MHB A complex number problem that has been vexing me....
The discussion revolves around proving that for three distinct complex numbers \( z_1, z_2, z_3 \) with equal magnitudes, the condition that \( z_1 + z_2 z_3, z_2 + z_1 z_3, z_3 + z_1 z_2 \) are all real leads to the conclusion that \( z_1 z_2 z_3 = 1 \). The initial approach involved expressing the complex numbers in polar form and equating imaginary parts to derive relationships between their angles. A key insight was recognizing that if \( \cos(2\theta_1 + \theta_3) = \cos(2\theta_2 + \theta_3) \), it implies either the angles are equal or related by a negative reflection, ultimately leading to the conclusion that \( \theta_1 + \theta_2 + \theta_3 = k\pi \). The discussion emphasizes that the proof can be refined to avoid any perceived "fudging," and a geometric proof is suggested as a potential alternative. The thread concludes with an acknowledgment of the collaborative effort to clarify the proof.
MarkFL
MHB
Recently, on another forum, the following problem was posted:
Given three distinct complex numbers:
$\displaystyle z_1,z_2,z_3$
where:
$\displaystyle |z_1|=|z_2|=|z_3|\ne0$
and:
$\displaystyle z_1+z_2z_3,z_2+z_1z_3,z_3+z_1z_2$
are all real, then prove:
$\displaystyle z_1z_2z_3=1$
I began with:
$\displaystyle z_1=re^{\theta_1 i}$
$\displaystyle z_2=re^{\theta_2 i}$
$\displaystyle z_3=re^{\theta_3 i}$
where $\displaystyle 0\le\theta_n<2\pi$
For the 3 expression that are real, I equated the imaginary parts to zero, which gives:
$\displaystyle \sin(\theta_1)+r\sin(\theta_2+\theta_3)=0$
$\displaystyle \sin(\theta_2)+r\sin(\theta_1+\theta_3)=0$
$\displaystyle \sin(\theta_3)+r\sin(\theta_1+\theta_2)=0$
I next solved the first two equations for r, and equated, to find:
$\displaystyle \sin(\theta_1)\sin(\theta_1+\theta_3)=\sin(\theta_2)\sin(\theta_2+\theta_3)$
Using a product-to-sum identity, this implies:
$\displaystyle \cos(2\theta_1+\theta_3)=\cos(2\theta_2+\theta_3)$
Given that the angles $\displaystyle \theta_n$ must be distinct, I used:
$\displaystyle \cos(2\theta_1+\theta_3)=\cos(2\theta_2+\theta_3-4\pi)$
From which I obtained:
$\displaystyle \theta_1+\theta_2+\theta_3=2\pi$
However, I was told by someone whose judgement is extremely sound that I was "fudging" here.
Would it also be "fudging" to redefine the angles with:
$\displaystyle -\pi\le\theta_n<\pi$
and then use:
$\displaystyle \cos(2\theta_1+\theta_3)=\cos(-2\theta_2-\theta_3)$
to obtain:
$\displaystyle \theta_1+\theta_2+\theta_3=0$
I admit, this seems to merely be the same "fudge" I used before.(Rofl)
Can anyone offer a hint or nudge in the right direction?
Mathematics news on Phys.org
where:
and:
I began with:
Up to that point, your argument is completely watertight. To avoid the fudge in what follows, continue like this.
First, given $\phi, \ \psi$ with $\cos\phi=\cos\psi$, it must be true that either $\psi=\phi+2k\pi$ or $\psi=-\phi+2k\pi$ (for some integer $k$). Applying that to the equation $\cos(2\theta_1+\theta_3)=\cos(2\theta_2+\theta_3)$, you see that either $2\theta_1+\theta_3 = 2\theta_2+\theta_3 + 2k\pi$ or $2\theta_1+\theta_3 = -(2\theta_2+\theta_3) + 2k\pi$. But the first of those alternatives implies that $\theta_1 = \theta_2$, which is not allowed. Therefore the second alternative holds, from which you get $\theta_1 + \theta_2 + \theta_3 = k\pi.$
If you then go back to the equation $\sin(\theta_1)+r\sin(\theta_2+\theta_3)=0$, you can deduce that $k$ must be an even number (otherwise both terms on the left side of that equation would have the same sign). Consequently $\sin(\theta_2+\theta_3) = -\sin\theta_1$, from which it follows that $r=1$. From there it is easy to see that $z_1z_2z_3 = 1.$
I would say that your proof is essentially sound and that the fudge is easily removable. I would prefer to see a more geometric proof of this result, but I don't have any idea of how that might go.
Thank you! :cool:
I did actually consider:
$\displaystyle \theta_1+\theta_2+\theta_3=k\pi$
but I never thought to use one of the 3 equations arising from the conditions on the 3 given expressions being real to show that k must be even. (Smile)
When I fix my argument, I will give you credit for the suggested fix!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
