elias001
- 389
- 30
- TL;DR Summary
- Question about online answer about a question concerning a proposition concerning ##A_\mathfrak{p}/\mathfrak{a}_\mathfrak{p}\cong (A/\mathfrak{a})_{\mathfrak{p}/\mathfrak{a}}##
I asked online questions about Proposition 2.1.1:
The answer I got is the following:
I have some questions about the answer I got.
When the person answering says:
##1.##
Is the map ##\mathfrak{q}\mapsto \mathfrak{q} A _\mathfrak{p}## from ##A\setminus \mathfrak{p}\to A_\mathfrak{p}##?
But I don't understand what the author meant for the rest of the sentence in mathematical notation:
##2.##
In the next statement where the author says:
How is ##A\to A_\mathfrak{p}## this a contraction map? and
How is it "used to prove the statement in Prop 2.1.1 about maximality of ##\mathfrak{p} A_\mathfrak{p}## in ##A_\mathfrak{p}## and the statement immediately following it"
##3.##
In the second sentence of Proposition 2.1.1, what does the phrase: "runs once through the prime ideals..." precisely in mathematical notation.
Thank you in advance.
Question
For the proof of the Proposition 2.1.1 at the end of the Background section below, the text make use of Proposition 3.5 preceding Definition 6.6. Is it possible to use the classic method of the first isomorphism theorem by constructing a surjective homomorphic map and finding the kernel of the map. Basically, we let:
##m,s\in A##, and ##\bar{(\frac{m}{s})}=\frac{m}{s}+\mathfrak{a}_{\mathfrak{p}}##
then ##\frac{A_\mathfrak{p}}{\mathfrak{a}_\mathfrak{p}}=\{\bar{(\frac{m}{s})}\mid m\in A, s\not\in P\}=\{\frac{m}{s}+\mathfrak{a}_{\mathfrak{p}}\mid m\in A, s\not\in P\}##
and since ##(\frac{A}{\mathfrak{a}})_{\frac{\mathfrak{p}}{\mathfrak{a}}}## denotes the localization of the quotient ring ##\frac{A}{\mathfrak{a}}## at the ideal ##\frac{\mathfrak{p}}{\mathfrak{a}}##. Also
let ##\bar{m}, \bar{s}\in \frac{A}{\mathfrak{a}}## where ##\bar{m}=m+\mathfrak{a}, \bar{s}=s+\mathfrak{a}##. So
##(\frac{A}{\mathfrak{a}})_{\frac{\mathfrak{p}}{\mathfrak{a}}}=\{\frac{\bar{m}}{\bar{s}}\mid \bar{s}\not\in \frac{\mathfrak{p}}{\mathfrak{a}}\}=\{\frac{m+\mathfrak{a}}{s+\mathfrak{a}}\mid s+\mathfrak{a} \not\in \frac{\mathfrak{p}}{\mathfrak{a}} \}##
We define the map: ##f:A_\mathfrak{p}\to (A/\mathfrak{a})_{\mathfrak{p}/\mathfrak{a}}## as ##\frac{m}{s}+\mathfrak{a}_{\mathfrak{p}}\mapsto \frac{m+\mathfrak{a}}{s+\mathfrak{a}}##
with ##\mathrm{ker}f\;=\mathfrak{a}A_\mathfrak{p}=(A-\mathfrak{p})^{-1}\mathfrak{a}=\mathfrak{a}_\mathfrak{p}=\{\frac{m}{s}\mid m\in \mathfrak{a}, s\not\in\mathfrak{p}\}##.
Also since ##\mathfrak{a}_\mathfrak{p}## is an ideal extension, then
##\mathfrak{a}_\mathfrak{p}=\{\sum_i \frac{m_i}{s_i}\mid m_i\in \mathfrak{a}, s_i\not\in\mathfrak{p}\}=\{\frac{\sum_{j} m_j\left(\prod_{i \neq j} s_i\right)}{\prod_i s_i}\mid m_j\in \mathfrak{a}, s_i\not\in\mathfrak{p}\}##.
