- #36
whatif
- 87
- 5
… for consistency.lomidrevo said:Energy and momentum are different quantities, of course. The reason why 4 vectors are introduced in relativity, is not just to have a common units. What is far more important is that time and space individually do not transform properly under Lorentz transformation. You have to transform them together. Hence it becomes natural to talk about spacetime, and to define position 4-vector, where the 0th component represent the timelike coordinate of an event. But you still keep in mind that space and time are not the same, as you know intuitively. The same applies to energy and momentum. They cannot be properly transformed individually, but if you define a 4-vector, which you construct using the classical 3D momentum of a particle plus using its energy as the 0th component, the whole new beast will transform properly under Lorentz transformation. I don't see any reason why we should regard energy as having any direction...
Langauge m2 = E2 – p2 is a relationship between the components of 4 momentum. The timelike component is called energy, not timelike momentum component. For the purposes of the equation we are distinguishing between energy and momentum. The 4 vector does not make this distinction, in the sense that we may not call the timelike part of the vector, energy (mathematically it works). That is OK, so long as we keep track of what is being done.
Does the 4 momentum vector have units of kilograms? I ask because I would think so but you might say no. If so, then these units are a measure of energy in the spacelike direction and momentum in the spatial directions.
How is the timelike part of the 4 momentum vector to be interpreted (what does it mean to have kilograms moving in the time direction)? The answer to this question is left hanging. You might be able to tell me. You might say you do not know, which would be OK. However, it should have meaning. If you cannot tell me then, although it would still difficult to make sense of, I suggest energy moving forward in time is the “obvious” interpretation. It would seem that making the timelike part of the 4 momentum vector, energy, would put 4 momentum energy on a par with how timespace is treated in terms of language and interpretation.
