2 masses, a massive pulley and an inclined surface
The discussion revolves around solving a physics problem involving two masses, a pulley, and an inclined surface with friction. Participants derive equations for tension and acceleration using Newton's laws and torque principles. There is a debate on the necessity of tension values T1 and T2, with suggestions to eliminate them for a more straightforward solution. Corrections are made regarding the algebra, leading to a consensus on the correct expression for acceleration. The final acceleration formula is confirmed as a = (2/7)(2 - sin(θ) - μcos(θ))g.
Karol
[/B]A mass m lies on an inclined surface with equal coefficients of friction μ=μsk. the pulley has also mass m and the weight is 2m. what is the velocity after it has descended distance h and during how much time.
Moment of inertia of a massive disk: ##I_{cen}=\frac{1}{2}mr^2##
Torque and angular acceleration: ##M=I\alpha##
$$\Sigma F=ma:~~\left\{\begin{array}{l} 2mg-T_1=2ma \\ T_2-mg\sin\theta-mg\mu\cos\theta=ma \end{array}\right.$$
$$\rightarrow~T_1=\frac{2}{3}(1+\sin\theta+\mu\cos\theta)mg$$
$$T_2=\frac{mg}{9}(4+7\sin\theta+7\mu\cos\theta)$$
$$M=I\alpha:~~a=\frac{2}{m}(T_1-T_2)=...=\frac{2g}{3}\left( \frac{2}{3}-\frac{1}{3}\sin\theta-\frac{\mu}{3}\cos\theta \right)$$
Well done - I have not checked the algebra but that looks like a good approach to take.
Is there a question in all that?
Thank you Simon, i am not sure about my answer, that is why i posted. thank you
I got different result. T1 and T2 are not needed. Eliminate them by adding the force equations and substituting T1-T2 from the torque equation.
Looks like you divided by 3 twice over.
$$\left\{\begin{array}{l} (\rm 1)~2mg-T_1=2ma \\ (\rm 2)~T_2-mg\sin\theta-mg\mu\cos\theta=ma \end{array}\right.$$
$$(\rm 1)+(\rm 2),~T_2-T_1=-\frac{1}{2}ma:~~a=\frac{2}{7}(2-\sin\theta-\mu\cos\theta)g$$
Correct!
Thanks Ehild, Simon and Haruspex
  • · Replies 18 ·
  • · Replies 24 ·
  • · Replies 40 ·
