2 Quck Questions on Work and Energy
The discussion revolves around two physics problems involving work and energy. For the first question, the correct kinetic energy of a 0.2 kg ball dropped from 8 m should be calculated using the formula KE = (1/2)mv^2, not the incorrect potential energy equation initially used. The second question involves Jane swinging on a vine, where the potential energy at the highest point equals her kinetic energy at the lowest point, suggesting a conservation of energy approach. Participants emphasize the importance of using the correct equations to arrive at accurate answers. Clarifications on energy conservation principles are also discussed to ensure understanding of the concepts.
bigpapasmurf
1. If a 0.2 kg ball is dropped from a height of 8 m, what is its kinetic energy when it hits the ground?
2. Jane, looking for Tarzan, is running at top speed (4.6 m/s) and grabs a vine hanging vertically from a tall tree in the jungle. How high can she swing upward?
Kinetic Energy = (1/2) mass*gravity*height
Potential Energy= mass*gravity*height
not sure if this equation is right... distance=(1/2)(gravity)(time^2)
Velocity= (change in distance)/time
my work got deleted for both the question (error in webassign) and now I have no idea how I got the answers. (both wrong) But they were 9.5J for the first one and 14.2m for the second question.
Your KE equation is wrong. It's mixed up with the correct PE equation. Fix the KE equation, and you should get the correct answers.
woops I had it actually I just wrote typed it out wrong it is (1/2)mv^2
For part a, maybe I am missing something, but did you say that your answer of 9.5J was correct? because I am thinking otherwise unless I am missing something very obvious.
E(i)=E(f) ---> PE=KE in this case correct?
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up ##Mg \sin \theta ## will act downwards and maximum static friction will act downwards ## \mu Mg \cos \theta ## Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
TL;DR Summary: Find Electric field due to charges between 2 parallel infinite planes using Gauss law at any point Here's the diagram. We have a uniform p (rho) density of charges between 2 infinite planes in the cartesian coordinates system. I used a cube of thickness a that spans from z=-a/2 to z=a/2 as a Gaussian surface, each side of the cube has area A. I know that the field depends only on z since there is translational invariance in x and y directions because the planes are...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
