How Do You Derive Euler's Equation of Motion for a Rigid Body?
In summary, the transport theorem states that the time derivative of a vector is the same for all observers if and only if the vector is coordinate-free.
CAF123
88
Derive Euler's equation of motion for a rigid body: $$\dot{\vec{L}} + \vec{\omega} \times \vec{L} = \vec{G},$$ where ##\vec{L}## is the angular momentum in the body frame, ##\omega## is the instantaneous velocity of the body's rotation and ##\vec{G}## is the external torque.
Subsequent parts are written in an attachment.
Expressions for angular momentum and kinetic energy in rotating frame or body frame fixed in the body.
I believe that equation is saying the rate of change of angular momentum in some inertial frame is the rate of change of angular momentum in the body frame + another term due to rotation of axes relative to the inertial frame. Is that right? I found a derivation of the result for a general vector A but I could not understand this equation fully: $$[\dot{A}]_{S_o} = [\dot{A}]_S + \omega \times [A]_S$$ (##S_o## denotes the inertial frame and S the non inertial one and they coincide instantaneously. ##[A]_x## denotes A measured in frame x.)
The term on the left is the rate of change of A in the inertial frame. The first term on the RHS is the rate of change of A in S. Why is it then ##\omega \times [A]_S##? If we consider a turntable of radius R, then the velocity of a point on the circumference is ω x R relative to the centre of the turntable. But the centre of the turntable is fixed (so inertial) and a frame co-moving with a point on the circumference rotates relative to the centre so should it not be ##\omega \times [A]_{S_o}?##
Many thanks.
Or perhaps it is the case that given that the frames coincided instantaneously ##[A]_{S_o} = [A]_{S}##? But then this cannot be true for the whole motion.
Well, that's one way to express the kinematics transport theorem (not to be confused with the Reynold's transport theorem, or a number of other things called the transport theorem).
First it's important to distinguish between what I'll call a reference system and a coordinate system. (Note well: The literature is entirely inconsistent. Some groups use reference frame for what I'm calling a reference system, some groups use reference frame for what I'm calling a coordinate system.)
I'll use your turntable to distinguish the concepts, except I'll use a merry-go-round instead. Imagine two observers on the merry-go-round and another two on the ground. Each observer sets up a coordinate system based on how they see things. While the two observers on the merry-go-round might pick different basis vectors, those two rotating coordinate systems are embedded in the same rotating reference system. The same goes for the two observers on the ground. They can define two different non-rotating ("inertial") coordinate systems, but those two inertial coordinate systems are just different ways of expressing things from the perspective of the same inertial reference system.
At a specific point in time, we'll have all four observers describe the displacement vector from the center of the merry-go-round to the nose of the spotted pony on the merry-go-round. All four observers see exactly the same vector. How they represent that vector in their observer-specific coordinate systems will differ, but it's still the same vector.
It's time derivative is not the same to all observers. The two on the merry-go-round will say the derivative is zero. The pony isn't moving from the perspective of those rotating observers. The two on the ground will say the derivative is non-zero. Those two inertial observers see the same derivative vector. It's only the representations that differ.
We can do the same for any other vector ##\vec a## that is substantively the same to all four observers. While the vector ##\vec a## is the same vector to all observers, it's time derivative is not. The relationship between the time derivative of ##\vec a## from the perspective of our rotating and non-rotating observers is
[tex] \left(\frac {d\vec a}{dt}\right)_R + \vec \omega \times \vec a = \left(\frac {d\vec a}{dt}\right)_I [/tex]
That's the coordinate-free version of the transport theorem. The subscript R on the left denotes the time derivative as observed by a rotating observer, the subscript I on the right denotes the time derivative as observed by a non-rotating (inertial) observer. Deriving this is non-trivial. Just take it as a given.
