A moving magnet in a linear electric field
In summary, a moving magnet in a linear electric field refers to the phenomenon where a magnet is placed in a straight path and experiences a force due to the presence of an electric field. This force is perpendicular to both the magnetic field and the direction of motion of the magnet and is known as the Lorentz force. The strength of the force depends on the strength of the magnetic field, the magnitude of the electric field, and the velocity of the magnet. This principle is crucial in understanding the behavior of charged particles in electromagnetic fields and has numerous applications in industries such as electric motors and generators.
GregM
If a electrically charged mass travels thru a magnetic(m) field, it will accelerate at right angles to its velocity and the m-field. Under some conditions like this the charged mass will travel in a circular loop due to this magnetic force acceleration. This info is all over the internet. e.g.
https://courses.lumenlearning.com/b...on-of-a-charged-particle-in-a-magnetic-field/
What about a moving magnet in an electric field? A similar effect? Seems not a word has ever been written about it. Google returns nothing. Perhaps no-one has ever thought to do this experiment. Potential for a ground breaking 19th century style experiment here. Which one of us will be the neo Faraday? I wonder what the Heaviside equations predict.
problem with the heaviside equations is they associate electric charge with mass, but not magnetic charge. Its harder to see how magnetic mass experiences force.
can't they just report the results of dropping a bar magnet between 2 large long capacitor plates? Debate about interpretation of the results should come later.
https://link.springer.com/article/10.1140/epjp/i2014-14215-y
https://iopscience.iop.org/article/10.1088/0143-0807/32/4/003/meta
https://iopscience.iop.org/article/10.1088/0143-0807/33/1/L02
https://iopscience.iop.org/article/10.1088/0143-0807/33/1/L03/meta
Those papers contradict each other because they're all wrong. A magnetic would require an inhomogeneous magnetic field to feel a force. There are some papers claiming that a moving magnet acquires an electric dipole moment, but they are also wrong.
Likes vanhees71
But the latter is correct. If you have a permanent magnet and view it from an inertial frame, where it's moving there's also an elecctric dipole moment. It's because the electric and magnetic polarizations of a medium are components of an antisymmetric 2nd-rank Minkowski tensor in a similar way as the electric and the magnetic field are components of such an antisymmetric tensor. The only difference is that due to the historical misconception of magnetization there's a sign change. So you have
$$F^{0j}=-F^{j0}=-E^j, \quad F^{jk}=-\epsilon^{jkl} B^l$$
and
$$P^{0j}=-P^{j0}=p^j, \quad P^{jk}=+\epsilon^{jkl} m^l,$$
where ##\vec{E}## are the electric, ##\vec{B}## the magnetic field components and ##\vec{p}## the electric and ##\vec{m}## the magnetic polarization of the matter.
Thus an uncharged permanent magnet which has only a magnetization in its rest frame has both an electric polarization and a magnetization in any other inertial frame.
"the electric and magnetic polarizations of a medium are components of an antisymmetric 2nd-rank Minkowski tensor"
There's no proof of that for a permanent magnet.
That's standard relativistic electrodynamics.
I didn't realize that was the proof.
FAQ: A moving magnet in a linear electric field
What is a moving magnet in a linear electric field?
A moving magnet in a linear electric field refers to a situation where a magnet is in motion within a uniform electric field. This can occur in various scenarios, such as a magnet moving through a wire or a magnet moving between two charged plates.
How does a moving magnet in a linear electric field produce an electric current?
When a magnet moves through a uniform electric field, it experiences a force due to the interaction between the magnetic field of the magnet and the electric field. This force causes the electrons in the magnet to move, creating an electric current.
What is the relationship between the speed of the magnet and the electric current produced?
The speed of the magnet and the electric current produced are directly proportional. This means that as the speed of the magnet increases, the electric current also increases. Similarly, if the speed of the magnet decreases, the electric current decreases.
How does the direction of the magnetic field affect the direction of the electric current?
The direction of the magnetic field and the direction of the electric current are perpendicular to each other. This means that if the magnetic field is moving horizontally, the electric current will be moving vertically, and vice versa.
What are some real-life applications of a moving magnet in a linear electric field?
One common application is in electric generators, where a magnet is rotated within a coil of wire to produce electricity. Another application is in particle accelerators, where magnets are used to create a linear electric field to accelerate charged particles. Additionally, this concept is used in many electronic devices, such as loudspeakers and electric motors.
