kodama
- 1,075
- 144
- TL;DR Summary
- significance of 7Li(p,e+e−)8Be direct proton-capture reaction
What is the significance of
there are these papers,
reaction has been studied by observing the α particles from the decay of the 8Be levels at 16.62 and 16.92 MeV by means of a magnetic spectrometer. The yields to both levels are resonant at Ep = 0.44 MeV, the well-known (p, γ) resonance. In addition, the 16.62 MeV level is populated by a direct capture process, confirming the expectation based on 7Li(d, n)8Be threshold and stripping measurements that this level is a single-proton state.
A.V.Dzhazairov-KakhramanovaN.A.Burkovab
Li scattering to the ground
Review of Scientific Instruments 66, 309 (1995); https://doi.org/10.1063/1.1146393
C. Brad Evans and G. W. Cooper
so there is some experimental interest in this reaction.
The reason I ask is this new paper
[Submitted on 16 May 2022]
N.J. Sas, A.J. Krasznahorkay, M. Csatlós, J. Gulyás, B. Kertész, A. Krasznahorkay, J. Molnár, I. Rajta, J. Timár, I. Vajda, M.N. Harakeh
same group, but it seems that 3 different experiments,
nuclear transition of beryllium-8 atoms and in stable helium atoms
and now, the 7Li(p,e+e−)8Be direct proton-capture reaction
all have the same X17 anomaly.
granted it is from same research group, but how hard would it be for other research groups to verify these results?
if other experimental groups also see the same results, that's 3 very different nuclear reactions all having the same x17 anomaly.
there's also this
[Submitted on 8 Aug 2022]
E Cline (for the DarkLight Collaboration)
way back in 2015 https://en.wikipedia.org/w/index.php?title=Attila_Krasznahorkay&action=edit&redlink=1 and his colleagues reported his first result on beryllium-8 nuclear transitions
it's 2022 and AFAIK there's no independent confirmation using beryllium-8
and then 2019 the same anomalies in the decay of stable helium atoms
again in 2022 and AFAIK there's no independent confirmation using the decay of stable helium atoms
in 2022 7Li(p,e+e−)8Be direct proton-capture reaction gives rise to anomalies that can be explained by X17
7Li(p,e+e−)8Be direct proton-capture reaction ?
Slope of the astrophysical S factor for the 7Li(p,γ)8Be reaction
- January 2000
- https://www.researchgate.net/journal/Physical-Review-C-1089-490X 61(1):15802-
The
reaction and single-particle levels in 8Be
Author links open overlay panelJerry B.MarionMarkWilson†Abstract
Thereaction has been studied by observing the α particles from the decay of the 8Be levels at 16.62 and 16.92 MeV by means of a magnetic spectrometer. The yields to both levels are resonant at Ep = 0.44 MeV, the well-known (p, γ) resonance. In addition, the 16.62 MeV level is populated by a direct capture process, confirming the expectation based on 7Li(d, n)8Be threshold and stripping measurements that this level is a single-proton state.
Reaction rate of the 7Li(p,γ)8Be radiative capture at low energies
Author links open overlay panelS.B.DubovichenkoabA.V.Dzhazairov-KakhramanovaN.A.Burkovab
Abstract
Within the framework of the modified potential cluster model with the classification of orbital states according to Young diagrams, the possibility of description experimental data for S-factor of the proton radiative capture on 7Li to the ground state of 8Be is considered. It was shown that taking into account E1 and M1 transitions from the state ofLi scattering to the ground
- An intense proton beam diagnostic using the 7Li(p,γ)8Be →141Pr(γ,n)140Pr(β+) nuclear reaction sequence
- Department of Chemical and Nuclear Engineering, University of New Mexico, Albuquerque, New Mexico 87131
Nuclear Experiment
Observation of the X17 anomaly in the 7Li(p,e+e−)8Be direct proton-capture reaction
Angular correlation spectra of e+e− pairs produced in the 7Li(p,γ)8Be nuclear reaction have been studied at the sharp Ep= 441 keV resonance as well as at Ep= 650 keV, 800 keV and 1100 keV proton beam energies. The spectra measured at the resonance can be understood through the M1 internal pair creation process, but in the case of the off-resonance regions (direct proton capture) significant anomalies were observed in the e+e− angular correlations supporting the X17 hypothetical particle creation and decay.
Cite as: | arXiv:2205.07744 [nucl-ex] |
there's also this
Searching for New Physics with DarkLight at the ARIEL Electron-Linac
The search for a dark photon holds considerable interest in the physics community. Such a force carrier would begin to illuminate the dark sector. Many experiments have searched for such a particle, but so far it has proven elusive. In recent years the concept of a low mass dark photon has gained popularity in the physics community. Of particular recent interest is the 8Be and 4He anomaly, which could be explained by a new fifth force carrier with a mass of 17 MeV/c2. The proposed DarkLight experiment would search for this potential low mass force carrier at ARIEL in the 10-20 MeV e+e− invariant mass range. This proceeding will focus on the experimental design and physics case of the DarkLight experiment.
Comments: | 7 pages, 4 figures, to be submitted as part of the proceedings on "New Scientific Opportunities with the TRIUMF ARIEL e-linac" |
Subjects: | Nuclear Experiment (nucl-ex); Instrumentation and Detectors (physics.ins-det) |
Cite as: | arXiv:2208.04120 [nucl-ex] |
