How torque is converted into ampere in a generator
In summary: Maxwell's equations govern the conversion of torque into amps and this is done through the use of control circuits.
RohitRmB
24
As i have read on the internet that during synchronization the prime mover connected to the turbine produces a little over than required power to keep the turbine cum generator assembly moving at the synchronous speed that is regulated by the grid frequency (In India its 50Hz). As the generator is synchronized, the speed of the turbine cum generator will remain equal to 3000 RPM (As per frequency of 50Hz). Now if more steam is admitted to the turbine, then the torque produced by the turbine will increase but the speed of the turbine cum generator assembly cannot increase beyond synchronous speed, so that increased torque gets converted into amps.
Now my question is, i am not able to understand the physics behind how this conversion of torque into amps takes place at fundamental level.
So kindly help me in this.:smile:
Power generation is not really my field; however if your background is in physics, then this is all driven by Maxwell's equations. The turbine spins the generator at the specified frequency to match the grid as you state. So to change the power output the magnetic flux is controlled through the control circuits. This is an easy job these days as the computers that control the process quickly adjust the settings such that any change in input power matches the necessary output power while keeping the speed constant. In days before the computer control, operators did this by hand controls and must have been very good at their jobs!
Think of it as riding a bike. When you are on level ground you are required a certain amount of leg energy to keep a constant pedal cadence thus speed; going downhill required much less leg energy to keep the speed constant; while going uphill required much more leg energy to keep the same speed. The fields of the generator are adjusted in a similar way as you adjust your leg muscles to produce more power.
Thanks for your reply but I want to know actually which equations govern this conversion and how the generator actually knows that now speed should be constant and further addition of energy from the turbine (torque) is now to be converted to amps?
Sorry but please bear with my childish question.
Related to How torque is converted into ampere in a generator
1. How is torque converted into ampere in a generator?
Torque is converted into ampere in a generator through the principle of electromagnetic induction. When a conductor, such as a wire, is rotated in a magnetic field, it creates an electric current, which is measured in amperes.
2. Is there a specific formula for converting torque into ampere in a generator?
Yes, the formula for converting torque into ampere in a generator is I = (E/phi) x N, where I is the current in amperes, E is the electromotive force in volts, phi is the magnetic flux in webers, and N is the number of turns in the coil.
3. How does the amount of torque affect the amount of amperage generated?
The amount of torque directly affects the amount of amperage generated in a generator. The higher the torque, the stronger the rotational force, which results in a higher electric current being produced.
4. Can the efficiency of a generator impact the conversion of torque into ampere?
Yes, the efficiency of a generator can impact the conversion of torque into ampere. A more efficient generator will have less energy loss and therefore, more torque will be converted into amperes. In contrast, a less efficient generator will have more energy loss, resulting in a lower conversion of torque into amperes.
5. Are there any other factors that can affect the conversion of torque into ampere in a generator?
Aside from efficiency, other factors that can affect the conversion of torque into ampere in a generator include the strength of the magnetic field, the speed of rotation, and the size and composition of the conducting material. These factors can all impact the amount of electric current produced by a generator.
  • Electrical Engineering