Now let's make this specific to two different cartesian coordinate systems. Using a subscript R to denote one of the rotating observer's coordinate system and a subscript I to denote one of the inertial observer's coordinate system, the transport theorem becomes
[tex] \frac {d\vec a_R}{dt} + \vec \omega_R \times \vec a_R = T_{I\to R} \frac {d\vec a_I}{dt} [/tex]
where ##T_{I\to R}## is the time-varying transformation matrix from the inertial frame I to the rotating frame R.
Hi D H,
If a is the vector from the middle of the merry-go round to the pony, in the frame co-moving with the pony, da/dt_R is zero, so da/dt_I = w x a. And the a on the right hand side there corresponds to both the representation in the rotating frame and the representation in the inertial frame?
No. It's just a vector. How that vector is represented is not an issue in that first perspective. There's a big difference between what that vector represents and how that vector is represented. In this case, the vector ##\vec a## from the center of the merry-go round to the pony's nose represents the exact same thing to all of our observers. They all agree on it's length, they all agree on what other objects that vector point to.
When you take the time derivative that's no longer the case. The two inertial observers agree that their time derivatives are substantively the same vector, even if their coordinate representations differ. The two rotating observers similarly agree that their time derivatives are substantively the same vector. An inertial and rotating observer will not agree. To one the pony is moving and to the other, it's stationary.
Now what happens when you substitute angular momentum ##\vec L## for that vector ##\vec a##? Keep in mind that angular momentum in the rotating frame and angular momentum in the inertial frame are the same vectors. They just have different coordinate representations.
Consider a rotating unit vector. Because it is unit, its length is constant, so ##0 = {d \over dt} \left( \vec u \cdot \vec u\right) = 2 \dot {\vec u} \cdot \vec u##, i.e., the derivative of a unit vector is orthogonal with the vector itself. This should also be intuitively clear. Because of that, there exists vector ##\vec \omega## such that ##\dot {\vec u} = \vec \omega \times \vec u##. Vector ##\vec \omega## is the "angular velocity" of vector ##\vec u##.
Now let's take any vector ##\vec v(t) ## and represent it in a rotating frame. A rotating frame is specified by three rotating unit vectors ##\vec i, \vec j, \vec k## whose derivatives because of the above are given by ##\vec \omega \times \vec i, \vec \omega \times \vec j, \vec \omega \times \vec k## respectively. Because ## \vec v(t) = x(t) \vec i + y(t) \vec j + z(t) \vec k ##, ## \dot {\vec v} = \dot x \vec i + \dot y \vec j + \dot z \vec k + x \vec \omega \times \vec i + y \vec \omega \times \vec j + z \vec \omega \times \vec k = \vec p + \omega \times \vec v ##, where ## \vec p = \dot x \vec i + \dot y \vec j + \dot z \vec k ##. Observe that ##\vec p## looks like the derivative of ##\vec v## with the frame unit vectors fixed, or the "derivative in the co-rotating frame". This is what is meant by that funny bracket notation.
Hi voko,
So the ##\vec v## in that formula is the coordinate representation of a point relative to the co-moving frame. ##\vec \omega \times \vec v## encapsulates the fact that the co-moving coordinate frame is rotating relative to a fixed frame, so the quantity gives the rate of rotation of the co-moving frame relative to this fixed frame. ##\vec p## gives the rate of change of a vector describing a point relative to the co-moving frame. Yes?
How do you know, in your derivation, that ##\dot{\vec{v}}## is the rate of change of the vector v in the fixed frame?
Going back to the merry-go round example, and ##\vec a## describes a vector from the centre to a pony. In a frame co-moving with the riders, this vector remains fixed so ##\vec p = 0## and therefore ##\dot{\vec a} = \vec \omega \times \vec a##
If by "fixed frame" you mean the rotating frame, he didn't. voko's result is the rate of change of the vector v in the inertial frame. The unit vectors are constant in the rotating frame, so the derivative in the rotating frame is ##\dot v(t)_R = \dot x(t) \hat \imath + \dot y(t) \hat \jmath + \dot z(t) \hat k##. It's when you compute the derivative in the inertial frame that you get those extra derivative terms.
