Experiment about Discharging Batteries
The discussion focuses on monitoring the true electromotive force (emf) of a battery while discharging it at a constant current. Participants note that the voltage across the battery decreases during discharge, questioning whether this voltage difference remains constant. It is suggested that the terminal voltage reflects the true voltage delivered at that current, while the open-circuit voltage may take time to stabilize after disconnection. The impact of internal resistance and temperature on measurements is also highlighted, with recommendations to conduct tests under load for more accurate data. Overall, the consensus is to gather data while the battery is loaded and to explore the effects of voltage bounce when unloaded.
johnsmith12345
Right now I'm doing an experiment for my EE about battery capacity. How would I be able to monitor the battery's true emf while discharging the battery at a constant current?
Also, when I connect the battery in a circuit and discharge it at a constant current, I notice that the voltage across the battery decreases. Since I am discharging at a constant current, will this difference in voltage from when its in a circuit and the true emf be constant?
Connect a voltmeter?
Right.
Which difference? The measured voltage IS the true voltage the battery delivers at that current.
Hmm, well, can you interrupt the discharging process for the measurements?
That's what I thought - but doesn't the open circuit voltage for a battery take a bit to "relax" after the load is disconnected, like a hysteresis effect ... possibly altering the discharge curve? It would depend on the battery of course...
I also thought that the early measurements could be used to work out the internal resistance and, after that, the open-circuit voltage would just get calculated.
However, the internal resistance may change during discharge - it would certainly be affected by temperature.
If the load resistor was very large compared with the internal resistance, then the loaded voltage would be close to the open-circuit...
I would be surprised to see any effect on the scale of a human intervention (~1s), but that would be easy to test.
I was thinking that repeatedly switching the circuit may be different enough from a continuous discharge, over the entire discharge time, to affect the shape of the curve - but like you say: easy to test.
We don't know how accurate things are either... any effect could be small compared with the sensitivity of the instruments - especially seeing the battery in question is quite high tech.
@ johnsmith
That would be interesting to test. I never tried it with an exotic battery.
Published curves are with battery under load.
Tinkering with automobile batteries, indeed there is a time delay when you release the load. Voltage bounces back to 12.6 in about a minute.
I've seen car batteries that'd indicate 12.6 volts but were too run down to illuminate even the dome lamp.
So i think you should take your data with battery loaded.
Then experiment with the voltage 'bounce' when unloaded from various states of discharge.
  • · Replies 16 ·
