A free-falling sky-diver. Using ODE and Variable Separation
In summary: This is consistent with the solution obtained in part (b) of the question. In summary, the equation of motion for a free-falling sky-diver experiencing air resistance can be written as dv/dt = -g + (k/M) v^2, and the initial velocity, v(0), is sqrt(Mg/k). Using the given solution for v(t), it can be shown that there exists a limiting or terminal velocity, vL, such that v(t) tends to vL as t tends to infinity. The value of vL is sqrt(Mg/k).
Richard Platt
A free-falling sky-diver of mass M jumps from an aeroplane and beforen he opens his parachute experiences air resistance which is proportional to the square of the magnitude of his velocity.
a) Show that the equation of motion for the sky-diver can be written as
where v is the magnitude of the sky-diver's velocity, k is the proportionality constant for the air resistance and g is the gravitational constant.
b) What initial data concerning, v(0), is consistent with the following solution
the of differential equation obtained in part (a) of this question,
v(t) = square root ((Mg/k) ((e^-At - 1/ e^-At + 1)) ;
where
A = 2* (square root gk/M)
c) Using the expression for the velocity obtained in part (b) of this question, show that there exists a limiting or terminal velocity, vL, such that
v(t) tends to vL, t tends to infinity.
What is vL?
Within the Question
I'm stuck on (b).
dv/(kv^2-Mg)= dt/M
Intregrate both sides;
(1/2kv) ln |kv^2-Mg|= t/m + c?
Then what to do..? Something to do with with Ae^(-kt/M)..?
To solve for the initial velocity, we can set t=0 and solve for v(0).
(1/2kv(0)) ln |kv(0)^2-Mg|= 0 + c
c= (1/2kv(0)) ln |kv(0)^2-Mg|
Now, we can plug in the given solution for v(t) into the equation and solve for v(0).
v(t) = sqrt((Mg/k)(e^-At - 1/ e^-At + 1))
v(0) = sqrt((Mg/k)(e^0 - 1/ e^0 + 1))
v(0) = sqrt((Mg/k)(1 - 1 + 1))
v(0) = sqrt(Mg/k)
Therefore, the initial velocity, v(0), is sqrt(Mg/k).
Related to A free-falling sky-diver. Using ODE and Variable Separation
1. What is ODE and why is it used in this context?
ODE stands for Ordinary Differential Equation, which is a type of mathematical equation used to model the behavior of a system or process over time. In the context of a free-falling sky-diver, ODE is used to describe the motion of the sky-diver as they fall through the air.
2. What is Variable Separation and how does it relate to the free-falling sky-diver?
Variable Separation is a technique used to solve ODEs by separating the independent and dependent variables in the equation. In the case of a free-falling sky-diver, this technique can be used to solve for the position, velocity, and acceleration of the sky-diver as they fall through the air.
3. How is the motion of a free-falling sky-diver affected by external factors such as air resistance?
The motion of a free-falling sky-diver is affected by external factors such as air resistance, also known as drag. As the sky-diver falls, they experience an upward force from the air resistance, which increases as their speed increases. This force opposes the downward force of gravity, resulting in a terminal velocity where the two forces are equal and the sky-diver falls at a constant speed.
4. Can ODE and Variable Separation be used to model the motion of a sky-diver with a parachute?
Yes, ODE and Variable Separation can be used to model the motion of a sky-diver with a parachute. In this case, the equation would need to include additional variables such as the size and shape of the parachute, as well as the air resistance it creates. This would result in a more complex ODE that would need to be solved using numerical methods.
5. How accurate is the model of a free-falling sky-diver using ODE and Variable Separation?
The accuracy of the model of a free-falling sky-diver using ODE and Variable Separation depends on the assumptions and simplifications made in the equation. For example, the model may not take into account factors such as air turbulence or the changing density of the air at different altitudes. As such, the model may provide a good approximation of the sky-diver's motion, but may not be entirely accurate in real-world scenarios.
