Euclidean.
Now the observer on the rotating disc can measure the circumference of the non rotating circle on the floor by placing a mark on the circle. He sees that the mark has a relative velocity of 0.866c. He time how long it takes for the mark to return to its starting point. It takes 36.2760 seconds. The rotating observer calculates that the circumference of the non rotating circle is 36.2760*0.866 = 31.4160 meters so as far as the rotating observer is concerned, the circumference of the non rotating circle is non Euclidean too but this time the circumference of the circle Cc has the relationship Cc = pi*r. They would also notice that the circumference of the non rotating circle is gamma^2 shorter than the circumference of the rotating disc, even though the disc rim and the circle are superimposed on each other.
This might seem a little odd. The rotating observer on the disc has the right to consider himself stationary and he considers marks on the circle to be going past him at 0.866c so he would expect the measured length of the circle to be length contracted by a factor of gamma and the length contraction of gamma^2 might be a bit of a surprise. This is because everything is a little weird in the rotating frame. The speed of light is different in different directions, clocks can not be synchronised all the way around the rim using the Einstein clock synchronisation procedure. Light does not travel in straight lines. If a dweller on the disc decided that the disc was not in fact stationary but rotating in real terms, it would be like a Copernican revolution for the disc dwellers and everything would look so much simpler. All of sudden they would see that the circumference of the disc is the same as the circumference of the circle it is superimposed on, that the speed of light is the same in all directions, that light travels in straight lines and that clocks can be synchronised all the way around the rim. However, the high priests of the rotating disc community would probably put him under house arrest for such subversive suggestions. :-p
No, only you are discussing that. yuiop, who brought up the rotating observer, specifically mentioned "an observer riding on the edge of the disk" from the very first post on this topic in this thread.
Only non-inertial observers such as the one on the edge of the disk see the equivalent gravitational fields, so it is essential to include such an observer and not restrict yourself to inertial observers. Such a limited discussion as you propose would not even be relevant to the OP's question on the equivalence principle.
Ok yuiob and others.. I want to say something about length contraction and its application in this case of rotating disc and let you then agree or disagree that the high priests are right this time if they put Copernic or even Einstein under house arrest when he offers such suggestions.
Length contraction means to put your ruler beside a static object and to mark its two ends in the same time according to your clock and then do the same when the object is in motion relative to you .you will surely find a difference.
In the case of the disc it is the same only that the shape is circle and I suggest that we should use circular ruler ...say we have many different-sizes rulers and we measure any circle circumference by seeing which of them coincide with the object .this is the definition of the process of measurement whether the object is static or moving .
What I said -maybe not clearly- and seems to you as a contradiction is that the question is not whether the measurement of the two observers are the same or not but whether both observers see Eucildean geometry or not
And I show that we agree that one of them does see Eucildean geometry .Then if we look to the other- be the static or the moving not important- if he use the circular ruler which is static to him then the ruler has the same radios of the disc and the same circumference then the ruler is static to him as the ruler used by the other observer is static to him then why suppose that one of them should have nonEuicldean geometry
The mistake in your calculations is that you simplify the problem too much when you assume that the radios of the disc will not be affected by rotation, rotation is not like linear perpendicular motion if special relativity is applicable in this way then the space must be Euicldean .This contradiction appears in your results that you have special relativity validity in the same time with nonEuicldean geometry . this is the mistake you and Einstein made .
My aim from this discussion is to show that the rotating disc is not the correct way to introduce the idea of nonEuicldean geometry relationship with acceleration and not more
a correct way is to use Equivalence Principle as I stated in the beginning of this discussion.
Another problem with the disc experiment is that it contradict one of the basis of General Relativity in that if it done in a region of zero gravitational field there should be preferred frame of reference in which the geometry is Euicldean and all other rotating relative to it (static to themselves of course) frames should seek other geometry ...
What hypocrisy! :smile:
Mueiz said:
Then if we look to the other ... if he use the circular ruler which is static to him then the ruler has the same radios of the disc and the same circumference then the ruler is static to him as the ruler used by the other observer is static to him then why suppose that one of them should have nonEuicldean geometry
Because the rotating observer cannot construct such a ruler while under rotation, and if he were to build such a ruler in an inertial condition and then spin it up to be at rest with himself then it would necessarily be materially stressed and no longer correctly measure distances in any frame.