One thing I don't know how to deal with is how do I account for the map ##\mathfrak{q}\mapsto \mathfrak{q}A_{\mathfrak{p}}## in the statement of the theorem in my proof?
Background
The following is taken from
Algebra Vol 2 by Luthar and Passi
3.5 Proposition. Let ##\mathfrak{a}## be an ideal of $A$, and $\bar{S}$ be the image of ##S## in ##\bar{A}=A/\mathfrak{a}##. Then there exists a unique isomorphism ##\eta## of $S^{-1}A/S^{-1}\mathfrak{a}## with ##\bar{S}^{-1}\bar{A}## which maps ##(\mathfrak{a}/s)^{-1}## to ##\bar{\mathfrak{a}}/\bar{s}##.
Definition 6.6. The ring ##(A-\mathfrak{p})^{-1}A## is a local ring and is called the ##\textit{localization of ##A## at its prime ideal}## ##\mathfrak{p}## be denoted by ##A_\mathfrak{p}##, and it is defined as $$A_\mathfrak{p}=\{a/s\mid a\in A, s\not\in\mathfrak{p}\}$$
If ##\mathfrak{a}## is an ideal of ##A##, it is customary to denote the extension of ##\mathfrak{a}A_\mathfrak{p}=(A-\mathfrak{p})^{-1}\mathfrak{a}## of ##\mathfrak{a}## in ##A_\mathfrak{p}## by ##\mathfrak{a}_\mathfrak{p}##. Thus ##\mathfrak{a}_\mathfrak{p}## consists of elements of the form ##\frac{a}{s}##, ##a## in ##\mathfrak{a}## and ##s\not\in \mathfrak{p}##.
2.1.1 Proposition. The ring ##A_\mathfrak{p}## is a local ring with maximal ideal ##\mathfrak{p}A_\mathfrak{p}##. As ##\mathfrak{q}## runs once through the prime ideals of ##A##, contained in ##\mathfrak{p}##, the ideal ##\mathfrak{q}A_\mathfrak{p}## of ##A_\mathfrak{p}## runs once through the prime ideals of ##A_\mathfrak{p}##. For any ideal ##\mathfrak{a}## of ##A##, contained in ##\mathfrak{p}##, we have
$$A_\mathfrak{p}/\mathfrak{a}_\mathfrak{p}\cong (A/\mathfrak{a})_{\mathfrak{p}/\mathfrak{a}}.$$
In particular, ##A_\mathfrak{p}/\mathfrak{p}A_\mathfrak{p}## is isomorphic to the field of fractions of ##A/\mathfrak{p}##.
The isomorphism ##(S/\mathfrak{a})^{-1}(A/\mathfrak{a})\cong S^{-1}A/S^{-1}\mathfrak{a}## in Prop 3.5 is proved by the authors using the First Isomorphism Theorem, so applying it to the case ##S=A-\mathfrak{p}## as in Prop 2.1.1 is essentially the proof you wanted.
As for the map ##\mathfrak{q}\mapsto \mathfrak{q} A _\mathfrak{p}##, this is the map from prime ideals of ##A## disjoint from ##A-\mathfrak{p}## to prime ideals of ##A_\mathfrak{p}## given by extension of ideals along the localization map ##A\to A_\mathfrak{p}## as in Prop 1.3.10 and Prop 3.3. As stated in the propositions, this is a bijection with inverse given by the contraction map along ##A\to A_\mathfrak{p}##, which is used to prove the statement in Prop 2.1.1 about maximality of ##\mathfrak{p} A_\mathfrak{p}## in ##A_\mathfrak{p}## and the statement immediately following it.
##1.##
....given by extension of ideals along the localization map ##A\to A_\mathfrak{p}## as in Prop 1.3.10 and Prop 3.3
##2.##
##3.##
