Java 3.14.1: Warm up: Text message abbreviation decoder (Java)
The discussion centers on troubleshooting a Java program designed to expand text message abbreviations. The user encounters errors related to variable declaration and initialization. Specifically, the line "Scanner=new Scanner(System.in);" lacks a variable name, leading to a "cannot find symbol" error. Additionally, the user mistakenly refers to the Scanner variable as "txtMsg" when trying to read input, which is incorrect. Suggestions include renaming the Scanner variable to something more descriptive, such as "input," and using the "equals" method for string comparison instead of "compareTo." A more efficient approach using a switch statement is also recommended for handling the abbreviations. The importance of providing clear problem descriptions and including error messages in queries is emphasized for better assistance in future discussions.
zatawave
I'm working on this code for my programming class and I'm completely stuck. Here is what I have so far but I keep getting error messages.
Code:
import java.util.Scanner;
public class TextMsgAbbreviation {
   public static void main(String[] args)
      String BFF ="best friends forever";
      String IMHO ="in my humble opinion";
      String TMI = "too much information";
      String LOL = "laughing out loud";
      String IDK="I don't know";
      String textMsg="";
      System.out.println("Input an abbreviation:"+" ");
      textMsg=txtMsg.nextLine();
      if (textMsg.compareTo("BFF")==0)
      System.out.println(BFF);
      else if(textMsg.compareTo("IMHO")==0)
      System.out.println(IMHO);
      else if(textMsg.compareTo("TMI")==0)
      System.out.println(TMI);
      else if(textMsg.compareTo("LOL")==0)
      System.out.println(LOL);
      else if(textMsg.compareTo("IDK")==0)
      System.out.println(IDK);
      else
      System.out.println("Unknown");
      return;
this is what I'm receiving once I run the code.
TextMsgAbbreviation.java:12: error: cannot find symbol
symbol: variable Scanner
TextMsgAbbreviation.java:17: error: cannot find symbol
symbol: variable txtMsg
2 errors
Any help would be greatly appreciated.
Technology news on Phys.org
Hi, and welcome to the forum!
Your problem is in the this line:
[m]Scanner=new Scanner(System.in);[/m]
Variable declaration and initialization looks as follows:
[m]ClassName varName = new ClassName(constructorArguments);[/m]
You omitted the variable name. Later you refer to this variable as [m]txtMsg[/m] in [m]txtMsg.nextLine()[/m], but I recommend naming it something like [m]input[/m]. It better conveys the idea that it stores the program's standard input, and it is less likely to be confused with [m]textMsg[/m].
Comparing strings with [m]compareTo[/m] is fine, but this method also compares strings lexicographically. You need only test for equality, so you could write
[m]if (textMsg.equals("BFF"))[/m]
You can also write the branching part as follows.
Code:
    switch (textMsg) {
      case "BFF": System.out.println(BFF); break;
      case "IMHO": System.out.println(IMHO); break;
      case "TMI": System.out.println(TMI); break;
      case "LOL": System.out.println(LOL); break;
      case "IDK": System.out.println(IDK); break;
      default: System.out.println("Unknown");
Apparently, only string literals (i.e., string in quotes) can be used inside [m]switch[/m], but this is the case with your code.
Some hints for the future: write the whole question in the message body, not in the thread title. Also, you did well to include the precise error message rather than saying "It does not work", but in asking about a piece of code it is important to describe what it is supposed to do. It is also a good idea to shorten it as much as possible to keep the problem but exclude everything else. Determining what a piece of code does is what is called an undecidable problem: there is no computer algorithm that takes any code and determines what it does, whether it contains a logical error, etc. Naturally, it is hard for humans, too.
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