Then the rotating observer must take you with his left hand and Einstein with his right hand
to the rotating disc to show you that the geometry therein is Euicldean:smile:
Nice imagery. Completely irrelevant and unconvincing, but very well said.
If a round ruler such as you describe is impossible to build then the Euclidean measurement you suggest is also not possible.
Mueiz's analysis of the rotating disk is incorrect. For this example, the relevant notion of curvature of space is given by a purely spatial metric determined by radar measurements carried out by comoving observers. Here is my derivation of the spatial metric: http://www.lightandmatter.com/html_b...tml#Section3.4 (subsection 3.4.4)
The following FAQ entry and its references may be helpful.
FAQ: How is Ehrenfest's paradox resolved?
As described in [Einstein 1916], the relativistic rotating disk was an example that was influential in leading Einstein to describe gravity in terms of curved spacetime. Einstein writes:
"In a space which is free of gravitational fields we introduce a Galilean system of reference K (x,y,z,t), and also a system of coordinates K' (x',y',z',t') in uniform rotation relative to K. Let the origins of both systems, as well as their axes of Z, permanently coincide. We shall show that for a space-time measurement in the system K' the above definition of the physical meaning of lengths and times cannot be maintained. For reasons of symmetry it is clear that a circle around the origin in the X, Y plane of K may at the same time be regarded as a circle in the X', Y' plane of K'. We suppose that the circumference and diameter of this circle have been measured with a unit measure infinitely small compared with the radius, and that we have the quotient of the two results. If this experiment were performed with a measuring-rod at rest relative to the Galilean system K, the quotient would be π. With a measuring-rod at rest relative to K', the quotient would be greater than π. This is readily understood if we envisage the whole process of measuring from the stationary'' system K, and take into consideration that the measuring-rod applied to the periphery undergoes a Lorentzian contraction, while the one applied along the radius does not."
Einstein's friend Paul Ehrenfest posed the following paradox [Ehrenfest 1909]. Suppose that observer L, in the lab frame, measures the radius of a rigid disk to be r when the disk is at rest, and r' when the disk is spinning. L can also measure the corresponding circumferences C and C'. (When we speak of "radius" and "circumference," we are making use of the fact that the disk is rigid, so that after it spins up it is still a circle. It doesn't fly apart or contort itself like a potato chip.) Because L is in an inertial frame, the spatial geometry does not appear non-Euclidean according to measurements carried out with his meter sticks, and therefore the Euclidean relations C=2πr and C'=2πr' both hold. The disk is rigid, so it doesn't stretch centrifugally, and the only reason for r to differ from r' would be a Lorentz contraction. But the radial lines are perpendicular to their own motion, so they have no length contraction, r=r', implying C=C'. The outer edge of the disk, however, is everywhere tangent to its own direction of motion, so it is Lorentz contracted, and therefore C' is less than C.
The resolution of the paradox is that it rests on the incorrect assumption that a rigid disk can be made to rotate. If a perfectly rigid disk was initially not rotating, one would have to distort it in order to set it into rotation, because once it was rotating its outer edge would no longer have a length equal to 2π times its radius. Therefore if the disk is perfectly rigid, it can never be set into rotation.
Thorough modern analyses are available,[Grøn 1975,Dieks 2009] and in particular it is not controversial that, as claimed in [Einstein 1916], C/r is measured to be *greater* than 2π by an observer in the rotating frame.
A common source of confusion in discussions of Ehrenfest's paradox is the role of the rigid meter-sticks, since it is not clear whether sufficiently rigid meter-sticks can exist, or how to verify that they have remained rigid. This confusion can be avoided simply by replacing the meter-stick measurements with radar measurements.
