Voltage Drop in Electric Circuits
In summary, the voltage in an electric circuit only drops across a resistor because the electrons in the current are moving at a constant velocity.
horsecandy911
My textbook tells me that the voltage in an electric circuit only drops across a resistor. I don't quite understand this; doesn't this suggest that the electrons in the current are moving at a constant velocity? I would think that, since they are moving under the influence of an electrostatic force, they are being accelerated (and then slowing down when they encounter resistors). In that case, the potential energy would be being converted to kinetic energy, and the potential of points in the circuit would drop steadily as we moved along the circuit.
This raises the wider question of the velocity of electrons in a circuit. If they are moving at constant velocity, how do they get started moving? Is there a brief moment when the circuit is completed during which everything gets accelerated? Thanks for your help.
If you have a perfect conductor, then the tiniest of electric fields will set charges moving. Since the electric field is tiny, the voltage drop is tiny. So there is practically no voltage drop across a perfect conductor.
I guess this is why all the real physicists look so shocked and dismayed when I use the water analogy to explain electricity...
They ain't no acceleration of electrons. In fact moving electrons are not really what makes electricity. It's the electrostatic field, which moves at the speed of light. Electrons drift around in the field tending in the direction of negative current flow. Here's a quickie description I found googling "speed of electrons in a wire":
http://www.Newton.dep.anl.gov/askasci/phy99/phy99092.htm
As to voltage drop. One needs to have a circuit to measure voltage. Lacking any other element, the voltmeter itself closes the circuit -- actually it measures current flow across a very high resistance and extrapolates that to be voltage. Aside from super-conductors, everything -- wire included -- has a finite resistance, which limits current flow and thus "creates" a voltage difference.
Electrons DO move at a constant DRFIT velocity...a slow speed when a constant voltage is applied. There IS a tiny "acceleration" as electrons are stripped from their orbitals by a newly applied emf (voltage) and begin to DRIFT slowly.
see here: http://en.wikipedia.org/wiki/Drift_velocity
but when an electron moves at one end of a circuit another begins to move at the other end almost the speed of light...so its SEEMS fast...like one car at the back of a train begins to move almost instantaneously as one at the front of the train begins to move...but the overall velcoity of the train is SLOW by comparison.
In a resistor the electrons are more tightly bound to their nucleus than in a conductor...so in a resistor it takes more voltage to break them free and keep them moving...So if a constant voltage is applied,say, to a piece of wood and a copper rod, very different currents will flow.
In fact in the stationary state, when there has been for a long time a time-independent voltage drop across a resistance, the current is also time-independent, and the electrons move at constant velocity.
Of course, there acts the electrostatic force on the moving electrons, but there's also a constant friction force which just compensates this electrostatic force. That's the microscopic picture of resistance!
Related to Voltage Drop in Electric Circuits
1. What is voltage drop in electric circuits?
Voltage drop in electric circuits refers to the decrease in electrical potential energy that occurs as current flows through a circuit. It is measured in volts and is caused by the resistance of the circuit components.
2. How is voltage drop calculated?
Voltage drop is calculated using Ohm's Law, which states that voltage drop (V) is equal to current (I) multiplied by resistance (R). This can be represented by the equation V = IR. The voltage drop can also be calculated by measuring the voltage at different points in a circuit and finding the difference between them.
3. What causes voltage drop in electric circuits?
Voltage drop is caused by the resistance of the circuit components. As current flows through a component, some of the electrical energy is converted into heat, causing a decrease in voltage. The longer the circuit or the higher the resistance, the greater the voltage drop.
4. How does voltage drop affect the performance of a circuit?
Voltage drop can affect the performance of a circuit by reducing the amount of voltage available to power the circuit. This can result in decreased efficiency and functionality of the circuit. In extreme cases, voltage drop can cause devices to malfunction or not work at all.
5. How can voltage drop be reduced?
There are a few ways to reduce voltage drop in electric circuits. One way is to use thicker or shorter wires with lower resistance. Another way is to use components with lower resistance, such as copper instead of aluminum. Additionally, minimizing the distance between the power source and the load can also reduce voltage drop.
  • Electromagnetism
