Pressure at points on the same horizontal plane
In summary, pressure is the same at points on the same horizontal plane, even if the height of the fluid is different at each point. This is because pressure in fluids is caused by gravity and is transferred in all directions. Even if there are variations in depth or height within the fluid, the pressure will still be the same at points on the same horizontal plane. This is because the pressure does not need to act sideways to produce a pressure to the side.
Misr
385
As you know,pressure is the same at points on the same horizontal plane
Okay,suppose two points A,B in a fluid are on the same horizontal plane
[PLAIN]http://img197.imageshack.us/img197/1977/unledfhe.jpg
the pressure on both points is the same
but at A pressure=h2*ρg
pressure at B=h1ρg
and h1 is not equal to h2 as you see
could you explain this
Pressure is rho g h right? So the water in the middle has pressure applied on it from atmosphere as well as the water above it, while the water to the left only has pressure applied to it by the water above it. Pressure does not spread laterally.
If you push on a piece of paper, the paper around the paper you pushed on feels some of the pressure exerted too. This is not the case with water. Each molecule is very small and has a lot of freedom to move. Imagine that each water molecule in the middle has some force exerted on it because of pressure. You think that this force might cause those molecules to push on molecules to the left and right, but this is not the case.
A simpler explanation is that the pressure in this case is caused by gravity, and gravity doesn't exert a force sideways.
Actually, fluids - liquids and gases - transfer whatever pressure applied to them in all directions...downwards, sideways, upwards...
The atmospheric pressure out on the yard is 1 atm...when you snick back in the porch with a ceiling only 10 feet high...is the pressure a lot less? No.
If the pressure in A was not the same as the pressure in B...you could dive to the bottom of the ocean, carve a hole on a wall and a bit of ceiling to snick under and all of a sudden have minimal pressure? I don't think so.
so what is the pressure in the case above?
so the extra pressure at point B is transferred to point A until they are equal in pressure??
but the pressure is much less at high mountains
The pressures at A and B are the same.
Whether pressure is less at high mountains has not much to do with the problem at hand...you are talking about pressure between two points at the same depth inside a fluid.
But, yes, pressure at high mountains is less because such point is less deep measuring from the top of the atmosphere, down.
Ok what makes pressure the same at A and B?
Gravity doesn't need to "act sideways" to produce a pressure to the side any more than a crank lever needs to be pushed in the same direction as the direction you want a force to be applied. Fluid will flow from a high pressure region to a low pressure region - in any direction. If you did the experiment out in zero g, the pressures would all be equal everywhere in the container (cabin pressure or more if you squeeze on a sealed container). Back on Earth, there is a hydrostatic effect that causes the pressure at any level to increase with depth. This pressure will be acting in all directions so fluid will move (microscopically) from B towards A until equilibrium is reached. Then the pressure will be the same over all that particular level. If you were, suddenly, to add another metre of liquid to the vertical tube, there would be a slight delay before the wave of increased pressure traveled from B to A and equilibrium was again reached. (Speed of sound in the liquid)
True.
Not true.
pressure at B=h1ρg
True (neglecting atmospheric pressure).
h1 is the depth below an open surface, but h2 is not. The upper surface of the container above A exerts a downward pressure that must be added to h2*ρg to get the actual pressure at A. The net effect is that the pressure is equal at A and B.
Yeah,that's great and easy to imagine
thanks very much
Related to Pressure at points on the same horizontal plane
1. What is pressure at points on the same horizontal plane?
Pressure at points on the same horizontal plane refers to the force exerted by a fluid on a surface at different points that are on the same horizontal level. This pressure is caused by the weight of the fluid above the surface and is measured in units of force per unit area, such as pounds per square inch (psi) or pascals (Pa).
2. How does pressure at points on the same horizontal plane change with depth?
The pressure at points on the same horizontal plane increases with depth due to the weight of the fluid above. This is known as hydrostatic pressure and is calculated by multiplying the height of the fluid column by the density of the fluid and the acceleration due to gravity.
3. What is the relationship between pressure and area at points on the same horizontal plane?
At points on the same horizontal plane, pressure and area have an inverse relationship. This means that as the area of the surface increases, the pressure decreases and vice versa. This relationship is known as Pascal's principle and is the basis for hydraulic systems.
4. How is pressure at points on the same horizontal plane affected by the shape of the container?
The shape of the container does not affect the pressure at points on the same horizontal plane, as long as the depth and density of the fluid remain constant. This is because the pressure is determined by the weight of the fluid above the surface and is independent of the shape of the container.
5. How does pressure at points on the same horizontal plane differ from pressure at points on different vertical levels?
The pressure at points on the same horizontal plane is equal, while the pressure at points on different vertical levels will vary. This is because the weight of the fluid above each point will be different, resulting in different pressures. The difference between these pressures is known as hydrostatic head.
13K
