A charge inside a non conducting spherical shell uniformly charged
A positive charge placed randomly inside a uniformly charged non-conducting spherical shell experiences no net force due to the shell's charges, as confirmed by Gauss's law. The electric field inside the shell is zero because the effects of the shell's charges cancel out regardless of the charge's position. The confusion arises when considering multiple charges inside the shell, which can interact with each other but remain unaffected by the shell. This situation parallels gravitational forces, where a uniformly dense spherical shell exerts no force on masses within it. Thus, the conclusion is that the charge inside the shell does not experience any force from the shell itself.
tmn50
This problem is driving me mad
suppose that we have a positive charge inside a non conducting spherical shell uniformly charged
the charge is at a random place inside the shell but not in the center
the textbook says the charge will feel no force from the charges of the shell and the argument is based on gauss law when there's no charge inside the shell
this is true but when we put the charge inside everything changes
if we apply gauss law
we choose a gaussian surface that has the same center as the shell with a radius that's big enought to contain only the emptiness before the charges of the shell (if we can say that)
so there will be an electric field that will act on the charges
so either the charge moves or the shell moves
this is what i could conclude
please tell me where did i go wrong
I apologize for not following the pattern cause this isn't really a problem just a case that was mentioned in the lecture and i didn't understand
I'm confused as to what the situation is.
If there is only 1 charge inside the charged shell, the force on that point charge is zero, since the shell charges' effects cancel each other at the inside charge no matter where that charge is located. This is what your problem seems to state.
What you say after that I can't follow. If you assume two (or more) charges within the charged shell then those inside charges will attract or repel each other but still none of those inside charges will be affected by the charged shell.
It's no different than the fact that a uniformly dense spherical shell does not generate a gravitational force inside the shell. The shell simply does not exist as far as masses inside the shell are concerned. And it's exactly the same situation with the charges, since electrostatic and gravitational forces both vary inversely as the square of the distance.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
