B 2D Model of the Universe as an expanding ball
A simplified 2D model of the universe as an expanding ball suggests that time acts as a vector normal, with light moving at a 45-degree angle to this vector. While the model is intriguing, it conflicts with observations that indicate the universe is flat and does not show large-scale spatial curvature. Current theories, including General Relativity, propose a finite closed universe must be very large to avoid evidence of curvature. The relationship between the universe's expansion and curvature is governed by the Friedmann equations, indicating that dark energy is responsible for the accelerating expansion rather than the expansion itself. Ultimately, the model serves as a crude analogy, as the universe is a complex 4D manifold.
darkdave3000
TL;DR Summary
Can an expanding ball describe our universe in a simplified 2D model?
Can a simplified 2D model of our universe be an expanding ball? Where the surface of the ball is the 2D universe time is the vector normal of the ball measured in imaginary number i. So light will move at 45 degree to any vector normal. The expanding ball gets bigger because time is causing it to expand outward and this is why the universe expands because of material flying out into time. Also if you travel far enough in one direction you come back to your origin like on Earth (warped space).
Would this be an accurate model of the universe?
I recall the universe was discovered to be "flat" so how big would this ball have to be so that the fact that we haven't seen parallel lines converge at any distance can be explained away that the universe is just too big for us to observe it?David
Space news on Phys.org
One of the possibilities thrown up by the theory of General Relativity is a finite closed universe, as opposed to an infinite flat universe. The current observations suggest that if the universe is closed, then it must be very large, as there is no evidence of large scale spatial curvature.
Moreover, our universe appears to have the critical matter-energy density required for an infinite flat universe:
https://en.wikipedia.org/wiki/Friedmann_equations#Density_parameter
It's tempting to imagine the spherical geometry that way, but it doesn't work with time as the radial component. The scale factor does not grow linearly with cosmic time, as it would have to be doing in this scenario.
If you forget about including time in there, and instead treat the radius of the sphere as just the radius of its curvature, then this radius would have to be at least ~205 Gly (this comes from the error bars on the density parameter, mentioned above, as per the latest Planck data).
So is there a relationship between the expansion of the universe and curvature? Change in Surface Area Vs Change in Radius? And is dark energy (expanding universe) merely caused by the passage of time?
Everything is related by the Friedmann equation:
The universe is a 4D manifold (three space plus one time). It's only a crude analogy to compare it to an expanding sphere in 3D space.
It's not dark energy that causes expansion; expansion is a result of the laws of GR and the Friedmann equation. Dark energy, however, is responsible for the current accelerating expansion. Without dark energy, the universe would still be expanding - but the expansion would be slowing down.
Abstract The Event Horizon Telescope (EHT) has significantly advanced our ability to study black holes, achieving unprecedented spatial resolution and revealing horizon-scale structures. Notably, these observations feature a distinctive dark shadow—primarily arising from faint jet emissions—surrounded by a bright photon ring. Anticipated upgrades of the EHT promise substantial improvements in dynamic range, enabling deeper exploration of low-background regions, particularly the inner shadow...
https://en.wikipedia.org/wiki/Recombination_(cosmology) Was a matter density right after the decoupling low enough to consider the vacuum as the actual vacuum, and not the medium through which the light propagates with the speed lower than ##({\epsilon_0\mu_0})^{-1/2}##? I'm asking this in context of the calculation of the observable universe radius, where the time integral of the inverse of the scale factor is multiplied by the constant speed of light ##c##.
Title: Can something exist without a cause? If the universe has a cause, what caused that cause? Post Content: Many theories suggest that everything must have a cause, but if that's true, then what caused the first cause? Does something need a cause to exist, or is it possible for existence to be uncaused? I’m exploring this from both a scientific and philosophical perspective and would love to hear insights from physics, cosmology, and philosophy. Are there any theories that explain this?
