MHB 4-39 magnitude of its velocity after falling 10.0m
The discussion focuses on the calculations related to a water balloon thrown downward from a building. After 2 seconds, the speed of the balloon is calculated to be 27.6 m/s, and it falls a distance of 31.6 meters in that time. The magnitude of its velocity after falling 10.0 meters is determined to be 15.2 m/s. The calculations utilize motion formulas for speed and distance, considering the initial velocity and acceleration due to gravity. The discussion also highlights the importance of correctly applying these formulas for accurate results.
karush
MHB
a) what is its speed after falling to 2.00s
motion formula $v=u+at$
so
$v = 6.00 \dfrac{m}{s}
+ 9.81 \dfrac{m}{s^{\cancel{2}}}{2.00 \cancel{s}}
= 27.6 \dfrac{m}{s}$
b) How far does it fall in 2.00s
distance formula $d= ut + \dfrac{1}{2}at^2$
so
$d=6.00\dfrac{m}{\cancel{s}}\cdot 2.00\cancel{s}
+ \dfrac{1}{2}\cdot 9.81 \dfrac{m}{s^{\cancel{2}}}{(2.00s)^2}
=12.00m+19.62m=31.6m$
c) What is the magnitude of its velocity after falling 10.0m?
graph $a-t, v-t, \textit{ and } y-t$ graphs for the motion.
ok don't have book answer to these and a little ?? on c} and graph
Mathematics news on Phys.org
so
so
What information does the original problem statement give prior to asking parts (a), (b), and (c)?
4-39 A student throws a water balloon vertically downward from the top of a building. The balloon leaves the thrower's had with a speed of $6.00 m/s$ Air resistance may by ignored, so the water balloon is in free fall after it leaves the throwers hand
motion formula is $v=u+at$
so
so
c) ?
4-39 A student throws a water balloon vertically downward from the top of a building. The balloon leaves the thrower's had with a speed of [FONT=MathJax_Main]6.00[FONT=MathJax_Math]m[FONT=MathJax_Main]/[FONT=MathJax_Math]s Air resistance may by ignored, so the water balloon is in free fall after it leaves the throwers hand
(a) $v(t) = v_0 - gt$
$v(2) = -6 - g(2) = -25.6 \, m/s$
speed is $|v| = |-25.6| = 25.6 \, m/s$
(b) $\Delta y = v_0 t - \dfrac{1}{2}gt^2$
$\Delta y = -6(2) - \dfrac{1}{2}g(2^2) = -31.6 \, m$
(c) $v_f^2 = v_0^2 - 2g \Delta y$
$v_f = -\sqrt{(-6)^2 - 2g(-10)} = -15.2 \, m/s$
$|v_f| = 15.2 \, m/s$
ok, much mahalo
look like I didn't subtract :eek:
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
