What causes people to age differently?
  • Thread starter spaced-out
  • Tags
    Age
In summary: The first man has aged more because on his journey, he moved more and experienced more events. The second man has aged less because he did not move as much and did not experience as many events.
spaced-out
Here is a simple example:
A man moves inertially between two clocks in inertial coordinate
system A. He is age 20 when he starts.
Man
(20) -->
[0]-------------Frame A-----------[?]
Clock````````````````````````Clock
Man
---------------------------------(23.67) -->
[?]-------------Frame A----------[3.80]
Clock```````````````````````` Clock
The A-frame observers note that his aging rate is 96.47 percent
compared to the observers' clock times.
A second man moves faster but still inertially between the same two
clocks in inertial coordinate system A. He is also age 20 when he
starts.
Man
(20) -->
Clock`````````````````````````Clock
Man
---------------------------------(21.37) -->
[?]-------------Frame A----------[1.70]
The A-frame observers note that his aging rate is only 80.87 percent
The question is What causes the men age differently? I know that
the math gives it, but what is the physics behind the math?
(Remember the epicycles!)
The men have taken different paths through space-time, and a different amount of time passes on these paths, just as a different numbers of miles would pass if they had taken different paths through ordinary space.
To Nugatory: Yes, I realize that the times are different, but I was asking about the different aging rates. Could you please address this? (In case you are saying that merely taking different path in space-time causes the two men to age differently, then I ask how.)
They age differently because the time is different, just a car that drives a longer distance experiences more wear and tear because it's covered more miles.
Time is defined (google for the Einstein quote "Time is what a clock measures") by observing the progressive change of physical systems: Sand falling through an hourglass, the movement of the hands of a clock, the graying of my hair, the rate of spoilage of food or decay of atoms in a sample of radioactive material, they're all measuring the passage of time. And so is the aging of a biological organism - you'll age more on ten-year journey than on a five-year journey.
So your question comes down to asking why, other than that the math says so, should different paths through space-time have different "lengths" in time. There's really no deeper answer than that that's how the universe we live in works.
That sounds like a non-answer, but it's what you find at the bottom of any scientific explanation of "why" something happens. The math can explain how things makes sense and predict the results of experiments, but it doesn't really answer the "why?" question. We chose the math (in this case, the definition of the space-time interval that we use to calculate the time passing on different paths through spacetime) to match what the universe was doing long before we started constructing mathematical descriptions.
Your question is akin to asking: Yes, I know that apples fall because of gravity but what causes apples to fall? I know that the math gives us that apples fall but what causes them to fall? (Remember the epicycles!)
As he and others said the answer is what it is, note there are different perspectives for "why" this differential aging happens.
Consider this is all about geometry, and the "tools" for geometric measurements are not just rulers and protractors, but also clocks.
Here's a different way of thinking about it that is possibly helpful.
Your original question involved thinking of proper time [itex]\tau[/itex] (the amount of aging) as a function of coordinate time [itex]t[/itex]. It's mysterious why velocity should affect [itex]\tau[/itex].
A different way of thinking about it reverses the dependent versus independent variable. Pick a coordinate system. A coordinate system associates four numbers: [itex]x, y, z, t[/itex] with each event (point in space and time). If you're traveling, then you can describe your path by 4 functions [itex]x(\tau), y(\tau), z(\tau), t(\tau)[/itex], which together give your coordinates as a function of the proper time [itex]\tau[/itex] showing on your watch. If you start at [itex]\tau = 0[/itex] and travel until [itex]\tau = 100[/itex] seconds, then clearly where you end up [itex]\langle x(100), y(100), z(100), t(100)\rangle[/itex] depends on the "velocity" [itex]\langle\frac{dx}{d\tau}, \frac{dy}{d\tau}, \frac{dz}{d\tau}, \frac{dt}{d\tau}\rangle[/itex]
So in these terms, your question amounts to: Why is [itex]\frac{dt}{d\tau} > 1[/itex]?
Coordinate time in special relativity is treated in much the same way that any other spatial coordinate is. There is no particular reason to think that [itex]\frac{dt}{d\tau}[/itex] should always be the same, for all travelers, any more than [itex]\frac{dx}{d\tau}[/itex] is.
I like to look at it the other way:
The men don't age differently. Using the car analogy, it is just as incorrect to say/ask why the men aged differently as why their cars traveled at different speeds when they were instead going the same speed for different distances. In fact, in both examples, they behave exactly the same, they just do it for different times/distances.
The wording of the question is a reflection of not accepting what time dilation is.
To Russ: Just a quick question: What exactly, in yoiur opinion, is "time dilation" physically speaking? Thanks!
Time dilation is the differing rates of the passage of time that exist between different reference frames.
russ_watters said:
Time dilation is the differing rates of the passage of time that exist in different reference frames.
