A decreasing sequence of images of an endomorphisme
In summary: Yes, but I do not mean that ##f^n## is injective. This would have to be proven first. But we know that ##f## is injective, so we can write it the other way around: ##f^n(x)=f(f^{n-1}(x))## and use injectivity of ##f^1##.
steenis
312
Let ##M## be a left R-module and ##f:M \to M## an R-endomorphism.
Consider this infinite descending sequence of submodules of ##M##
##M \supseteq f(M) \supseteq f^2(M) \supseteq f^3(M) \supseteq \cdots (1)##
Can anybody show that the sequence (1) is strictly descending if ##f## is injective and ##f## is NOT surjective ?
So you have to prove that ## f^n(M) \neq f^{n+1}(M)## for all ##n > 0##, given that ##f## is injective and ##f## is not surjective.
Of course ##M \neq f(M)##.
Can someone help me with this?
You could prove the alternative definition of injectivity:
##f\, : \,M \longrightarrow N## is injective if and only if for all sets ##M'## and all ##g,h\, : \, M' \longrightarrow M## holds ##f\circ g = f \circ h## implies ##g=h##.
and apply it to the given situation.
Thank you for your suggestion, but I do not see how to apply this. Can you give me one more hint, please?
Usually we have ##f(x)=f(y) \Longrightarrow x=y##, i.e. a left cancellation of ##f##. The definition I gave says, this is also true for mappings. Given any functions of sets, then ##f\,g=f\,h \Longrightarrow g=h## is the same as injectivity.
Now assume ##f^n(M)=f^{n+1}(M)##. This means ##f\circ f^{n-1} = f \circ f^n ## and by the alternative definition ##f^{n-1} = f^n.## You can either assume ##n## to be minimal, proceed by induction or simply say etc. to achieve a contradiction, because you end up with ##\operatorname{id}_M=f## which is surjective.
So all you have to show is, that the two definitions are equivalent.
Sorry, see the next post.
I am sorry. fresh_42, but i found a glitch. I think your answer is not correct. ##f^n(M)=f^{n+1}(M)## does not mean that ##f^n(x)=f^{n+1}(x)## for all ##x \in M##. It means that the two sets ##f^n(M)=\{f^n(x) | x \in M \}## and ##f^{n+1}(M)=\{f^{n+1}(x) | x \in M \}## are equal. So, one cannot conclude that ##f^n=f^{n+1}##.
Sorry I was too quickly.
But isn't the idea the same? Assume ##f^n(M)=f^{n+1}(M)## as sets. Then for all ##x \in M## there is an ##y\in M## such that ##f^n(x)=f^{n+1}(y)##. This leads to ##x=f(y)## and again surjectivity.
I do not see it. ##f^n(x)=f^{n+1}(y)## does not lead to ##f\circ f^{n-1} = f \circ f^n## and so on.
You mean, because ##f^n## is injective ? Then ##f^n(x)=f^nf(y)## and ##x=f(y)##.
steenis said:
I do not see it. ##f^n(x)=f^{n+1}(y)## does not lead to ##f\circ f^{n-1} = f \circ f^n## and so on. Can you be more specific, please?
Answer the following questions, one by one.
What does ##f^n(M)=f^{n+1}(M)## mean in terms of elements?
If we consider this elementwise equation, can we cancel an ##f\,##?
Is this cancellation repeatable?
With which equation will we end up?
What does this last equation express?
Our posts crossed, I edited my former post.
I am interested in what you meant.
But ##f^n## is injective is easy to prove, if ##h:A \to B## is injective and ##g:B \to C## in injective, then ##g \circ h:A \to C## is injective.
If it is this easy, why didn't I see it ?
I assume because you were caught in the ring theoretic view of things and the other definition forced you to look more generally on it. Btw., do you know an example of such a chain?
##\mathbb{Z}## is not artinian.
Define ##f:\mathbb{Z} \to \mathbb{Z}:n \mapsto 2n##.
