1-D (I think) Speed to distance problem
  • Thread starter Thread starter magnanimousto
    Speed
A runner accelerates from rest to 2.0 m/s over 12 m, and the problem asks for the distance needed to reach 3.0 m/s under the same force. The initial attempt to solve it using time was incorrect, leading to confusion. Participants suggest using kinematic equations or the Work-Energy Theorem to find acceleration first. Recognizing that the force remains constant implies the acceleration is the same for both scenarios is crucial. The correct total distance to accelerate to 3.0 m/s is determined to be 27 m.
magnanimousto
A runner exerts a constant force to accelerate from rest to 2.0 m/s over a distance of 12 m.
Assuming the runner can keep up the same force, what total distance would be needed to ac-
celerate up from rest to 3.0 m/s?
none given.
The answer to the problem is 27. After quite some time spent thinking I tried solving first part for time using x= 1/2 vt and then plugging it into 2nd part. but that gives time as 12 and 2nd x as 18 so wrong. Dunno how to solve it
none given.
Hello magnanimousto. Welcome to PF!
What kinematic equations do you know?
Alternatively, do you know the Work-Energy Theorem ?
This is a constant acceleration problem, so you can use the basic kinematic equations for that case. Try solving for the acceleration first, and using that value for the next part.
If you don't know those equations, here's the one you should probably use -- they're very helpful to memorize though.
v_{f}^{2}= v_{i}^{2} + 2aΔd
Thanks jackarms & SammyS.I do know kinematics equations, for some reason it never occurred to me that since the force is the same in both so must be the acceleration
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
