MHB 051 how they got the eigenspaces ?
  • Thread starter Thread starter karush
The discussion focuses on finding eigenspaces for the matrix A = [[-1, 2], [-6, 6]]. The correct eigenvalues are identified as 2 and 3, with corresponding equations derived for eigenvectors. For eigenvalue 2, the equations simplify to 3x = 2y, leading to an eigenvector (2, 3) and its multiples. The participants clarify that the eigenvectors span the eigenspace associated with each eigenvalue. The conversation emphasizes the importance of correctly identifying eigenvalues to determine the corresponding eigenspaces.
karush
MHB
ok I didn't understand how they got the eigenspaces
the original matrix was
$A=\left[\begin{array}{rrr}−1&2\\−6&6\end{array} \right]$
so think I got values correct $\lambda=2,3$
https://dl.orangedox.com/wlKD7eKSWiQ79alYD6
Yes, the eigenvalues are 3 and 4.
Any eigenvector corresponding to eigenvalue 3 must satisfy
$\begin{bmatrix}-1 & 2 \\ -6 & 6\end{bmatrix}\begin{bmatrix}x \\ y \end{bmatrix}= \begin{bmatrix}3x \\ 3y \end{bmatrix}$
so -x+ 2y= 3x and -6x+6y= 3y. What must x and y be? (Those two equations reduce to the same thing so there are an infinite number of solutions- a one dimensional subspace.)
Any eigenvector corresponding to eigenvalue 4 must satisfy
$\begin{bmatrix}-1 & 2 \\ -6 & 6\end{bmatrix}\begin{bmatrix}x \\ y \end{bmatrix}= \begin{bmatrix}4x \\ 4y \end{bmatrix}$
so -x+ 2y= 4x and -6x+6y= 4y. What must x and y be?
Those eigenvectors span the "eigenspace".
That last is wrong because, of course, the eigenvalue was 2, not 4!
Instead -x+ 2y= 2x and -6x+ 6y= 2y.
2y= 3x and -6x= -4y both reduce to 3x= 2y. In particular, if we take x= 2, then 3x= 6= 2y, y= 3. One eigenvector is (2, 3) but any multiple is also an eigenvector.
Thread 'How to define a vector field?'
Hello! In one book I saw that function ##V## of 3 variables ##V_x, V_y, V_z## (vector field in 3D) can be decomposed in a Taylor series without higher-order terms (partial derivative of second power and higher) at point ##(0,0,0)## such way: I think so: higher-order terms can be neglected because partial derivative of second power and higher are equal to 0. Is this true? And how to define vector field correctly for this case? (In the book I found nothing and my attempt was wrong...