No, I don't agree with that wording. There is no difference between "the rates of passage of time" in different frames. All inertial frames are equivalent in Special Relativity.
Poor word choice: I've swapped "in" for "between".
I am aware of 2 sorts of time dilation, one physical, the other a mere point of view. The physical is when people born at the same time end up having different ages. The pt-of-view is when observers see each other's clocks "running slow" - this cannot be physical because 2 clocks cannot both run slower. Which one, if either, are you guys talking about? (I will have to reply in the am) Thanks!
Likes richengle
There is only one time dilation(unless you separate SR and GR), but those are two different implications: both very real. And the only significant difference between the cases is that if the two clocks are in different reference frames, there may be disagreement about how to compare them.
No clock 'runs slow'. This point has been emphasized for you several times. It is possible for two observers to each see another's clock running slow, and this is a 'real' observation, that is not paradoxical precisely because no clocks run slow. What differential aging (twin scenario shows) is not that one clock ran slow, but that total time along different histories (world lines) between a pair of events can be different - just as two curves connecting points on a paper can be different lengths.
What you can say about time dilation is that it is observer dependent (not that isn't 'real'). For example, the fact that a muon created in the upper atmosphere usually reaches the ground is a fact that everyone agrees on. However, for an Earth frame, the reason is time dilation of the muon 'decay clock'. For a muon observer, it is the Earth clock that is seen to run slow, and the reason the muon reaches the ground is extreme contraction of the thickness of the atmosphere. Thus, you can say that (in contrast to differential aging), that time dilation is a frame or observer dependent explanation of a particular phenomenon. But the phenomenon associated with time dilation in one frame is 'real' and agreed on by other frames.
[edit: In the case of differential aging (twins), because two clocks begin and end co-located, the explanation in all frames involves time dilation. However, different frames will disagree on the details; they only agree on the final result.]
On the contrary, it is possible for both clocks to run slower, and this time dilation is physical.
As for how this apparent impossibility can come about... You have to consider very carefully exactly what it means to say that a clock "is running slow", and also remember the relativity of simultaneity.
Let's say that A flies past B at .6c, and as they pass one another they both zero their clocks and start them running. At some later time, A looks at his stopwatch and sees that it reads ten seconds. A knows that at that moment B is six light-seconds away, and therefore that light leaving B at that moment will reach A's eyes when his watch reads 16 seconds. Thus, when A sees his clock read 16 seconds and at the same time sees B's clock reading 8 seconds, he correctly concludes that B's clock is running 20% slow - at the same time that his clock read 10 seconds B's clock read 8 seconds.
But we also have to consider the relativity of simultaneity. The two events "A's clock reads 10 seconds" and "B's clock reads 8 seconds" only happen at the same time in a frame in which A is at rest. In a frame in which B is at rest, the event "B's clock reads 8 seconds" happens at the same time as the event "A's clock reads 6.4 seconds", and B will correctly conclude that A's clock is running 20% slow.
There is nothing illusory about this effect - you might want to look up the cosmic ray muon lifetime measurements in the FAQ at the top of this subforum.
Maybe this helps...
Consider an odometer (a wheel with a counter, counting the number of rotations).
On a plane, it functions the same way (turning once for traveling one circumference of the wheel)... no matter which path on the plane you take from point A to point B. The reading of the elapsed distance depends on the path taken from A to B.
Consider a clock (a light clock [my video below]). In Minkowski spacetime, it functions the same way (ticking once for an inertial timelike-displacement of 1 second)... no matter which worldline in spacetime you take from event A to event B. The reading of the elapsed time depends on the worldline taken between A and B.
So, follow the ticking of a light-clock,
as in my old video [ http://physics.syr.edu/courses/modules/LIGHTCONE/LightClock/#twins ],
gives you a mechanism for how time elapses along each worldline.
(Motivation for why this light-clock works as it does...
http://physics.syr.edu/courses/modules/LIGHTCONE/LightClock/#circularlightclocks
from here, scroll upwards to see the development of these light-clocks [with reference to Michelson-Morley].)
(The bottom of that page has links to a paper describing the light-clocks.)
Why not?
"Physical" means "of or pertaining to physics". So time dilation is certainly physical. It is also experimentally measurable, but it is frame variant meaning that different frames will disagree.
Btw, I agree completely with Nugatory's answer. They age differently because the take different paths through spacetime. It is no different than accumulating more mileage when taking different paths in space. Hopefully you understand intuitively that different paths through space accumulate different distances? Why should it be different with spacetime?
This odometer case is not a proper analogy. An odometer relates to tires which
constantly contact a road. What do the Triplets contact that affects
their ages? They merely move inertially through space. And who
cares if they move different distances or in different directions;
how can that cause people to age differently?
