Does anyone make a small high temperature and high pressure pump?
A researcher is seeking a small high-temperature and high-pressure pump for a test rig simulating plant conditions with heat transfer fluids, specifically a eutectic mix of biphenyl and diphenyl oxide. The required specifications include operation up to 500C and 40 bar, with a pumping rate of 2-5 liters per minute. The test loop will use 1-2 liters of fluid and is constructed from Swagelok stainless steel piping. Despite contacting several companies, the researcher has not found a suitable pump and is considering a piston arrangement as an alternative. Recommendations for brands available on Amazon have been noted.
Jack_O
Hello, I have recently started work as a researcher at a university investigating heat transfer fluids (HTF). One of the tasks is to build a pumping test rig to simulate plant conditions. One of the fluids being tested is a eutectic mix of biphenyl and diphenyl oxide which is similar in density and viscosity to water but boils at 257C.
Testing will be up to 460C at 35 bar so ideally I want to find a pump that can run up to 500C at 40 bar. The test loop would be fairly small with around 1-2l of HTF in the loop, pressurised before running the pump so it only needs to push the htf around the loop, a pumping rate of 2-5l per minute would be fine. I have contacted several companies so far without luck.
The rig will be made of parts from swagelok, either 1/4" or 1/2" stainless steel piping. If I cannot find a pump I may end up using some kind of piston arrangement to pump the HTF back and forth without a loop.
I think a positive displacement piston pump made from steel or stainless should be fine for your application.
They list several brands at amazon.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
