A function without a maximum and a minimum
James LeBron
Give an example of a non-continuous function on [0,1] that has no maximum and no minimum.
Well, a continuous function on a non-empty compact set will have a maximum and a minimum, so I guess this is why we need a non-continuous function.
Does this work?
f(x) =
1/2 if x is a rational number
x if x is an irrational number.
Does this work? Breaking this up into 1/2s (if rational) and x's (if irrational) hopefully makes it non-continuous, and I suppose there is always some larger number that could be formed as we approach 1 (so no maximum). What do you think?
I would agree.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
