A ball of mass m is thrown with a velocity v at a disk
The discussion centers on calculating the total initial angular momentum of a ball of mass m thrown at a disk of mass M, which sticks to the disk upon impact. The relevant equation for angular momentum, L = r x p, is utilized, with the cross product indicating the direction of momentum. The specific angular momentum calculated is given as (0, 0, -Rmv), assuming the axis of rotation is through the center of the disk. The right-hand rule is confirmed as a method to determine the direction of angular momentum. The solution is affirmed as correct based on the provided definitions and calculations.
Westin
A ball of mass m is thrown with a velocity v at a disk of mass M which sticks to the rim on impact.https://s3.lite.msu.edu/res/msu/perl_author/P3_PRELECTURE/L_CONSERVATION/IMAGES/CQ1.png
For the system of the ball and disk, what is the total initial angular momentum about the axis?[PLAIN]https://s3.lite.msu.edu/adm/jsMath/fonts/cmsy10/alpha/144/char68.png0,0,Rmv[PLAIN]https://s3.lite.msu.edu/adm/jsMath/fonts/cmsy10/alpha/144/char69.png
[PLAIN]https://s3.lite.msu.edu/adm/jsMath/fonts/cmsy10/alpha/144/char68.png0,0,−Rmv[PLAIN]https://s3.lite.msu.edu/adm/jsMath/fonts/cmsy10/alpha/144/char69.png
[PLAIN]https://s3.lite.msu.edu/adm/jsMath/fonts/cmsy10/alpha/144/char68.png0,−Rmv,0[PLAIN]https://s3.lite.msu.edu/adm/jsMath/fonts/cmsy10/alpha/144/char69.png
[PLAIN]https://s3.lite.msu.edu/adm/jsMath/fonts/cmsy10/alpha/144/char68.png0,Rmv,0[PLAIN]https://s3.lite.msu.edu/adm/jsMath/fonts/cmsy10/alpha/144/char69.png
[PLAIN]https://s3.lite.msu.edu/adm/jsMath/fonts/cmsy10/alpha/144/char68.png0,0,0[PLAIN]https://s3.lite.msu.edu/adm/jsMath/fonts/cmsy10/alpha/144/char69.png[/B]
Cross Product
τ⃗ A=r⃗ A×F⃗
Cross Product
What is your specific question about this question?
Am I correct?
Yes, [PLAIN]https://s3.lite.msu.edu/adm/jsMath/fonts/cmsy10/alpha/144/char68.png0,0,−Rmv[PLAIN]https://s3.lite.msu.edu/adm/jsMath/fonts/cmsy10/alpha/144/char69.png, using the definition of angular momentum as L=r x p and the right-hand rule (presuming the axis is through the axis of the disk).
Right hand rule?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
