2nd order non-linear homogeneous differential equation
byrnesj1
Find a solution (Z2) of:
z'' + 2z - 6(tanh(t))2z = 0
that is linearly independent of Z1 = sech2
reduction of order gives you
v''(t)(Z1(t))+v'(t)(2 * Z1'(t)) + v(t)(Z1''(t)+p(t)Z1'(t)) = 0
however the third term on the LHS can be dropped since we know that Z1 is a solution to the original problem.
v''(t)(Z1(t))+v'(t)(2 * Z1'(t)) = 0 = sech2(t)v''(t) + 2(-2tanh2(t)sech2(t))v'(t)
let y = v'
sech2(t)y'(t) + 2(-2tanh2(t)sech2(t))y(t) = 0
divide both sides by sech2(t)
y'(t) - 4tanh2(t)y(t) = 0
from here would I use integrating factor, or should I have done exact equations for the step before this?
using integrating factor
μ(t) = e(4tanh(t)-4t)
y = e-(4tanh(t)-4t)
v = ∫e-(4tanh(t)-4t)dt
can any1 point me in the correct direction? I also don't know how to integrate the last part..
that is linearly dependent of Z1 = sech2
let y = v'
y = e-(4tanh(t)-4t)
Check the derivative of sech2(t).
ehild
ahh that works beautifully. thanks ehild.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
