Exploring Newton's "G" in Relativity
  • Thread starter Hebob80
  • Tags
    Relativity
In summary, Newton's theory of gravity is still used in modern physics, but it is an approximation to the more accurate Einstein Field Equations. The equations that use G are approximations, but they are all correct in the sense that they use the same physical constant, G, no matter what the equation is.
Hebob80
The Big "G"
I've been studying relativity for a bit over 2 years now, in this time I've come across Newton's G in various equations. For example: http://en.wikipedia.org/wiki/Gravitational_time_dilation#Outside_a_non-rotating_sphere
to = tf sqrt(1 - 2GM/rc2)
It was my understanding that Einstein disproved Newton's concept of gravity, so I'm really wondering - what am I not understanding that is making it okay for us to use Newton's G?
As far as I know, G was derived by:
F= G ( m1 m2 / r2)
or
G = Fr2 / m1 m2
Which, I thought was an inaccurate statement...
Someone help
Hi Hebob80, welcome to PF!
Newton's theory of gravity is known to work very well in many situations. One of the prerequisites of any new theory is that it must reduce to the old theory in all situations where the old theory is know to work. This means that GR must reduce to Newtonian gravity in the classical limit. So it is not surprising to see G in the equations of GR.
My 8th grade algebra teacher told me that pi was 7/22, and I don't mean to be rude, but by your argument, that works very well in many situations as well; however, it does nothing towards proving it is a valid variable to use. If you were to say that the equations that use G were only approximations, I would find that acceptable, is this the case?
No, the equations that use G are not only approximations to Newtonian physics.
I don't understand your argument. Pi is a mathematical constant which can be calculated to any arbitrary degree of precision using only math. What does it have to do with G which is a physical constant whose value can only be determined by experiment?
If G were not in the Einstein Field Equations then how would you be able to get Poisson's equation in the classical limit?
I hope he or she said 22/7, not 7/22!:smile: Still wrong, of course.
Yes, Newton's equations are only approximations to the GR equations, but it's the same G in all of them.
For example, according to Newton the acceleration due to gravity at a distance r from the centre of a planet of mass M is
[tex]\frac{GM}{r^2}[/tex]​
but in GR the equivalent formula is
[tex]\frac{GM}{r^2 \cdot \sqrt{1 - \frac{2GM}{rc^2}}}[/tex]​
although in this case r is not "ruler distance" but equals [itex]C/2\pi[/itex] where C is the circumference of a circle drawn round the planet at that height. (This is for the idealised case of a non-rotating spherically symmetric planet; it gets more complicated for real planets that are ellipsoidal and rotating.)
The two formulas are approximately the same provided r is very large compared with 2GM/c2 (which is tiny for planets and many stars).
Then, perhaps, I was not clear enough in my original question, let me make this as simple as possible:
If:
F = G ( m1 m2 / r2 ) <--- this is wrong
G = Fr2 / m1 m2 <--- this is wrong
G <--- this is wrong
Then:
Every equation that uses G is wrong.
No?
Those equations are not wrong. They have been tested for centuries and have been confirmed many times with a wealth of empirical data.
You seem to think that new theories disprove existing theories in domains where they have been experimentally verified. They do not. New theories extend or generalize existing theories to new domains where they have not been verified or where they have been contradicted. But it is absolutely essential the new theories agree with previous theories wherever the previous theories have been verified.
Ah HA! Thank you for helping me with this... although I don't like it in the least :biggrin:
I can assure you, I'll be back with more questions!
I have wondered about this myself. It appears from DrGreg's equations that the greater the mass and density, the greater the discrepancy between Newton and GR. And since the value of G is usually obtained by torsion balance experiments, would it be true that the measured value would only be inaccurate (within limits of the equipment and method of course) if the test masses were extremely dense and massive?
For this equation, do the measurements of distance or mass need to be in any particular unit?
No, but the value of G will change depending upon the units of distance and mass.