(Triplets = No Accelerations)
Triplet Case: When Mary & Bill meet in passing, both are the same age, and Bill goes on to meet Barry when they are the same age. Barry then catches up with Mary, and they have different ages. This is a direct comparison of aging and shows that people who move differently age differently. Barry's and Bill's paths relative to Mary are the same - same speeds - same distances traveled - same space-time paths.
Odometer: How long tires contact a road
(distance is all that counts, direction is irrelevant)
Triplets: How fast each person moves through space
(speed is relevant, distance not as much, direction none)
The light-clock's mechanism is determined by the light-rays which make contact with ("reflect off") the inertial mirrors... which follow the geodesics of Minkowski spacetime. (There is a presumption that a standard unit of time has been established... that is, the directions on how to build an identical light-clock for another inertial observer. That's part of the development.) [I restricted the discussion of the light-clock to "piecewise-inertial" for simplicity... or else one should make the displacements infinitesimal (as one would do for an arc-length in space for an arbitrary curve) and then take a limit.]
The construction does match the calculation using the formulas from special relativity.
The point of the road analogy is that there is no physical cause for why going 100 kilometers east and then 100 kilometers north gets you to the same place as if you went 141 kilometers to the northeast. It's the geometry of space. Thinking in terms of what kind of interaction between the road and the tires resulted in one trip being longer than the other is pointless. The only facts that are important are: (1) The geometric fact (the pythagorean theorem) that a diagonal connecting opposite points of a square has a different length than the sum of the two sides, and (2) the engineering fact that the odometer was specifically created to be accurately measure the distance traveled. There is a physical explanation for why an odometer is an accurate way to measure distances (or inaccurate), but the explanation for why the two sides of a square have a longer length, in sum, than the diagonal is not physical, but geometric. It's a geometric fact that two different paths that connect the same starting point and ending point can have different lengths.
There's a similar thing going on in Special Relativity, but it has to do with the geometry of spacetime, rather than space. In the same way that a path through space has an associated real number, the length of that path, a slower-than-light path through spacetime has an associated real number, the proper time for that path. It's a fact about the geometry of spacetime that two different paths connecting the same starting point and ending point can have different "lengths" (where the appropriate measure of "length" for a slower-than-light path is proper time). The fact that a clock shows more elapsed time for one trip than for the other is due to (1) the geometry of spacetime determines that one trip has a longer proper time than the other, and (2) clocks are constructed so that they accurately measure proper time, in the same way that odometers are constructed so that they accurately measure distance. If clocks didn't show the effect, then it would not be an accurate clock. (And if you use, say, a sundial as your clock, then it probably won't show that effect.)
It doesn't show that, at all. Take a look at the following picture, for an analogy with Euclidean geometry.
We assume that we have a network of one-way roads that cross each other at various angles. Each road has associated mile markers: Every mile along each road, there is a marker with a number on it, and the number on one marker is 1 more than the number on the last.
Now, we have three roads, as shown in the picture. Assume that the picture is oriented with North at the top of the picture. One road runs east-west from point A to point C. Another road runs from point A to point B. A third road runs from point B to point C. There are two different ways to go from point A to point C. You can take the straight path, or you can go via point B. The elapsed distance, according to the change in the numbers shown on the mile markers, is 8 if you go the "straight" way, or is 10 if you go the "bent" way.
There are two different types of explanations for why the two paths have different lengths: (1) geometric, and (2) physical.
The geometric explanation is: Two different paths connecting the same points A and B can have different lengths. The mileage markers accurately reflect those different lengths.
The physical explanation is: East-west roads have accurate mileage markers: one marker per mile. But roads that veer off in a direction other than east-west have compressed markers: the markers are too close together by a factor of |sec(θ)|, where θ is the angle of the road relative to the preferred east-west direction.
The physical explanation sounds pretty silly when we're talking about Euclidean geometry, but SR time dilation has the same two types of explanation: geometric or physical.
There is no math or geometry in the given triplet case, and there must be a real or physical cause for people who are at one time the same age to later have different ages. For ex., one person has a rare disease that makes him age differently. Aging is physical. Different aging is physical. Sorry, but them's the facts. The question is What is the physical cause here? It cannot be acceleration. It cannot be clock synchronization or relative simultaneity. It cannot be geometry or have anything to do with space-time paths. None of these can possibly have any effect on aging. And it cannot have anything to do with relative motion. I am just stating the obvious facts of the case. What else can I do?? To Stevendaryl: Do you not agree that people who were once the same age suddenly had different ages in the given example? If not, then why? This ex. has been read by many, and no one has ever said that it did not show this. That's why I am asking.
spaced-out said:
... The question is What is the physical cause here? ... It cannot be geometry or have anything to do with space-time paths.
Uh ... really ? That's exactly like saying that two cars that take different paths can't show different distances because they took different paths, it must be some other reason. Your point of view doesn't make sense.