In connection with these discussions, one often hears about the concept of a Born-rigid object, meaning an object that is subject to prearranged external forces in such a way that observers moving with the object find local, internal radar distances between points on the object to remain constant.[Born 1909] It is kinematically impossible to impart an angular acceleration to a Born-rigid disk,[Grøn 1975] and therefore it is also impossible to do so for any plane figure that encloses a finite area, since it would enclose a disk. The reason for this is that in order to maintain Born-rigidity, the torques would have to be applied simultaneously at all points on the perimeter of the area, but Einstein synchronization (i.e., synchronization by radar) is not transitive in a rotating frame; that is, if A is synchronized with B, and B with C, then C will not be synchronized with A if the triangle ABC encloses a nonzero area and is rotating. (This does not make it impossible to manipulate the rigid meter-sticks as described in [Einstein 1916], since they can be one-dimensional, and therefore need not enclose any area.)
A. Einstein, "The foundation of the general theory of relativity," Annalen der Physik, 49 (1916) 769; translation by Perret and Jeffery available in an appendix to the book at http://www.lightandmatter.com/genrel/ (PDF version)
P. Ehrenfest, Gleichförmige Rotation starrer Körper und Relativitätstheorie, Z. Phys. 10 (1909) 918, http://en.wikisource.org/wiki/Uniform_Rotation_of_Rigid_Bodies_and_the_Theory_of_Relativity
Born, "The theory of the rigid electron in relativistic kinematics." Annalen der Physik 30 (1909) 1–56.
Ø. Grøn, Relativistic description of a rotating disk, Am. J. Phys. 43 (1975) 869
Dieks, "Space, Time, and Coordinates in a Rotating World," in Rizzi and Ruggiero, ed., Relativity in Rotating Frames: Relativistic Physics in Rotating Reference Frames, 2009, http://www.phys.uu.nl/igg/dieks/rotation.pdf
Note: In the discussions below, all measurements are done far from any gravitational source. The lab frame or non-rotating observer/frame will be used consistently to mean the inertial frame in which the observers do not feel or measure any proper acceleration and any Sagnac type devices will indicate there is no rotation in the lab frame. The rotating or disc frame/observer will be used consistently to refer to an observer that is at rest with the disc that rotating relative to the lab frame. Observers at rest in the rotating frame (except at the very centre) will feel and measure proper acceleration and Sagnac type devices will indicate they are rotating. There is no ambiguity between rotating and non-rotating and whether something is rotating or not is not observer dependent. Rotation is not a point of view, it is absolute.
There is a difference. Take two short rulers that have the same length when alongside and at rest wrt each other. Place one ruler on the rotating disc rim and compare it a ruler that remains at rest in the lab frame. The lab observer will measure the ruler on the disc to be shorter than the ruler in the lab frame by the gamma factor. It will take more of these length contracted rulers in the rotating frame to extend all the way around the rim of the disc. In the earlier example, assuming rulers of length 1 meter, the observer in the rotating frame requires over 125 of these rulers layed end to end in the rotating frame to extend all the way around the disc, while the observer in the lab frame only needs about 63 identical rulers layed end to end, to go all the way around the non rotating circle in the lab frame. We can prove these rulers have identical proper length by getting the observer in the lab frame to time how long it takes light to travel from one end of his ruler to a mirror on the other end and back again. He tosses the ruler to the observer on the rotating disc and while the ruler is at rest in the rotating frame, he carries out a similar radar measurement and confirms he gets the same time. He can then lay this calibrated ruler alongside anyone of his rulers at rest in the disc frame and confirm that it is the same length.
This can be proved wrong. If I take a non rotating circular ruler with a circumference of about 125 meters when at rest in the lab frame, it will have a radius of about 20 meters. If we spin the circular ruler up to a tangential velocity of 0.866c and take care not stretch the ruler, then it will shrink to a radius of about 10 meters in the lab frame. The lab observer will now measure the circumference of the circular ruler to be about 63 meters. An observer that that remains on the circular ruler will initially measure the circumference of the ruler to be about 125 meters before it is spun up, and after it has been spun up he will still measure the total circumference of the circular ruler to be 125 meters, because the short rulers he uses to measure the circumference will have length contracted to the same extent as the circular ring so he sees no change in total circumference. He will however agree with the lab observer that the radius is half what is was before it was spun up. The observer on the spinning circular ruler claims the proper length of the circular ruler is 125 meters and the radius is 10 meters. (Non Euclidean) This spinning ring will now be superimposed with a non spinning ring with a radius of 10 meters and a circumference of 63 meters, so a spinning ring and a non spinning ring of the same radius do not have the same circumferential proper length.
