(0,0) Empty Interval? Basic Set Theory
In summary: You're essentially proving that your original assertion is correct by adding another piece of information.
teroenza
195
Give an example of an indexed family of sets such that the intersection of any finite subfamily is not empty, but the intersection when the index=infinity, is empty.
The family I came up with is the exclusive interval (-1/k , 1/k) where k is the index (natural numbers) which index from 0 to infinity. I believe that the intersection of any finite subfamily is not empty. When I get to infinity, I get (0,0). This is an empty interval correct? Because I have squeezed the intersection to zero, but my interval is exclusive.
Thank you
Isn't 0 in every interval (-1/k, 1/k)?
I agree with vela. This isn't it. However, it is close to an example...
You don't really need both sides, right? Just consider the positive half of your family...
Ok. I understand that -1/k was redundant, and that 0 is in the successive intervals. But I don't understand what the exclusive interval from 0 to 0 means, even if it not the solution I seek.
The original family of intervals produces an intersection of {0}, as the element 0 is in every set of the form (-1/k, 1/k), but for every real number r > 0, there is a k such that 1/k < r, so r is not contained in the interval (-1/k, 1/k), and a similar argument holds for r < 0.
(a, b) is the set of all reals x such that a < x < b. Therefore, by definition, (0, 0) = {} the empty set (this is a valid real interval). However, {} is not the intersection of the family of intervals (-1/k, 1/k), for the reason vela noted.
If the family is (0, 1/k) that would still produce (0,0), and every interval would not include zero. The finite values of k would produce a non-empty intersection.
Yes.
I would avoid using (0, 0) and use {}. As you can see, (0, 0) = (x, x), so it's not very descriptive... and you might not get taken seriously if you use it later.
Also, if the family is (-1/k, 1/k), it would produce {0}, not {}. These are two different sets.
Thank you. Along those same lines, would (1, 1/k+1) producing (1,1) i.e. {} as k indexes to infinity be another example? It would have the same sort of shrinking interval, just shifted to the the right (positive) side of zero.
As alanlu noted, the notation (x, x) isn't meaningful. Don't use it.
All your sets in your example are empty. You may be looking for (1, 1 + 1/k).
Anyway, the intersection of the family of (1, 1 + 1/k) is {}.
Thank you both.
My teacher says that I am 1/2 right in providing the example. Now I must justify it. To justify the non-empty intersection part I will say that "as n increases the interval of intersection decreases in length, but still contains infinitely many points of intersection."
He said that is was incorrect, however, to say "at n=infinity, the family_n=infinity is ={}. He said it was like just adding in a foreign piece of information.
I believe that the intersection of an infinite number of sets to be empty, means that there can be no element common to all of them. But if there are an infinite number of points in an interval, no matter how small...
This is a second year class. I just can't seem to justify my answer.
I apologize for my imprecise language. Correction: "Also, if the family is (-1/k, 1/k), the intersection of all elements of the family would be {0}, not {}. These are two different sets."
Try fixing an element r in ℝ. Which sets would r have to belong in if it were to belong in the intersection of a family of sets?
If you only state that, you're simply asserting what you're trying to prove.
This is an example of the non-intuitive things that crops up when infinity is involved. If you look at any finite intersection of those intervals, it will always contain an infinite number of points, but the intersection of an infinite number somehow ends up empty.
Go back to the definition of intersection. What is the intersection of a family of sets? Can you show that the intersection of your family of sets is empty, but that the intersection of finitely many of the sets in your family is non-empty? Go directly to the definition of intersection. Is that too vague a hint? There's a general technique in doing formal proofs. Whenever you're stuck, go directly to the exact textbook definition and show that the definition is satisfied (or not) by the particular objects in question. Forget about "decreasing lengths" or whatever. This is a question about set intersection and they're trying to get you to think formally about set intersections.
After speaking with him again I have this. A finite intersection is nonempty because for any intersection of arbitrary subfamilies from my indexed family there are common points. However, when I have an infinite number of subfamilies I can always find one which does not contain an arbitrarily chosen element, this making the intersection empty.
if A is a subset of R with this property:
for all x in R, x is not in A, then A is the empty set.
that is: ∅ = R - R.
this gives a useful way to show a subset of R is actually the empty set: show that no real number is in it!
Yes but all you've done is give the definition of intersection. In other words, you say, "A finite intersection is nonempty because for any intersection of arbitrary subfamilies from my indexed family there are common points." That's the definition of what it is that you have to prove. (Assuming you meant finite subfamilies, not "arbitrary" subfamilies as you wrote).
So if I was the grader here, I would be looking for specifics. What I'd like to see is:
* A clear statement of exactly what your claimed family of sets is.
* Then prove that the intersection of your family is empty.
* Then prove that the intersection of any finite number of sets in your family is nonempty.
FAQ: (0,0) Empty Interval? Basic Set Theory
What is the definition of an empty interval in basic set theory?
An empty interval, also known as a null or void interval, is a set that contains no elements. It is represented as (0,0) in basic set theory notation.
How is an empty interval different from a null set?
An empty interval and a null set are often used interchangeably, but they have different meanings. An empty interval is a type of set that contains no elements, while a null set is a set that has no elements at all.
Is an empty interval considered to be a subset of any other set?
No, an empty interval is not considered to be a subset of any other set. This is because it does not contain any elements, and a subset must have at least one element in common with the larger set.
Can an empty interval be represented by other symbols or notations?
Yes, an empty interval can also be represented by the symbols ∅ or {}. These symbols are commonly used in mathematics to represent an empty set or null set.
What is the significance of an empty interval in basic set theory?
An empty interval is important in basic set theory as it helps to define the concept of an empty set and the concept of a null set. It also plays a role in the study of set operations and the construction of larger sets through unions and intersections.