When you come up against a belief that flies so utterly in the face of established science, it is not a good idea to start off reaching different conclusions and stating them as correct but rather to start off with the assumption that you have made a mistake somewhere and try to find out where it is. If you have NOT made a mistake you will find the flaw in the established science, but that is very unlikely to happen. If you start off thinking that you have overturned established science you are likely to just end up embarrassed.
So let's talk about what the physical cause is, instead of what it is not.
Every biological organism ages as time passes, and the more time that passes, the more the organism ages. In this respect, aging is no different than any other time-dependent physical process.
And, because the two travelers have taken different paths through space-time, a different amount of time has passed for them. It would be far more amazing if they didn't age differently - then we'd have to look for a physical cause for why one traveler's metabolism reacted differently to the passage of time than the other.
This is a very minor objection. An odometer measures the distance along a path in space, a clock measures the interval along a path in spacetime. The fact that each device uses a different method to measure the different quantity is hardly surprising or objectionable since the point is the geometry, not the mechanism of measuring the geometry.
(1) The distance along two different paths in space is different (an odometer measures that).
(2) The interval along two different paths in spacetime is also different (a clock measures that).
Why do you find (2) surprising but not (1)?
spaced-out said:
The question is What is the physical cause here? ... It cannot be geometry or have anything to do with space-time paths. None of these can possibly have any effect on aging.
Why not?
Fundamentally, there isn't any reason to expect them to age the same.
Suppose you drive from new york to chicago, directly. And you note the distance is 700 miles, say for example. And your friend drives from new york to Albany, Kentucky, and then from Albany Kentucky, to Chicago, and travels say 1250 miles.
You might ask "why is the distance shorter when you drive directly with no detours" and the answer is geometry. That's the same answer to the analogous question in the twin paradox. There's one curious twist - the traveller who travels "in a straight line" on a space-time diagram ages t he most, rather than the least.
You can, in fact, if you draw a space-time diagram, see that this question is an exact analogy for the twin paradox question. If you're not familiar with drawing space-time diagrams, I'm afraid I can only go into the briefest description. I'll just say that the basic idea is that you can represent time on a diagram with a spatial dimension - the simplest example of this is the "timeline". And you can represent space/distance on a piece of paper too, this is called a map. If you combine the two, by representing both time and space on one piece of paper, you get a space-time diagram. For instance, you might represent time by height on the paper, and spatial distance by the width.
Suppose you ask, instead of "why is the distance longer", you ask instead "why is the rate of distance" different in the trip. You'd probably get a blank look - what do you mean by the "rate of distance". And how would you measure it?
You probably think that "the rate of time" is an obvious concept, but it is, in fact, not obvious that there even is such a thing.
If I had to guess, I'd guess that you are implicitly beliving in some sort of "absolute time", without perhaps even knowing what the words "absolute time" mean, and then using this absolute time to compute a "rate of time". But there isn't any such "absolute time" in relativity, so you can't compute a "rate of time" in this manner. As far as I know there isn't any other manner to compute a "rate of time", so your question doesn't have a short answer as it's phrased.
What you are basically saying here is that you simply refuse to accept Relativity's explanation that it is time itself that is different in different frames, right? Even though you agree that clocks show the difference?
There certainly is. The differential aging is a geometric effect.
Why do you say that? That's completely wrong. Of course it has something to do with space-time paths. Different paths have different associated amounts of proper time.
  • #31
Two people took two different paths through spacetime. One path was "longer" than the other, as measured using the spacetime metric. The twin who took that path aged more.
In space, there is nothing surprising about the fact that one person might take an hour to go from point A to point B, while another person takes two hours. Even though they both started at A, and both ended at B, one aged more along the way than the other. That's not surprising.
The same thing is true of spacetime, where A and B are not points in space, but points in spacetime. There is more than one way to get from A to B and the two different ways have different proper times.
  • #32
First, I think it would be good to know what causes people to age. Have you thought about that, spaced-out?
  • #33
Of course there is maths and geometry. There always is. The problem here is that you haven't really thought about your experiment. If they are all going at the same velocity, they'll never catch up to each other. If they all cross at different times they must have gone at different speeds, which means different paths through spacetime.
The only other option is that they all started in different places, and then you have relativity of simultaneity to worry about (not to mention gynaecological complexity).
I agree with the analysis of others above - your mental model of relativity still has absolute simultaneity or absolute time in it. That's why it appears not to make sense to you.
  • #34
What math is needed?
There is no such thing (physically-speaking) as "a path thru space-time" because space-time is math (geometry).
When two people born at the same time and place later have different ages, then something much more than mere math is afoot. And the only thing that differed about my people was their speeds.
  • #35
Is the difference flying from NY to Rome via Zurich, versus direct just math, not physics? Why is path through space physics but not spacetime? In fact, these different flights are also paths through spacetime.
