95% confidence interval on the mean
In summary, a 95% confidence interval on the mean is a statistical measure that provides a range of values within which the true population mean is likely to fall with 95% certainty. This interval is calculated based on a sample mean and sample size, and takes into account the variability of the data. It is commonly used in research and data analysis to assess the precision and accuracy of a sample mean and make inferences about the population mean. A wider confidence interval indicates more uncertainty, while a narrower interval indicates more precision.
eterna
What does it mean?
Is this the interval such that 95% of the means from a sample mean distribution (frequency distribution of means of sample size n) are a certain number of standard deviations from the population mean?
eterna said:
What does it mean?
Does this mean that 95% of the means from a sample mean distribution (frequency distribution of means of sample size n) are a certain number of standard deviations from the population mean?
A 95% confidence interval is an interval that has a 95% chance of overlapping the true, unknown population mean μ. In other words, if you were to repeat the sampling experiment many times you would get many different intervals, but about 95% of them would contain the true mean somewhere inside them. See, eg., http://en.wikipedia.org/wiki/Confidence_interval and look especially at the section entitled "Meaning and Interpretation".
so was what I said a completely wrong way of thinking about it?
I could not make any sense of what you were saying.
Related to 95% confidence interval on the mean
1. What is a 95% confidence interval on the mean?
A 95% confidence interval on the mean is a range of values calculated from a sample of data that is likely to contain the true population mean with 95% confidence. This means that if we were to take multiple samples from the same population, 95% of the time the calculated confidence interval would contain the true population mean.
2. How is a 95% confidence interval on the mean calculated?
A 95% confidence interval on the mean is calculated by taking the sample mean and adding and subtracting the margin of error. The margin of error is determined by the sample size, standard deviation, and desired level of confidence. This calculation is based on the Central Limit Theorem, which states that the sample mean will be normally distributed around the population mean.
3. Why is a 95% confidence interval used?
A 95% confidence interval is commonly used in statistical analysis because it provides a good balance between precision and reliability. It gives a narrow range of values that are likely to contain the true population mean, while still allowing for some margin of error.
4. What does the 95% confidence level mean?
The 95% confidence level refers to the level of certainty that the calculated confidence interval contains the true population mean. It means that if we were to take multiple samples from the same population, 95% of the time the calculated confidence interval would contain the true population mean.
5. How can a 95% confidence interval be interpreted?
A 95% confidence interval can be interpreted as a range of values within which we are 95% confident that the true population mean lies. This means that if we were to take multiple samples from the same population and calculate a confidence interval for each sample, 95% of those intervals would contain the true population mean.
