- #36
Merlin3189
- 824
"If you look at the variables in the equation, there's really only one that you have control over, and that's the "area" of the wind turbine." I think this a very important point. There is a danger of thinking, 'if only we used a different alternator, or geared it up, or down, or whatever', then we could make it work. But the essential point is, there is only a certain amount of energy/power available from a moving mass of air (and apparently*, we can only extract about 60% of that.) Nothing you can do with your alternator can alter this.
All you can do is to optimise the extraction / conversion process, so I think you need to look at the steps in the process and see which ones can be improved. Two items related to the alternator which I think could be changed to help you are both electronic.
What might help you most with your main problem (getting output at low wind speed) is synchronous rectification. Instead of using diodes, as shown in the circuit of #33 and used universally in automotive systems, you can use mosfet transistors (and associated control circuitry.) Diodes have a roughly constant voltage drop of 0.7V, so that two in series in the standard circuit drop 1.4V. To get 12V output you therefore need to generate at 13.4V and waste 10% of your power in the diodes. Mosfets do not have a constant voltage drop, but a very low resistance of only about 0.01 V per amp. So at low currents, say up to 10 A, the voltage drop is less than 0.2 V, wasting only 1 - 2% of your power. At high currents you eventually lose out to diodes, but then you are not so worried about losing a bit.
Another thing you can do with controlled transistor rectification, is simply to switch it off at low speeds. This could solve your starting torque problem: if no power is being extracted, there is no electromagnetic drag and your alternator should rotate freely, limited only by friction.
I think the reason this does not seem to feature in many amateur wind turbines, is that automotive alternators usually have diodes built in and possibly regulation as well. But I guess it would not be too difficult to remove or bypass them.
If you get away from automotive alternators and have them made specifically for your purpose (possibly, increasing the cost 10x of course!) then you can also do things such as SophieC's suggestion of increasing the poles to make it function at lower speed (but higher torque.) Doing so does not give any more power, but by avoiding gears / pulleys will reduce frictional loss.* "Betz Law
In 1919, a German physicist Albert Betz, based on conservation of momentum and energy, he proved that the maximum possible energy that can be derived from a wind turbine cannot be more than 59.3 percent, or 16/27 of the potential energy in the wind.
In practice, no wind turbine has ever achieved the Betz limit."
