Are Electric and Magnetic Fields Essentially the Same?
  • Thread starter Thread starter Nick89
    Analogy Fields
Electric (E) fields and magnetic (B) fields exhibit significant similarities, particularly in their mathematical descriptions, as seen in Coulomb's law and Biot-Savart's law, where constants epsilon_0 and mu_0 interchangeably relate to each other. The relationship between E and B fields becomes particularly evident in the context of time-varying fields, as outlined in Maxwell's equations, which demonstrate their interdependence. Special relativity further unifies these fields, suggesting they are manifestations of the same electromagnetic phenomenon. Discussions also highlight the derivation of the Biot-Savart law from Coulomb's law using Lorentz transformations, emphasizing the symmetry and connection between electric and magnetic forces. Overall, the conversation underscores the theoretical framework that positions E and B fields as fundamentally linked in both classical and quantum mechanics.
Nick89
Hi,
I was simply wondering this for some time now... I am constantly seeing similarities between electric (E) fields and magnetic (B) fields.
A few examples, Coulomb's law and Biot-Savart's law:
dE = \frac{1}{4 \pi \epsilon_0} \frac{dQ}{r^2}
dB = \frac{\mu_0}{4 \pi} \frac{I dl}{r^2}
They are nearly the same... Especially the constants \mu_0 and epsilon_0, they always seem to be taking each other's place, where epsilon_0 is always replaced with (\mu_0)^{-1} (not just in this example but everything I have ever come across, like in EM-waves etc...)
Also in the case of time-varrying E or B fields they seem to be related, you can't only look at one without considering the other anymore (maxwell equations etc)...
I have heard / read a bit about this and it seems to be that E and B fields are essentially the same, in quantum mechanics, or in (general?) relativity (or both? I dunno..)...
Is this true?
If anyone has some information on this that would be great, I'm very interested in this...
Thanks!
EDIT
I don't know if it's the same with you guys but for some reason I cannot see the latex images in my post... Seems to be something wrong...
The electric and magnetic fields are unified in special relativity.
It is possible to derive the Biot-Savart law using a thought experiment with Coloumb's law and a moving observer. When we use the Lorentz transformations of special relativity to transform coordinates, the Biot-Savart law is the result.
Is this transformation difficult to actually calculate? Could you perhaps show an example?
The transformation is not too difficult, but it could take some time to reproduce it here on the forum. I suggest trying google first, or checking out Chapter 12 of Griffth's "Introduction to Electrodynamics" if available.
For instance, here is a talk given by Daniel Shroeder from Weber State on this topic:
http://physics.weber.edu/schroeder/mrr/MRRtalk.html
Thanks that seems like an interesting read!
I don't happen to have a Griffith. I do, however understand the vacuum gauge symmetry of E and B. Does Griffith discuss any non-vacuum symmetry? just curious...
Electricity and magnetism are two extremes of the same phenomenon (electromagnetism). If you were to approach this quantum mechanically, with the addition of a few things, Maxwell's equations will show them to be practically identical. So then why is there a magnetic force and electric force...actually...I don't know and I have not gone into quantum mechanics...but it has something to do with charges moving, so I would assume magnetic fields occur due to moving Electric Fields...and if electric fields move, they are not always constant in a fixed frame of reference...and so magnetic fields occur essentially when there is a changing electric field...and electric fields occur with changing magnetic fields, which is apparently symmetric.
Yes, we are not talking about the vacuum gauge symmetry, but rather a process of deriving the magnetic field of a infinite line of current using the lorentz transformations and coloumb's law.
Yes, of course. My mistake. Checking my notes, the gauge doesn't enter into it, apparently. It seems however, that if
is expressed in a coordinate independent form using
d*F=-*J where J is a 1-from,
will be included in the same equation, where the Lorentz transform is implicit. I can't simply tell by looking as these two equations if that would be the case.
Another one
There's Another similarity between the Gauss' And Amperean laws
Integral(closed surface) E.ds = q(enclosed)/Epsilon nought
Integral(closed loop) B.dl= I(enclosed)/Mu nought
I know, there are loads, and it's obvious from the maxwell equations that time-varying E and B fields are physically connected. However it is not directly obvious that they would be the same thing (if you look at it in the right way)...
