MHB -14.1 ....standard deviation of 15......
  • Thread starter Thread starter karush
    deviation
IQ scores follow a normal distribution with a mean of 100 and a standard deviation of 15. The discussion focuses on determining the proportion of individuals with IQs above 130, which is two standard deviations above the mean. It is established that approximately 95% of the population falls within two standard deviations of the mean, leaving about 5% in the tails. Since the question specifically asks for the proportion above 130, the answer is 2.5%. Understanding the normal distribution is crucial for interpreting these statistics accurately.
karush
MHB
Given IQ scores are approximately normally distributed with a mean of 100 and standard deviation of 15,
the proportion of people with IQs above 130 is:
$ a.\ 95\% \quad b.\ 68\% \quad c.\ 5\% \quad d.\ 2.5\% \quad e.\ 12\%$
ok its been some moons since I looked at a standard deviation graph
so my choice would be by dice.
Mathematics news on Phys.org
It's not a "standard deviation graph", it's a normal distribution graph.
130 is two standard deviations above the mean. How much of the data will be within two standard deviations from the mean? So how much for each tail?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