That ##\dot{\hat u} = \vec \omega \times \hat u## is a non-trivial exercise. It's usually done in terms of "bad physics math" -- a big handwaving exercise. For a decent derivation you'll either have to look at a graduate level aerospace engineering text (and even there, most authors still wave their hands rather vigorously), a graduate level classical physics text (ditto on most authors using vigorous hand waving), or a decent upper level undergrad or graduate level math text on Lie groups (but here you might have to read between the lines).
Sorry, I meant the inertial frame. What I don't understand is if the basis ##\left\{i,j,k\right\}## is used to describe some point in the rotating frame (if i interpreted voko correctly) then why would the time derivative of some vector in that frame ##v(t)##(I.e v(t) had components specified in the rotating frame) give the rate of change of that vector in the inertial frame?
Let's go back to my rotating and inertial observers. The rotating observers see those rotating frame unit vectors as constant, so the only parts of ##\vec v(t) = x(t)\hat i + y(t)\hat j + z(t)\hat k## that vary with time are the components ##\{x(t),y(t),z(t)\}##. The inertial observers see those rotating frame unit vectors as rotating, which means it's better to write that vector using the rotating frame basis vectors as ##\vec v(t) = x(t)\hat i(t) + y(t)\hat j(t) + z(t) \hat k(t)## when viewed from the perspective of an inertial observer.
The "point in the rotating frame" bit is misleading. Note that vector ##\vec v## was originally given without referencing any frames, it was "just" a vector. Then I spoke of representing it in a particular frame. Any frame, rotating or not, can be associated with three mutually orthogonal unit vectors, and any vector can be represented in that frame using those vectors, giving rise to coordinates of that vector in that frame. It is the coordinates that are frame-dependent, but not (necessarily) the vector itself. That is what I did; the vector was frame-independent, but its coordinates x, y, z were. This frame-dependency of the coordinates is exactly what gives the two terms in the formula for the full derivative: if we just differentiate the three coordinate functions, we obtain three other functions, which we can interpret as some vector using the original basis vectors; this is ##\vec p## in my derivation, and is known via some other confusing notation and confusing names.
I omitted the proof that ##\vec \omega## is uniquely defined and is the same for all the three basis vectors of the rotating frame. That, even though it may be almost obvious, gets to be rather lengthy to prove both correctly and lucidly. Overall, I like the exposition in Landau & Lifshitz Vol. 1, where it takes a few pages.
I never cease to wonder how all that knowledge was derived before the notion of vectors was well established and the vectorial symbolism got good traction. That was truly non-trivial.
Thanks D H, voko.
Is that correct? This means that as viewed from the observer attached to the inertial frame, the pony undergoes rotational motion only.
My next question is more relevant to the problem at hand. In the body frame, we write that ##T=\frac{1}{2}(I_1 w_1^2, I_2 w_2^2, I_3 w_3^2)##. But in the body frame, we are rotating with the top, so why is the kinetic energy of this form? Is it because in the body frame we feel the centrifugal force and so an observer attached to the body frame knows he is rotating and therefore his kinetic energy is like so?
Yes, that is correct. That is in fact the familiar equation relating linear and angular velocities: ## \vec v = \vec \omega \times \vec r ##.
I do not understand what that equation means. If ##T## is kinetic energy, it must be scalar.
In a frame co-moving with a rigid body, the kinetic energy of the body is zero. Pretty much by the definition of kinetic energy, which is based solely on the speed of an object.
Ok, so in my turntable example, viewed from the centre, the motion of a point on the circumference is purely rotational.
:eek: Rather ##T = \frac{1}{2}(I_1 w_1^2 + I_2w_2^2 + I_3 w_3^2)##
One part of the question is to show that kinetic energy is conserved. But why is the kinetic energy of the form above?