I have clearly stated in several previous threads that the lab observer sees Euclidean geometry and the rotating observer on the disc does not see Euclidean geometry. I do not understand why you think there is any ambiguity here.
Mueiz said:
And I show that we agree that one of them does see Eucildean geometry .Then if we look to the other- be the static or the moving not important- if he use the circular ruler which is static to him then the ruler has the same radios of the disc and the same circumference then the ruler is static to him as the ruler used by the other observer is static to him then why suppose that one of them should have nonEuicldean geometry.
See above.
It is you who is simplifying too much. You have not attempted to calculate any measurements, but just making guesses on casual intuition without given the problem as much thought as it requires. The radius is affected by rotation. While the ruler length of the rotating disc radius is the same as that of the non rotating circle in the lab, the radar length length of the radius is shorter by a factor of the gamma in the disc frame. The radar length and the ruler length of the disc radius are different in the disc frame. This is the equivalence principle at work! In a real gravitational field the radar distance and ruler distance differ over extended distances. This is a sure sign of curved non-Euclidean geometry.
Mueiz said:
My aim from this discussion is to show that the rotating disc is not the correct way to introduce the idea of nonEuicldean geometry relationship with acceleration and not more a correct way is to use Equivalence Principle as I stated in the beginning of this discussion.
See above.
Not quite sure what you are getting at here. As I mentioned earlier, I agree there is preferred frame in a zero gravitational field where geometry is Euclidean and all other frames rotating relative to it are non-Euclidean and in this sense, rotation is absolute. This is not a contradiction of SR which states there is no preferred frame as far as motion in a straight line is concerned, but this does not apply to angular motion where a rotating observer feels proper acceleration while an inertial non rotating observer does not. As far as being a contradiction to GR I think you wrong. The metric for a Schwarzschild black hole (non rotating) is fundementally different from the metric of a Kerr black hole (rotating). The geometry around a Kerr black hole is not just simply the point of view of an observer orbiting around a Schwarzschild black hole.
The book gives Ohanian's opinion on p. 232: "The basic error of Einstein's and his contemporaries was that they failed to recognize that the use of accelerated rulers is an improper way to measure length." Ohanian's opinion is not universally shared. For example, see Rindler's Relativity: Special, General, and Cosmological, p. 199, which states "The metric of the lattice...represents a curved 3-space..."
Neither Ohanian nor Rindler is wrong, and they are not really contradicting each other. Ohanian is simply stating a distaste for a certain method of measurement, but Rindler doesn't share Ohanian's distaste.
Firstly;if we want to apply length contraction in the case of rotating disc this will not be simply by gama factors except if we do that locally(in very small region) because any point in the disc has a different relative velocity ,and the result of the summation of such local calculation is not equal to that of linear motion as your calculation assume.
secondly;There is no preferred frame of reference in the absence of matter and gravitational field according to general relativity all frames are Euclidean in this case you can make sure of this if you apply Einstein Field Equation ... the metric is absolute because both stress-energy tensor(matter) and Riemann curvature (gravitational field) equal zero and so cannot be affected by frames of reference(if there any thing else that can change the metric please tell me soon and I will change may mind:smile:) ..then what is the property of one frame that could make it different...if so the claimed results of rotating disc experiment contradict this by assuming that one of the frames should gain Euclidean geometry ,all the other not.
This is the sum of what I said in this discussion
Thank you I acknowledge that I did not read the book just someone told me that it contain details of what i am trying to show i will seach for it...this is just a mistake like that of Einstein-Yuiob rotating disc:redface:
  • · Replies 44 ·
  • · Replies 48 ·
  • · Replies 36 ·
  • · Replies 36 ·
  • · Replies 41 ·
