MHB A bag contains x beads. Calculate the value of x.
  • Thread starter Thread starter Help seeker
    Value
The problem involves calculating the total number of beads, x, in a bag containing 6 red beads and x-6 blue beads, given that the probability of drawing two beads of the same color is 9/17. The probabilities for drawing two red beads and two blue beads are calculated separately, leading to the equation 30/(x(x-1)) + ((x-6)(x-7))/(x(x-1)) = (x^2 - 13x + 72)/(x^2 - x). Setting this equal to 9/17 allows for solving for x. By cross-multiplying and simplifying, the value of x can be determined. The final solution reveals the total number of beads in the bag.
Help seeker
A bag contains x beads. 6 of the beads are red and the rest are blue. Ravish is going to take at random 2 beads from the bag. The probability that the 2 beads will be of the same colour is $9 /17$
Using algebra calculate the value of x. ( show sworking if possible)
Mathematics news on Phys.org
There are 6 red beads and x- 6 blue beads. The probability the first bead taken is red is 6/x. In that case there are 5 red beads and x- 6 blue beads left for a total of x-1 beads. The probability the second bead is also red is 5/(x- 1). The probability the two beads are both red is (6/x)(5/(x- 1))= 30/(x(x- 1)).
There are 6 red beads and x- 6 blue beads. The probability the first bead taken is blue is (x- 6)/x. In that case there are 6 red beads and x- 7 blue beads left for a total of x- 1 beads. The probability the second bead is also blue is (x- 7)/(x- 1). The probability the to beads are both blue is ((x- 6)/x)((x- 7)/(x- 1))= (x- 6)(x-7)/(x(x- 1).
The probability the two beads are the same color is 30/(x(x-1)+ ((x- 6)(x- 7)/(x(x-1))= (x^2- 13x+ 72)/(x^2- x).
Set that equal to 9/17 and solve for x.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
