Solving Polynomial: x^(3/2) + (1+x^3)^(1/2)
  • Thread starter Thread starter jessawells
    Polynomial
To solve the equation x^(3/2) + (1+x^3)^(1/2), the user seeks to simplify it to a single term of x. The challenge lies in expanding the square root correctly without setting the equation to zero. A suggestion is made to isolate one term and square both sides, but the user clarifies that they are not looking for a solution equal to zero. Additionally, there is a reminder about the importance of not double posting in the forum. The discussion emphasizes the need for clarity in problem-solving approaches.
jessawells
hi,
can anyone show me how to solve this:
i want to get it to so that there's only 1 term of x. but i don't know how to expand the squared root. any help is appreciated.
You have
\sqrt{x^3} + \sqrt{1+x^3} =0
put one member on the other side, square both side.
no, that's the problem. i don't have it "=0". i just have one to simplify the expression.
First of all, please do not double post. People will help you if you post once. Secondly, I have already responded to this post in another section.
Incidentally, that was here. That thread has been closed.
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up will act downwards and maximum static friction will act downwards Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
