A cyclist exerts 80N of energy pedalling. How much Work is done?
  • Thread starter Thread starter Daaniyaal
    Energy Work
The cyclist exerts 80N of force while pedaling, and the diameter of the pedal circle is 36 cm. To calculate work done, the formula W=F•d is used, where d is the distance traveled. The circumference of the pedal circle, calculated as π times the diameter, is relevant for determining the distance in one full stroke. There is some confusion regarding the application of centripetal force and whether the downward force affects the distance calculation, but the consensus is that the full circumference should be considered for work done in this context.
Daaniyaal
Cyclist pedals downward stroke with 80N of energy. The diameter of the circle traced by his pedals is 36 cm, how much work is done each stroke?
W=F•d
I figured that the force exerted downwards means half of the circle traced, which would mean that it would be 80 N per 18 centimetres. It was not so. does centripetal stuff have anything to do with this?
The downward thing is just describing the stroke so I believe the problem is telling you that with one stroke, the rider produces 80 N of force forward, so if the diameter is 36 cm, the linear distance in one stroke would be 1 circumference.
If you have ridden a conventional bicycle, you'll have noticed how while standing on the pedals you can force your foot DOWNWARDS for almost the whole depth of the circle traced by the pedals. You stand vertically, so your leg is exerting the main component force vertically downwards. (You do need to exert a small force tangentially to encourage the pedals to continue turning at the top & bottom of the path, but that tangential force is slight and does insignificant work in relation to that of the main downwards thrust.)
Work done = force • distance through which that force acts
(I've retained that dot you used, as it is very appropriate.)
I thank thee profusely, and I am honoured that my dot is appropriate. I bashed random buttons on my keyboard till it came out.
W=F•d
You can use the equation for work: W=F * D where D is the distance.
Substitute for D: D = circumference = pi * d, where d is the 0.36 meter diameter. Now the rest of the calculations should be self explanatory.
As I indicated in bold, I do not believe circumference is the applicable distance in this problem.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