Then the sequence becomes
##(2) \supset (4) \supset (8) \supset \cdots \supset (2^n) \supset \cdots##
decreasing and not terminating
Thanks for showing me the way.
Likes fresh_42
If f:S-->T is injective, and U is a proper subset of S, then f(U) is strictly smaller than f(S). QED.
Proof ?
Lemma: If f:S-->T is injective, and U is a proper subset of S, then f(U) is a proper subset of f(S).
proof: by definition of injectivity, if U is a subset of S, then f(S) is the disjoint union of f(U) and f(S-U), and since U is a proper subset of S, both S-U and f(S-U) are non empty, hence f(U) is a proper subset of f(S), since it is missing the points of f(S-U).
More simply perhaps, if x is a point of S which is not in U, then f(x) is a point of f(S) which is not in f(U). I.e. since f is injective, and since all points of U are different from x, no point of U can map to the point f(x). I hope it is clear this follows immediately from the meaning of injectivity.
Corollary: Since by hypothesis in your problem we have f not surjective, hence f(M) is a proper subset of M, it follows that f(f(M)) is a proper subset of f(M). Continuing, we have the result you want, i.e. then also f(f(f(M))) is a proper subset of f(f(M)), ...etc.
"by definition of injectivity, if U is a subset of S, then f(S) is the disjoint union of f(U) and f(S-U), and since U is a proper subset of S, both S-U and f(S-U) are non empty, hence f(U) is a proper subset of f(S), since it is missing the points of f(S-U)"
I really do not understand what you are saying here.Your second proof is easier, but why not write it down like this:
##U \subset S## proper, so there is an ##x \in S## such that ##x \notin U##. Suppose ##fx \in fU##, then there is a ##y \in U## such that ##fx = fy##, by the injectivity of ##f## we have: ##x = y \in U##, contradiction, so ##fU \subset fS## proper
It is the same but much easier to read.
well done. but i am puzzled why you had to ask how to prove this, since you did it so nicely. did you try it before asking?
edit: I have had an idea as to why this proof was not obvious and I suggest the following:
lemma: a function f:S-->T is injective if and only if whenever U,V are disjoint subsets of S, then f(U) and f(V) are disjoint subsets of T.
Try proving this. I am sure you can do it easily. This statement seemed obvious to me, and I more or less took it for granted in giving a brief solution to this problem, but for someone just meeting the notion of injectivity, it might not be. It may help to draw a picture of an injective function, which just faithfully embeds the domain into the range. I think this more global view of injectivity is more useful then the bare definition involving only two (arbitrary) domain points.
Related to A decreasing sequence of images of an endomorphisme
1. What is an endomorphism?
An endomorphism is a mathematical function or mapping that maps a mathematical object (such as a vector space, group, or ring) to itself. In other words, it is a function that takes an element from the same set and produces another element from the same set.
2. What is a decreasing sequence of images?
A decreasing sequence of images of an endomorphism is a series of images or outputs generated by applying the same endomorphism repeatedly, with each output being smaller than the previous one. This can also be thought of as a sequence of nested sets, where each set is contained within the previous one.
3. How are endomorphisms used in science?
Endomorphisms are used in various fields of science, including mathematics, physics, and computer science. They are particularly useful in linear algebra, where they can be used to study vector spaces and linear transformations. In physics, endomorphisms are used to describe symmetries and conservation laws. In computer science, endomorphisms are used in areas such as cryptography and data compression.
4. What does it mean for a sequence of images to be decreasing?
A decreasing sequence of images means that each image or output in the sequence is smaller than the previous one. This can be in terms of size, magnitude, or any other measurable quantity. In the context of an endomorphism, this means that each successive output is a "simpler" version of the previous output.
5. Can a decreasing sequence of images of an endomorphism be infinite?
Yes, a decreasing sequence of images of an endomorphism can be infinite. This means that the process of applying the endomorphism can continue indefinitely, producing an infinite number of outputs. This is often the case in theoretical mathematics, where infinite sequences are commonly studied.
  • Linear and Abstract Algebra