Exactly. If you measure distance in metres, acceleration in m/s2 and mass in kg, then G has the value G = 6.67428 × 10−11 m3 kg−1 s−2, but in other units it would have different value e.g. 0.8650 cm3 g−1 hr−2.
Relativists often choose units so that G = c = 1.
TurtleMeister brings up a good point. If Newton's equations and Einstein's equations disagree at some point, any point, doesn't that by default make one of them incorrect?
No, it makes Newton's equations a specific limit of the EFE. Solutions to Newton's equations are also solutions to Einstein's. They agree.
Should we avoid discussing plane waves simply because they are a specific case of Maxwell's equations rather than the full general Maxwell equations?
What if the test masses were small and less dense, would they not still be influenced by other surrounding objects more dense and massive like the earth.
Maybe I should rephrase my question. In post #5 DrGreg gave a GR equivalent to Newton's equation for acceleration. And as he stated, the two are approximately equal while r is very large compared with 2GM/c2. However, if r is not very large compared with 2GM/c2, then the GR equation gives the more accurate result. My question is, does the same also apply to the Newtonian equation used for the determination of the value of G (G = Fr2 / m1 m2)? For example, if I want to do a torsion balance experiment using very massive test masses of very great density, what GR equivalent equation must I use in place of the Newtonian equation in order to obtain the most accurate result?
The earth? No. the whole point of using a torsion balance is to cancel the influence of the Earth's gravitational field. Other surrounding objects? Yes. But the distances between the test masses and the attractor mass is usually very short, making the influence of surrounding objects insignificant. But this really has nothing to do with what we're talking about.
Sorry for enquireing you might like to have a look at wikis big G
The accuracy of the measured value of G has increased only modestly since the original Cavendish experiment. G is quite difficult to measure, as gravity is much weaker than other fundamental forces, and an experimental apparatus cannot be separated from the gravitational influence of other bodies.
I just took for granted that other bodies included the Earth but it's obviously wrong.
Specific limit? Can you clarify what, exactly this means?
They are based on different assumptions:
In Einstein's second paper on relativity in 1905, he explicitly concludes
"Radiation carries inertia between emitting and absorbing bodies". It is important that not only does something receive a "kick" from the momentum of the energy, but the internal inertia (i.e., the inertial mass) of the body is actually increased. (from mathpages.com)
A note from Newton's Principles definition #4 in 1687 conflict with Einstein:
Impressed Force - This force conflicts in the action only; and remains no longer in the body when the action is over.
If you take the EFE and solve them for the situation where you have a central point mass and a test mass which is far away from the central mass and moving slowly then you get Newton's equations.
This is similar to how Coulomb's law is a limit of Maxwell's equations for a single point charge which is stationary. Maxwell's equations hold in general. Coulomb's law is not wrong, it is simply a solution of Maxwell's equations which only holds in certain circumstances.
Related to Exploring Newton's "G" in Relativity
What is the "G" in Newton's equation?
The "G" in Newton's equation refers to the gravitational constant, which is a universal constant that determines the strength of the gravitational force between two objects.
How does Newton's equation relate to relativity?
In relativity, Newton's equation is modified to account for the curvature of space-time caused by massive objects. This is known as Einstein's theory of general relativity, which provides a more accurate description of gravity on a larger scale.
What are some practical applications of exploring "G" in relativity?
Understanding the effects of gravity and the relationship between space and time has many practical applications, such as predicting the motion of planets and satellites, designing space missions, and developing technologies like GPS.
Can Newton's equation and relativity be reconciled?
While Newton's equation and relativity provide different explanations for gravity, they can be reconciled in certain situations. For example, Newton's equation is a good approximation for objects moving at slow speeds and in weak gravitational fields.
What are some ongoing research and advancements in exploring "G" in relativity?
Scientists are constantly researching and testing Einstein's theory of general relativity, looking for ways to improve our understanding of gravity and its effects on the universe. They are also exploring the possibility of a unified theory that can reconcile both Newton's and Einstein's theories.
  • Astronomy and Astrophysics
10K
10K
