MHB A Density Problem and a Mass Problem
  • Thread starter Thread starter geissingert
    Density Mass
To solve the first problem regarding the gold coin, the volume can be calculated using the formula v = m/d, but it's crucial to convert the mass from grams to kilograms for consistent units. The density of gold is given as 19300 kg/m3, so the calculation should be v = 9.25 x 10^-3 kg / 19300 kg/m3. In the second problem about the helium balloon, the mass of helium also requires consistent units; the density should be converted to kg/m3 or the volume to cm3. Both problems highlight the importance of unit consistency in calculations for accurate results.
geissingert
Hoping you can give input. I need you to show work and explain. Here is what we have:1. A gold coin has a mass of 9.25 grams. What is its volume if the density of gold is 19300 kg/m3?
v= m/d
v= m 9.25 g/d 19300kg/m3
Not sure how and what to do...please help2. A helium filled balloon has a volume of 4.5 m3. What mass of helium does it hold if the density of helium is 1.8x 10-4 g/cm3?
v=4.5 m3
d=1.8x10-4g/cm3
m=dxv
m= 1.8x10-4g/cm3x4.5m3
100cm/1m
m3/m=m2
100cm/1mx100cm/1mx100cm/1m
1000000
m=1.8x10-4 gx4.5 x100x100x100
1.8 x100x100x100
1.000008
180 x 4.5= 810
m=810 (My answer, is this correct?)
Mathematics news on Phys.org
On problem 1, you have the right idea, but you have mixed units: grams versus kilograms. Make sure you have consistent units! So your computation should be
$$V=\frac{m}{\rho}=\frac{9.25\times 10^{-3}\;\text{kg}}{1.93\times 10^{4}\;\text{kg/m}^{3}}=\dots$$
The same exact issue plagues your second problem. You must get consistent units! Either convert your volume to cubic centimeters, or convert your density to kilograms per cubic meter.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
