1-D Motion, calculating final velocity
The discussion revolves around a calculation of final velocity in 1-D motion, where the user initially calculated vf as 4.7 x 10^5 m/s, while the textbook states it should be 8.7 x 10^5 m/s. The error was identified as a misunderstanding of unit conversion, specifically regarding centimeters to meters. After realizing the mistake, the user acknowledged the correction and expressed gratitude for the assistance. This highlights the importance of accurate unit conversion in physics calculations.
mncyapntsi
An electron is moving in a straight line with a velocity of 4x10^5 m/s. It enters a region 5.0 cm long where it undergoes an acceleration of
6.0x10^12 along the same straight line. (a) What is the electron’s velocity when it
emerges from this region? b) How long does the electron take to cross the region?
vf^2 = vi^2 + 2a(xf-xi)
Hello!
I have done this problem :
vf^2 = (4.0x10^5)^2 + 2(6.0x10^12)(5x10^-3)
so vf= sqrt((4.0x10^5)^2 + 2(6.0x10^12)(5x10^-3))
I get vf = 4.7 x 10^5 m/s
However, the textbook solutions says vf = 8.7x10^5 m/s.
Where did I go wrong?
Thank you for any help! :)
Well... how long is a cm, again ? In terms of metres, that is.
Does that get you any closer ?
Likes berkeman and Lnewqban
Oh no! Of course that changes the result haha.
Thank you so much for pointing that out :)
Likes hmmm27 and berkeman
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
