A ball falls with no force acting on it
  • Thread starter inertiaforce
  • Tags
    Ball Force
In summary: Relative to an observer in the elevator, the ball appears to fall to the ground. What's strange here is that no force is actually acting on the ball - the elevator is just accelerating. This is possible because gravity is not a force, but rather like the accelerating elevator, it's just a redefinition (locally) of what an inertial reference frame is.
inertiaforce
60
If you are standing on the Earth and you drop a ball, the ball falls to the ground due to the force of gravity acting on it.
Now imagine you are in an upward accelerating elevator in space. You let go of a ball that you are holding in your hand. The ball Is stationary in space, but the elevator floor is accelerating upward and hits the ball. This means that relative to an observer standing on the floor of the elevator, the ball appears to fall to the ground. The ball falls in the exact same way as it does when you are standing on the earth.
According to the principle of equivalence, no experiment from inside the elevator can tell whether the ball is falling or whether the elevator is accelerating upward. Therefore, the experience inside an upward accelerating elevator is indistinguishable from the experience of standing on the Earth in the Earth's gravity.
What's strange here is that no force is acting on the ball in the elevator causing it to fall. However, when standing on the earth, the Earth's gravity IS acting on the ball causing it to fall.
So, how can a ball fall inside an elevator WITH NO FORCE ACTING ON THE BALL? How is this possible?
In one situation (standing on the earth), A FORCE is acting on the ball. In the other situation, NO FORCE is acting on the ball. So even though one situation has a force acting on the ball (standing on the earth), and the other situation has no force acting on the ball (elevator), both situations are an identical experience where the ball falls to the ground. How is this possible?
The insight of Einstein is that gravity is not a force, but, rather like the accelerating elevator, simply a redefinition (locally) of what an inertial reference frame is.
That is Newtons model of gravity. In General Relativity, which is based on the equivalence principle, there is no real force acting on free falling objects in a gravitational field. See this animation for comparison:
https://www.youtube.com/watch?v=DdC0QN6f3G4
I may not know Einstein's theory, but, from a Newtonian view, there is no contradiction.
If the elevator is accelerating, shouldn't it take a force to have the ball not fall?
(Because "not falling" means moving with the elevator, which was said to be accelerating.)
Newon's law does not say, "forces act on 'falling' objects," because "falling" can be subjective (as your post illustrates).
To clarify the different explanations:
Newtonian Gravity:
The frame of the Earth's surface is inertial (ignoring rotation etc.): The ball accelerates down due to the force of gravity
The frame of the accelerating box in space is non-inertial: The ball accelerates down due to an inertial force or curvlinear space-time geometry.
General Relativity:
Both frames are non-inertial: The ball accelerates down due to an inertial force or curvilinear space-time geometry.
In a coordinate independent sense, the ball doesn't fall, it travels in a straight line called a geodesic. The elevator is accelerating due to some force and the elevator's path curves up to intersect the ball's geodesic (straight path).
This does not require GRT, just Newton and Galilei.
No force is acting in the rest frame of the ball.
In the rest frame of the elevator however a gravity force IS acting.
Not Newtonian gravity, but an inertial force locally indistinguishable from gravity.
That's right.
Related to A ball falls with no force acting on it
1. What causes a ball to fall with no force acting on it?
In this case, the ball is falling due to the force of gravity. Even though there may not be any other external forces acting on the ball, gravity is still pulling it towards the ground.
2. Will the ball continue to fall forever with no force acting on it?
No, the ball will eventually reach a maximum velocity, known as terminal velocity, due to the resistance of air. Once it reaches this velocity, it will continue to fall at a constant speed.
3. Can a ball fall with no force acting on it in a vacuum?
Yes, in a vacuum where there is no air resistance, the ball will continue to accelerate until it reaches the maximum velocity of freefall.
4. Why does the ball fall straight down with no force acting on it?
Gravity pulls objects towards the center of the Earth, so the ball falls in a straight line towards the ground. This is known as the path of least resistance.
5. Is there any way to stop the ball from falling with no force acting on it?
Yes, you can stop the ball from falling by introducing an opposing force, such as catching it with your hand or placing it on a surface. This will counteract the force of gravity and prevent the ball from falling.
  • Classical Physics