Well, there is more than one approach to that. I believe you and I discussed a while ago how you can decompose the kinetic energy of a system into the kinetic energy of the centre of mass and the "internal" kinetic energy. That could be useful here.
Yes. The kinetic energy to an inertial frame is the kinetic energy in the CoM + the kinetic energy due to rotation about CoM. The kinetic energy due to rotation about CoM is then ##T## above and since the body is just rotating (i.e not translating and rotating), the speed of the CoM is zero. Yes?
I can show that kinetic energy is conserved, by solving the Euler equations for ##w_1, w_2## and seeing that the sum of ##w_1^2 +w_2^2## is constant.
That looks good.
Assuming that you have already established the equation relating kinetic energy, angular velocity and the tensor of inertia, that should complete the proof.
That should just be ##T##. It is strange though because the next part of the question after showing the kinetic energy is conserved is to show that the sum ##w_1^2 + w_2^2## is constant. But I used this already in my derivation of the constancy of the kinetic energy.
If in the energy relative to the inertial frame is ##T##, then what is the energy relative to the body frame, or frame co-moving with the body? My notes say that it is also ##T##.
I have re-read the problem and it requires an explicit demonstration of energy conservation. Which probably means that you should start with the definition of kinetic energy and Euler's equations. Sorry that I misdirected you.
It's fine. In what way do you mean to use them? In my previous method I used the equations to solve for the ##w_i## and then use my definition of ##T##.
Well, the usual way is by multiplying the equation ##I_i \dot \omega_i = ... ## with ## \omega_i ## and then adding all that up. The leaves open the question whether you can just use the equation from #15.
Is this a self-study or an assignment?
Ok, I see. That would give $$\frac{\text{d}}{\text{d}t} \left(\frac{1}{2} \sum_i I_i w_i^2 \right) = 0$$ So the energy relative to this frame is also of the form ##T## given in #15. Why is the energy relative to the inertial frame and that of the non-inertial frame the same? It seems intuitive that they should be different.
Self-study - the question was online.
What makes you think the formula in #15 holds in the body frame (which I interpret as a frame co-moving and co-rotating with the body)? Vector ##\vec \omega## was not specified "in the body frame" and I believe it should be interpreted as the "angular velocity of the body in an inertial frame". I have checked a few sources, and in all them angular velocity is only defined with respect to an inertial system (even though not all of them are very clear about that). Angular velocity of a rigid body is the same in all inertial frames, and I think it is safe to interpret any mention of angular velocity as relative to an inertial frame unless very clearly stated otherwise.
Hi voko,
Two reasons: The Euler equations that are given in the question for torque free motion are the equations of motion relative to the body frame or frame co-moving/co-rotating with the body. Using just these equations, I got that a quantity 1/2 ∑Iiwi2 was conserved in that frame, which is the kinetic energy on dimensional grounds.
I also have some notes (see attached LDnotes) Page 3 near the top. Also see opening technical note in LD2notes. I did actually ask my professor about this and the interpretation he gave was that in the body frame, since it is non-inertial, an observer feels the centrifugal force and so knows he is rotating. Therefore the kinetic energy is of the form ##T## in the body frame.
Yes, ##\vec \omega## is a vector from the origin of the inertial coordinate system to a point on the rigid body. If we take some axis, say the 3-axis as the symmetry axis of the top, then ##\omega## precesses around this axes in the body frame. In the inertial frame, it is the 3 axis that rotates around ##\vec \omega##, if I understand correctly.
  • LD2notes.pdf
  • LDnotes.pdf
CAF123 said:
Hi voko,
I agree with that, except the last four words. Drop them. It is not the kinetic energy in the body frame. It is in the inertial CoM frame.
