Insights A Possible AI Modern Video Codec
  • Thread starter Thread starter bhobba
    Ai Video
The discussion addresses several technical aspects of video encoding and image processing, specifically focusing on H264, EVC Base Line, and the Bayer filter. It clarifies misconceptions about Bayer filters, emphasizing that they are unrelated to data compression. The conversation critiques the notion that an 8K stream can be simplified into "four 4K streams," highlighting alternative representations. The term "Invertible" is noted as unconventional in this context. Additionally, the discussion mentions that a 40dB signal-to-noise ratio is significant, contrasting it with the higher S/N ratios of analog NTSC cameras, which typically range around 60dB.
Technology news on Phys.org
There is lots of iffy and confused statement in there. Bayer filters have nothing to do with data compression. The data in an 8k stream is not organized into "four 4 K streams", but can be represented in a number of other ways. The use of the word "Invertible" is strange and non-standard. A 40db signal to noise ratio is quite observable; Analog NTSC cameras would bost s/n in the 60db range.
Thread 'Is this public key encryption?'
I've tried to intuit public key encryption but never quite managed. But this seems to wrap it up in a bow. This seems to be a very elegant way of transmitting a message publicly that only the sender and receiver can decipher. Is this how PKE works? No, it cant be. In the above case, the requester knows the target's "secret" key - because they have his ID, and therefore knows his birthdate.
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
17K
