A positive charge of magnitude Q1 = 8.5 nC is located....
A positive charge Q1 of 8.5 nC is at the origin, while a negative charge Q2 of -8.5 nC is positioned 16.5 cm along the x-axis. The electric field at point P, located 7.5 cm above charge Q2, needs to be calculated specifically for its x-component. The user initially calculated the electric field using the wrong formula, leading to an incorrect result. After clarification, the correct approach involves using the formula Efield = (K)(Q)/(r^2) to find the accurate x-component of the electric field.
brioches
A positive charge of magnitude Q1 = 8.5 nC is located at the origin. A negative charge Q2 = -8.5 nC is located on the positive x-axis at x = 16.5 cm from the origin. The point P is located y = 7.5 cm above charge Q2. Calculate the x-component of the electric field at point P due to charge Q1. Write your answer in units of N/C.
Efield = (K)(Q)/(r2)
I found the E-field created by Q1 by doing (k)(Q1)/(r2). I found r to be .18125 by performing the Pythagorean Theorem on the x and y legs. I then multiplied this answer by x/r because it asks for just the x-component, which is the E-field times cos(θ), and cos(θ) is adjacent/hypotenuse. I got 421.506 for the E-field and .910345 for cos(θ), and after multiplying these, I got 383.716, which is not the right answer. Any help is much appreciated.
brioches said:
I got 421.506
You seem to have used kq/r, not kq/r2.
Likes brioches
Welp, that was definitely it. Thanks so much!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