Speaking of Euler's equations, the only thing that needs to be in the body frame is the operation that gives you what I denoted earlier as vector ##\vec p##. Everything else, including the result of that operation (##\vec p##), are vectors that can be represented by coordinates in any frame, including an external inertial frame.
I am not sure what you mean by the final part. ##\vec \omega## need not be fixed in the inertial frame, if that was by any chance what you might have in mind.
Ok, but in LDnotes P.3 it says ''Moreover, in this coordinate system (meaning the body frame, the kinetic energy is of the form) ... ##T=...##''). I guess that is what I am trying to understand.
I was trying to interpret the diagram on page 2 of LD2notes, where they consider the symmetric top in the lab frame. Thanks.
This may be stemming from the confusion between a reference frame and a coordinate system, as D H warned. ##\vec \omega## is a vector defined with respect to an inertial frame, but that particular expression for the kinetic energy uses its coordinate representation in the co-rotating frame. You could use any other coordinate representation, you would still get the kinetic energy in the inertial CoM frame, because that is what defines the vector.
Yeah, this is confusing. And the worst part is yet to come: it will stay confusing years and decades after you'd think you had learned it all solid :)
##\omega## is defined relative to an inertial frame. We have a coordinate representation of this vector in the co-rotating frame(or body frame) which is denoted by ##\langle w_1, w_2, w_3 \rangle## So it is these coordinates that are used in the expression for ##T## in #15? Does this mean that relative to any other frame, ##T' = \frac{1}{2}(I_1'w_1'^2 + I_2'w_2'^2 + I_3'w_3'^2)## and for the equality to hold, ##I_i'## and ##w_i'## must be different from ##I_i## and ##w_i## (which is intuitive since MoI's depend on your choice of axes), but are such that ##T' = T##.
One grad student I was talking to said that the topic of rigid body motion was overall more difficult to comprehend than some of the research he was working on. I guess that is not very encouraging, but it puts your point into perspective.
Yes.
Yes in principle and no in details. In an arbitrary coordinate basis, the formula will have additional terms, given by the cross-products of angular velocity components.
I am not sure whether you have learned anything about tensor calculus yet, but note that energy is a scalar that is made by the scalar product (tensor contraction) of two vectors and with a second-rank tensor. When the coordinate basis changes, the vectors transform contra-variantly, while the tensor transforms co-variantly, preserving the scalar.
  • #31
No. The generic formula is ##T = \frac 1 2 \vec L \cdot \vec \omega = \frac 1 2 (I\vec \omega)\cdot \vec \omega##. This reduces to your simpler form only in the special case where the inertia tensor is diagonal.
One reason it's confusing is because rotations in three dimensional space don't commute. I didn't attain a true understanding of rigid body motion until I learned about Lie groups.
FAQ: How Do You Derive Euler's Equation of Motion for a Rigid Body?
What is a classic spinning symmetric top?
A classic spinning symmetric top is a toy or scientific instrument that consists of a symmetrical body with a pointed end, typically made of wood or metal, that is spun on its tip. As it spins, the top exhibits interesting physical phenomena such as precession and nutation.
How does a classic spinning symmetric top work?
A classic spinning symmetric top works by converting the energy from the initial spin into rotational kinetic energy. This energy keeps the top spinning and allows it to maintain its upright position. The symmetrical shape of the top helps to distribute the weight evenly and keep it balanced.
What is precession in a classic spinning symmetric top?
Precession is the phenomenon in which the axis of rotation of a spinning object, in this case the top, changes direction. This is due to the torque exerted by the gravitational force on the top as it spins.
What is nutation in a classic spinning symmetric top?
Nutation is the slight wobbling or nodding motion that a spinning top exhibits. It is caused by the combination of the top's rotation and the precession of its axis.
What are the practical applications of a classic spinning symmetric top?
Although primarily used as a toy or scientific demonstration, classic spinning symmetric tops have also been used as gyroscopes in navigation systems and as a tool for studying rotational motion and the laws of physics.
