12V diode combiner circuit question
In summary, the individual is installing an anchor/steaming light on a 29' Bristol boat and is connecting them to two separate single pole single throw breakers. They are seeking advice on what type of diode to use in order to have the steaming light and anchor light turn on independently. The lights themselves do not draw much power and the individual is unsure about any regulations or specifications for using a diode in a marine setting.
Rbandura
Hello, I'm currently doing an electrical refit on a 29' Bristol. I have an anchor/steaming light for the top of the mast. I'm connecting them to two separate single pole single throw breakers. My problem is that I need the steaming light (fwd light) to be able to come on indipendantly from the anchor light (both light) and vice versa. I know I can just put a diode in-between the breakers to solve this problem. But I'm not sure what sort of diode I need. It's a 12v system, each breaker is 5 amps. The lights themselves don't even draw one amp combined. Any help would be greatly appreciated. Thanks!
:welcome:
I don't understand your question. Each light has a ground connection. Each light has its own single pole switch for the positive side. You can turn them on/off independently. Why the question?
Edit: many modern mashead anchor/steaming/navigation/emergency flash LED lights come with a bit of smarts. They use one positive wire and one negative ground wire for all the lights. The control switch you push once for anchor, twice for steaming, three for nav, four for flash, five times for off. That is simpler than running separate wires for each. By the way, it is illegal to use your anchor light and steaming light at the same time.
Sorry, let me explain a little better. When I flip the breaker for the anchor light, I need both lights to turn on, when I flip it for the steaming light I just need the forward light to turn on.
The light it self is a single component with two bulbs. There are two positives coming out and they share a negative.
So this is a work project, I'm not going to lie I'm not much of a boater myself, I just work on them. So when it comes to coast guard regulations I'm pretty clueless. We do have other techs that sail and when talking with them they all said with that light that is the correct set up. I know it should be on a rocker switch but we have limitations in what we could add. So making it work on our main DC
panel breakers was our best option.
What is the matter with that? Why doesn't that do what you need?
It works if you throw both breakers for the anchor, and just the one for the steaming. But I want to be able to throw the anchor light breaker and activate both lights, while keeping the steaming on its own separate breaker as well.
I know I can achieve this with a diode, my main question was if there was a certain diode I needed for Marine applications. Or would any old 12v 3 amp diode do the trick.
I apologise for any confusion. I really do appreciate the help.
any normal diode ... there are no such things as marine diodes that I'm aware of
Related to 12V diode combiner circuit question
1. What is a 12V diode combiner circuit?
A 12V diode combiner circuit is a circuit that combines multiple 12V power sources into one output. It uses diodes to prevent backflow of current and ensure that the combined output voltage remains at 12V.
2. How does a 12V diode combiner circuit work?
The diodes in a 12V diode combiner circuit act as one-way valves, allowing current to flow from the power sources towards the output, but not in the reverse direction. This ensures that the combined output voltage remains at 12V, even when multiple power sources are connected.
3. What are the advantages of using a 12V diode combiner circuit?
One of the main advantages of using a 12V diode combiner circuit is that it allows you to combine multiple power sources without the risk of overloading or damaging them. It also provides a stable and consistent 12V output, which is useful for powering electronic devices.
4. Can I use a 12V diode combiner circuit with different voltage sources?
No, a 12V diode combiner circuit is specifically designed for use with 12V power sources. Using different voltage sources may result in incorrect voltage output and could potentially damage the circuit.
5. How do I choose the right diodes for a 12V diode combiner circuit?
The diodes used in a 12V diode combiner circuit should have a voltage rating of at least 12V and a current rating that is greater than the maximum current output of the circuit. It is also important to choose diodes with low forward voltage drop to minimize power loss.
  • Electrical Engineering
