I 2D Ising Model Average Number of Domain Walls
  • I
  • Thread starter Thread starter thatboi
    Classical Domain
The discussion centers on the classical Ising model on a 2-D square lattice with no external field, focusing on the average internal energy per site at criticality, which is calculated to be u = -√2 when the coupling constant J is set to 1. The query involves determining the average number of domain walls per site, given that each domain wall contributes an energy of 2. The ground state energy is established as -2N, and the goal is to find the number of domain walls needed to raise the energy to -√2N. The derived equation, n_walls/N = (2 - √2)/2, is proposed as a solution to this energy transition. The logic and calculations presented appear to be sound and consistent with the principles of the Ising model.
thatboi
Hi all,
I'm trying to see if my question/logic makes sense. Suppose I have a classical Ising model on a 2-D Square lattice with ##N## sites and 0 external field. There is an exact formula for the average internal energy per site, and at criticality it turns out to be ##u = -\sqrt{2}## where I have set the coupling constant ##J=1##. From here, I'd like to know if it is possible to find the average number of domain walls per site. I know each domain wall contributes energy ##2##. Now suppose the system is in its ground state (say all spin-up). Then the ground state energy is ##-2N##. I want to put in domain walls until the system energy increases to ##-\sqrt{2}N##, so we just need to solve ##-2N + 2n_{\text{walls}} = -\sqrt{2}N## and I get ##\frac{n_{\text{walls}}}{N} = \frac{2-\sqrt{2}}{2}##. Does this make sense?
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
